Old 07-20-2014, 10:48 PM   #1
EightiesOnly
EightiesOnly's Avatar
VSS for Speedo and Cruise?
I have an '86 with a '01 5.3 DBC in it. I am currently adding the cruise control from the 5.3. I'm a little unsure on something.
The speedo and the cruise module require the VSS signal from the PCM. I'm just wanting to make sure it is okay to splice into this wire for the cruise module. I know it is a digital signal. Can splicing it in two disrupt the signal or is it okay to do? Perhaps there's another way to do it?
LC.
My Truck Build (1986 LS powered c10)
EightiesOnly is offline   Reply With Quote
Old 07-26-2014, 05:35 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: VSS for Speedo and Cruise?
You should have no problem with splitting the signal.
Hart_Rod is offline   Reply With Quote
Old 07-26-2014, 06:18 PM   #3
EightiesOnly
Thanks for the reply. I actually already did the splits and it works great!
LC.
control, cruise, speedo, vss
