06-27-2016, 10:56 PM | #1 |
Code po332
My truck has a po332 code which is for a knock sensor. My knock sensors are new and My motor has never gotten wet so I know that's not the problem. I do notice my truck makes a lot of lifter noise. Could that be causing a false reading? My truck also seems to be sluggish. Would this cause a low power problem? My truck just has a base tune in it and I'm bringing it to be tuned in the next couple of weeks. I want to get these bugs worked out before it hits the dyno
06-27-2016, 11:49 PM | #2 |
meowMEOWmeowMEOW
Re: Code po332
False? We don't know its false yet, you might actually have knock....
How bad is the lifter noise, and did you do heads/cam or something like that? If you have noisy lifters (beyond the normal "ls motors are noisy" level), then you probably have a mechanical problem. Ruling out a cause of knock while an actual defect exists won't get us anywhere.
06-28-2016, 03:46 AM | #3 |
Re: Code po332
I just went though thiz on my suburban . I replace my knock sensors when I did my intake gaskets using bwd sensors from Advance Auto Parts a new harness from Dorman. About 3,000 miles I have my check engine light come on for the p0332 knock sensor too low signal + short. I had to put my intake back off and I replace the knock sensors with the OEM Delphi and new harness harness. So far it has not come back I found out that the aftermarket knock sensors not that great
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-28-2016, 07:17 AM | #4 |
Re: Code po332
Brew city it does have a cam. Truck dude, those are the same knock sensors I used. Where do you buy the Delphi sensors...Dealer only?
06-28-2016, 09:24 AM | #5 |
Re: Code po332
No i ordered them from advance auto made them warranty them out it took them about a week to get them they where actlay cheaper then the bwds i bought the dephi number is AS10017 i paid 46 for them where are the advance brand was 56 each, i made them warranty the knocks sensors the harness and intake gaskets when i redid mine. but i also have a comerical account so they wanted to keep me happy, but it would not be unreasonable for a walk in customer to ask for all that to be warrantied out
06-28-2016, 09:29 AM | #6 |
Re: Code po332
06-28-2016, 10:31 AM | #7 | |
Re: Code po332
06-28-2016, 10:38 AM | #8 |
Re: Code po332
You may need to adjust the Knock threshold in the tune do to the cam and headers...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-28-2016, 11:20 AM | #9 |
Re: Code po332
