Old 03-22-2008, 09:37 AM   #201
PBFAB.COM
PBFAB.COM's Avatar
Re: Crewcab build
Originally Posted by PrerunnerRob View Post
Funny you shoud metion that, I was just looking at them on ebay. Please excuse the ignorance, but what is an f-body? Camaro and Firebird maybe?
Correct... Camaro, Firebird and TA. They are very low profile... especially when compared to the truck oil pan.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-22-2008, 04:50 PM   #202
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Crewcab build
Whats wrong with the x-member you fabbed up ?? Are you have'n some clearance issues or what ??
I would say keep it...it lays rocker now, and you could use the money for something else.[/QUOTE]
Yep, the motor mounts are in a different spot on the ls1 I picked up. I'm going to have to re-figure alot of stuff out, but hey, thats how it goes right?
John, is there any way you could give me a measurment from the bottom of the oil pan to the top of the engine on the vette you are building? I think the corvette intake manifold setup is alot shorter then the truck one.[/QUOTE]
I sure can...but keep in mind the LS7 used a dry-sump lubrication system so the pan is really shallow. I can tell you right now my intake is way shorter.
Also, the adapter motor mounts plates are designed to mount to the SBC stock frame mounts...and place the rear of the LS block in the exact location as of a SBC/BBC. So in other words, the tranny would not move.
These plates came with the engine, but you can easily make them:
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-23-2008, 06:52 AM   #203
PrerunnerRob
PrerunnerRob's Avatar
Re: Crewcab build
Dry sump? Does the engine use an external resevoir or pump?
PrerunnerRob is offline   Reply With Quote
Old 03-23-2008, 08:07 AM   #204
1974k5blazer
Re: Crewcab build
freak'n amazing man, thats a beast of a project! stay motivated, i'll be pull'n for ya!
1974k5blazer is offline   Reply With Quote
Old 03-23-2008, 05:37 PM   #205
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Crewcab build
It uses an external 8 QUART massive frickin tank. (that I just figured out where to mount it)
Two -12 ports on the bottom pass side of the pan, that'll attach to the tank.
There are also ports on the tank for an oil-cooler hook-up. The engine builder informed me that I wouldn't need to run a cooler, but just might for the cool factor.
Check this out, I was concerned as to how far I could mount the tank. They informed me that they have run 10-15 foot lines from the block to a remote located tank. They told me the oil-pump generates over 120 psi, so this isn't a problem...wow !!
Sorry to jack, just thought it was cool.
I've seen LS1's converted to Dry-sump...they have pans with fittings available.
Not that you would need one, but if you wanted to make the pan super low-profile, you could...mabey lower the engine too.
Just a thought.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-24-2008, 07:14 PM   #206
PrerunnerRob
Re: Crewcab build
I need to lower the engine, thats where I am stuck right now. Oil pan is on the ground, and it's waaay too tall. I talked to Nathan Porter about this, he said a Camaro pan will do wonders for clearance.
Old 03-24-2008, 07:56 PM   #207
Frizzle Fry
Frizzle Fry's Avatar
Re: Crewcab build
Vette pans are even lower profile, but they have the "winglets" that make them hard to put in anything other than a Vette.
Frizzle Fry is offline   Reply With Quote
Old 03-24-2008, 08:41 PM   #208
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Crewcab build
What exactly do you mean by "winglets" ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-24-2008, 09:11 PM   #209
PrerunnerRob
Re: Crewcab build
I looked on ebay, and found out what they are. It's a "batwing" pan, that is super shallow, and spreads out across the underside of the pan
http://cgi.ebay.com/ebaymotors/LS1-L...spagenameZWDVW
Old 03-24-2008, 09:30 PM   #210
Hart_Rod
Hart_Rod's Avatar
Re: Crewcab build
Check out post #21, it has dimensions and part #'s. I'm going to use one of the Camaro one on my Suburban as soon as I can find one.
http://67-72chevytrucks.com/vboard/s...d.php?t=272174
Hart_Rod is offline   Reply With Quote
Old 03-24-2008, 11:51 PM   #211
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Crewcab build
My pan looks nothing like that...thats for sure, and it's a dry-sump out of a Z06 Vette....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-25-2008, 12:28 AM   #212
PrerunnerRob
Re: Crewcab build
Want to trade John?
