Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 02-01-2016, 10:27 AM   #1
Hart_Rod
Hart_Rod's Avatar
GM Pulse Generator for electroc speedo
This a new part. They list for $129 from DD, I will take $80 shipped. I had 2, and still have one left!
The missing piece of the increasingly popular early-GM transmission swap!
With late-model GM transmissions containing an internal speed sensor outputting 128,000 Pulses Per Mile, the stock 40-tooth (40 pulse per revolution) reluctor ring provided the factory ECM with a high frequency input. The SEN-01-128 can now recreate this missing high frequency rate when converting to an older style transmission with a mechanical speedometer output.
With a standard female 7/8” thread-on fitting, the SEN-01-128 fits all GM transmissions with a mechanical speedometer cable outlet. Removable weather-tight 10’ cable provides for simple installation and cable routing. 128,000 Pulse Per Mile Sine Wave signal output is direct replacement for the stock GM internal speed sensor, allowing the ECM receive the signals it needs for proper operation.
Fits GM transmission models with 7/8” Male Threading, ie: TH350, TH400, 700r4, 2004r, etc.
http://www.dakotadigital.com/index.c...rod/prd916.htm
Hart_Rod is offline   Reply With Quote
Old 02-29-2016, 09:03 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: GM Pulse Generator for electroc speedo
bump
Old 03-03-2016, 08:01 PM   #3
chevy-fun
chevy-fun's Avatar
im interested but have some ?s. i have a 5.3/700r4 with VDO Vision Series Speedometers 437155. not connected, an using my phone gps. is this what i need. an which way would i hook it up
1-Pin Number
1. Not used
2. Red wire from Hall Effect sender
3. Ground and black wire from Hall Effect sender
4. 12V Switched
5. Not used
6. White wire (split) from Hall Effect sender
7. Not used
8. White wire (split) from Hall Effect sender
2-Pin Number
1. Not used
2. Not used
3. Ground
4. 12V Switched
5. Not used
6. Not used
7. Sender wire
8. Sender wire
3-Pin Number
1. Not used
2. Not used
3. Ground
4. 12V Switched
5. Not used
6. Not used
7. Not used
8. Sender wire
chevy-fun is offline   Reply With Quote
Old 03-03-2016, 08:46 PM   #4
Hart_Rod
Hart_Rod's Avatar
1-Pin Number
1. Not used
4. 12V Switched
5. Not used
7. Not used
2-Pin Number
1. Not used
2. Not used
3. Ground
4. 12V Switched
5. Not used
6. Not used
7. Sender wire
8. Sender wire
3-Pin Number
1. Not used
2. Not used
3. Ground
4. 12V Switched
5. Not used
6. Not used
7. Not used
8. Sender wire
Here are the directions to the sensor:
http://www.dakotadigital.com/PDF/SEN-01-128.PDF
Looks like you have a 12V power, GRND and the sensor output. Which matches up to #3. Let me know.
Rob
Old 03-04-2016, 12:35 PM   #5
Hart_Rod
Hart_Rod's Avatar
1-Pin Number
1. Not used
4. 12V Switched
5. Not used
7. Not used
2-Pin Number
1. Not used
2. Not used
3. Ground
4. 12V Switched
5. Not used
6. Not used
7. Sender wire
8. Sender wire
3-Pin Number
1. Not used
2. Not used
3. Ground
4. 12V Switched
5. Not used
6. Not used
7. Not used
8. Sender wire
Do you want it?
Old 03-04-2016, 09:33 PM   #6
chevy-fun
chevy-fun's Avatar
Yes. But strap on cash right now. Don't get paid till Wednesday. I'll check back then to see if it hasnt sold
Old 03-04-2016, 11:03 PM   #7
Hart_Rod
Hart_Rod's Avatar
No worries . I hqve two of them,
Old 03-06-2016, 01:07 AM   #8
Aruba1
Will it work on the 5.3L with NV4500?
Aruba1 is offline   Reply With Quote
Old 03-06-2016, 09:06 AM   #9
Hart_Rod
Hart_Rod's Avatar
I dont see why not.
Old 03-08-2016, 12:04 PM   #10
Hart_Rod
Hart_Rod's Avatar
Are you still interested?
Old 03-08-2016, 09:02 PM   #11
chevy-fun
chevy-fun's Avatar
Hi HART ROD. if you can send me your paypal or how to pay. I can send the $ around 3-4am, an when would you be able to ship. hoping to try to have before the wkend when i go out town for a show. thanx you in advance
Old 03-08-2016, 09:09 PM   #12
Hart_Rod
Hart_Rod's Avatar
Paypal is robhartley@aol.com. It would have to be overnighted fornyou to get it by this weekend.
Old 03-08-2016, 09:31 PM   #13
chevy-fun
chevy-fun's Avatar
its k just ship it regular. doubt i would have time to actually get it put on in time cuz of work. ill send the $ in morning. thanx again
Old 03-08-2016, 10:06 PM   #14
Hart_Rod
Hart_Rod's Avatar
Sounds good!
Old 03-09-2016, 07:39 AM   #15
chevy-fun
chevy-fun's Avatar
payment sent
Old 03-09-2016, 08:31 AM   #16
Hart_Rod
Hart_Rod's Avatar
payment sent
Will be in the mail today. Thanks!
Old 03-11-2016, 09:17 AM   #17
Hart_Rod
Hart_Rod's Avatar
payment sent
Shipped, thanks again!
I still have one left, let me know .
Old 03-12-2016, 07:45 PM   #18
chevy-fun
chevy-fun's Avatar
Received the part. Thanx again Hart Rod
Old 03-13-2016, 10:20 AM   #19
Hart_Rod
Hart_Rod's Avatar
Your welcome!
I have one more left!
Old 03-19-2016, 09:06 AM   #20
Hart_Rod
Hart_Rod's Avatar
Bump
Old 04-03-2016, 09:17 PM   #21
chevy-fun
chevy-fun's Avatar
thanx again HART ROD. finally got around to installing last wk. gauge is finally working.
Old 04-05-2016, 12:26 PM   #22
Hart_Rod
Hart_Rod's Avatar
Sweet! I've got one more for sale if anybody else needs one.
Old 04-30-2016, 08:34 AM   #23
Hart_Rod
Hart_Rod's Avatar
bttt
Old 06-04-2016, 11:58 PM   #24
elf w/capital T
If it only fit and worked on an nv3500. Ugh good luck!
elf w/capital T is offline   Reply With Quote
Old 06-05-2016, 12:42 AM   #25
Hart_Rod
Hart_Rod's Avatar
Why wouldn't it? Isn't that where your speedometer cable mounts now?
