Old 01-06-2013, 09:29 AM   #1
502ms
502ms's Avatar
Arrow T56 Transmission Crossmember?
Hello!
I have a SWB 72 Stepside. Preparing to install LQ4 and T56. I want to ensure I have everything needed for a successful swap.
I was reviewing Shifty's thread on LS1tech.com, and he ran into a snag with his x-member, and recommends oe from Classic. I checked on their website, and only see one for an manual to auto upgrade. Does that one work? Or do I need to fab something up, or are there other options?
Thanks!
Reference:
http://ls1tech.com/forums/conversion...tepside-3.html
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 10-26-2013, 01:50 PM   #2
sbc10guy
sbc10guy's Avatar
Re: T56 Transmission Crossmember?
I also have the same question, one of the last things I cannot find anything on. Just wondering if you figured anything out on this?
1969 shortbed c/10
1998 GMC sierra
sbc10guy is offline   Reply With Quote
Old 03-18-2014, 01:05 AM   #3
eric8
Any answer on this? I'm at a loss as well with my swap?
eric8 is offline   Reply With Quote
Old 03-18-2014, 09:54 AM   #4
Custom 68
Custom 68's Avatar
I just modified my stock 400 turbo cross member. Worked for me...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-18-2014, 10:23 AM   #5
Hart_Rod
Hart_Rod's Avatar
CPP tranny cross member works well.
Hart_Rod is offline   Reply With Quote
Old 03-28-2014, 12:18 AM   #6
justahoby
I used mine that was trimmed for nv4500 on my t56, no mods were needed. I used the two bolt mount, and moved it back
justahoby is offline   Reply With Quote
Old 03-28-2014, 12:22 AM   #7
justahoby
I also modified the skip shift with the shift guide and made my own conversion .. Threw them in my mill and welded ..... you want to retain the reverse lockout so you don't find reverse at 70 mph the long stick makes it so I don't hook up the solinoid
Old 05-23-2014, 11:22 PM   #8
eric8
502ms, any luck?
Old 05-23-2014, 11:43 PM   #9
crazy longhorn
Fabricate till you "puke"
Set the angles right...I like to see 3-4 degrees down (to the rear) on the eng/trans, figuring the frame level? This is with the weight on the chassis. Up on stands is ok, but with the weight(all the parts on the truck)? Build the crossmember, to give what you want Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-07-2015, 09:51 AM   #10
eric8
Any further on the CPP tubular crossmember with the T56? Did it require lots of shimming to get your driveline angle correct?
Old 06-08-2015, 12:55 PM   #11
trkfrk
trkfrk's Avatar
I used the CPP crossmember and it was a direct bolt in with no mods.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 06-08-2015, 01:01 PM   #12
trkfrk
trkfrk's Avatar
Pic 2
Mark
Old 06-08-2015, 01:16 PM   #13
eric8
So trkfrk, you are using the older square tube design from cpp and not the tubular, correct? What mounts and perches are you using, and did you get lucky enough to use your factory holes in the frame rails for the crossmember? Looks great!
Old 06-08-2015, 04:10 PM   #14
trkfrk
trkfrk's Avatar
It must be the older one, I purchased it probably 4 years ago. Same with my motor mounts, they are from CPP also and we're the first design (tubular mounts). I moved my engine back from the factory holes approximately 1". I can't remember for sure, but I believe I did use the predrilled holes in the frame for the trans Xmember. My drivelines is being built now and hoping to test drive the truck this weekend.
Mark
Old 06-09-2015, 12:05 AM   #15
eric8
Very nice. Wish I was as far along as you. Did you get the 1" setback with adjustable sliding mounts?
crossmember, t56