Who makes the headers? That looks awesome!
Old 03-25-2008, 05:12 AM   #213
ElkyRacer
Re: Crewcab build
A f-body pan, or a new pan that they call the LH8 pan will help you in ground clearance area. The LH8 pan is hard to get ahold of from what Ive heard tho. Ive got the truck pan, and a f-body pan, just waiting to see which one Ill need.
Heres all you will need to know, and more about LSx pans.
http://www.ls1tech.com/forums/showthread.php?t=817787
ElkyRacer is offline   Reply With Quote
Old 03-25-2008, 05:17 AM   #214
Frizzle Fry
Re: Crewcab build
Thought that was your Dads? Ya, the dry sump pans are different.
Old 03-25-2008, 06:30 AM   #215
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Crewcab build
It is...for sake of conversation..."my build" is what I should of said.
The headers are FOR SALE !!!!
Are you interested ??
For cheap !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-25-2008, 07:53 AM   #216
Frizzle Fry
Re: Crewcab build
For cheap !!!
Just ribbin ya a little You're doing a nice job on it. I may be interested in the headers. PM sent.
Old 04-17-2008, 06:28 AM   #217
PrerunnerRob
Re: Crewcab build
Finally making some headway, this project has been put on hold due to alot of other things going on in life.
In order to mate tese 2 cabs together easier, I build a large adjustable table, but I haven't had a chance to finish the sliding rails that will hold the cabs. Here are few pictures of the cabs on the rails, and I'm going to build the sliders later this week.
Old 04-17-2008, 06:45 AM   #218
OLDNaVy3600
Thumbs up Re: Crewcab build
those porter builts are pretty sick huh?
i just installed one onto a 64 chevy long bed
lays frame !!!
this is my favorite project by far
ive never seen this....a crew cab with an LS7...you got balls man
Good Luck !
Looks amazing
_____________
Be American. Buy American.
1997 Chevy extended cab, 20's, Lowered, sound system that will blow your heart out of you chest
1951 GMC 100 Series(1/2 ton) Model 1665(long Bed) Project
2003 Pt Loser Get around Car (30 mpg)
oldNaVy3600
OLDNaVy3600 is offline   Reply With Quote
Old 04-17-2008, 07:48 AM   #219
PrerunnerRob
Re: Crewcab build
Thanks for the kind words, I'm still figuring things as I go!
Old 04-17-2008, 01:30 PM   #220
slammed1966chevy
slammed1966chevy's Avatar
Re: Crewcab build
Good job dude !
When in doubt drop it !
slammed1966chevy is offline   Reply With Quote
Old 04-17-2008, 03:23 PM   #221
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Crewcab build
Right on ROB !!! Glad to see you are back on it man !!!!
Should I reserve a seat now in that sucker when you take it out for the big cruise ?
Keep going bro !!!
Later
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-18-2008, 03:28 AM   #222
L0WRIDE
L0WRIDE's Avatar
Re: Crewcab build
nice work rob
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 04-18-2008, 05:02 AM   #223
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Re: Crewcab build
love the rail system Rob! Looking good. Jerry
ClassicAutoResto is offline   Reply With Quote
Old 04-21-2008, 08:57 AM   #224
PrerunnerRob
Re: Crewcab build
More progress made today, I finally had a chance to spend all day at my shop, and finished my sliding rail table. I placed both cabs on the sliders, evened them out on their mounts, and slid both together. I finished all of my rough cuts, slid them both together again, and found they fit very well.
After tacking the rockers together, I checked all the body lines. Everything is good, just minor shimming needed to get everything to line up.
DOH! I knew everthing was going way too smooth, so I threw my mock door up, and found I blew my measurement by 1/4". Ill be cutting them back apart again, removing that 1/4 inch, and everthing will be set from here on out! Gap is 3/8 now, need to go down to 1/8 between the two doors.
Old 04-21-2008, 04:24 PM   #225
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Crewcab build
Nice man, really nice !!
So what did you come up with the filler ??
Still gonna be suicide, right ?
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
