Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 12-09-2013, 10:10 AM   #1
Hart_Rod
Hart_Rod's Avatar
Cam/valvesprings/pushrods
I've got a cam/valve springs and keepers/valve seals/pushrods from a 2013 Camaro SS with only 135 miles. $150
Hart_Rod is offline   Reply With Quote
Old 12-16-2013, 01:20 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Cam/valvesprings/pushrods
$150? These are brand new parts!
Old 12-16-2013, 02:00 PM   #3
Jmiller022
Jmiller022's Avatar
specs? length of push rods?
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 12-16-2013, 02:16 PM   #4
Hart_Rod
Hart_Rod's Avatar
JMILL - this is what I found on line:
http://www.camaro5.com/forums/showthread.php?t=34774
Old 12-17-2013, 04:34 PM   #5
Hart_Rod
Hart_Rod's Avatar
L99 Lift specs
Camshaft Lobe Lift - Exhaust - Non Active Fuel Management Cylinders
7.48 mm
0.294 in
Camshaft Lobe Lift - Exhaust - Active Fuel Management Cylinders
7.61 mm
0.300 in
Camshaft Lobe Lift - Intake - Non Active Fuel Management Cylinders
7.48 mm
0.294 in
Camshaft Lobe Lift - Intake - Active Fuel Management Cylinders
7.61 mm
0.300 in
7.4 pushrods
Old 12-20-2013, 10:16 AM   #6
Ford Assassin
Ford Assassin's Avatar
It sucks, but the cam itself is pretty much worthless because it is a single bolt cam and the fact its AFM/DoD cam. Not something really worth swapping into another stock engine as an upgrade, plus it would require a GEN IV timing cover if attempting to use on a GEN III engine.
The springs are a decent enough for a mild aftermarket cam up to 0.570" lift or so.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
