Old 09-07-2016, 07:06 PM   #1
59 Turbine
Bagged, turbo LS, 59 Apache build
Hello - I am new to the board but have been a long-time lurker. Figured I would post some pictures of my 59 which has been going through a transformation for the last 10 months.
The project started off with what I thought was a good, driver quality truck that had been "updated" in the late 80s and again in 2003. It had a mild SBC, 700r4 and some nice accessories like a March serpentine system, Vintage Air, BeCool radiator, etc. Unfortunately, it also had the most poorly fab'd rack/steering box/column config you have ever seen and as a result, it handled like a shopping cart. It was scary.
So, since it had already been cut on we decided it was a good starting point for a bagged, LS sleeper. In January of this year, I dropped it off at Hale's Speed Shop in Lewisville, TX and things got moving pretty quickly.
Name:  starting point.jpg
I missed a few pictures at the start of the tear down but it was stripped to the frame in 1 day.
We were able to sell the entire drive train to another gear head
Chassis fab under way with 4 link, bag mounts and temporary rear end.
Name:  rear chassis 1.jpg
Front end was setup and LS motor mounts were fab'd using a plastic LS block. Around this time, Nathan Hale convinced me to go with a turbo and you can see the turbo manifold in this pic.
Name:  front chassis and motor mount fab.jpg
59 Turbine is offline   Reply With Quote
Old 09-07-2016, 08:16 PM   #2
59 Turbine
Re: Bagged, turbo LS, 59 Apache build
Name:  raw rear chassis.jpg
Old 09-07-2016, 09:01 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Gonna be a bad ride when you get back on the road..looks good..
Old 09-07-2016, 10:00 PM   #4
71swb4x4
71swb4x4's Avatar
What a tease...
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-07-2016, 10:38 PM   #5
59 Turbine
Built LQ9 (6.0) should make just over 1,000 HP to the tires with 88MM turbo....on pump gas.
Should be on the road this month and will ride just a little higher than it appears here.
Name:  first mock up.jpg
Old 09-07-2016, 10:43 PM   #6
jaws61
Wow looks awesome and happy to see another LS build, I can steal ideas off of.. lol
What Oil pan did you use and is the passenger back valve cover just about to touch the firewall? Thanks!!
jaws61 is offline   Reply With Quote
Old 09-07-2016, 11:02 PM   #7
59 Turbine
Yes, the passenger valve cover is about to hit the firewall. We were changing transmission mounts the day that picture was taken so the mount was out and the motor was tilted back more than normal. With the mount in place, there is about 1 inch of clearance between the valve cover and firewall. The new valve covers don't have the coil mount posts on them which also gives it more clearance.
The oil pan is from an F body (Camaro). It's GM part # 12558762.
Old 09-07-2016, 11:10 PM   #8
mongocanfly
Post Whore
1000hp...88mm turbo...dang it boy..you gonna have to give more details than that..haha..I agree with 71 4x4...you just teasing us..
Old 09-07-2016, 11:30 PM   #9
59 Turbine
The motor has a Texas Speed 4.125" crank and super I-beam rods, Diamond pistons (10:1), custom cam grind, stainless valves, PAC beehive springs, titanium retainers, etc.
The intake is a Holley Hi Ram with 105MM throttle body and 160# injectors.
Transmission is a Tremec T-56 Magnum with a McLeod RXT clutch.
Rear end is a Ford 9" from Quick Performance.
Old 09-08-2016, 06:40 AM   #10
dug224
dug224's Avatar
Incredible detail on the frame. Keep the photos coming. dug
dug224 is offline   Reply With Quote
Old 09-08-2016, 10:20 AM   #11
Kim57
Kim57's Avatar
welcome.
Very cool build.
Should be pretty wicked when done.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-08-2016, 10:36 AM   #12
bL.A.zer90045
Camaro/firebird fuel tank?
bL.A.zer90045 is offline   Reply With Quote
Old 09-08-2016, 11:07 AM   #13
59 Turbine
The tank pictured was just used during fabrication. The one in the truck now is the same size but is an Aeromotive Stealth for a 64-68 Mustang.
Old 09-09-2016, 11:16 AM   #14
FAKKY
Nice.
Holley Dominator EFI ???
FAKKY is offline   Reply With Quote
Old 09-09-2016, 06:46 PM   #15
59 Turbine
Originally Posted by FAKKY View Post
Nice.
No, stock GM ECU reworked by the tuner.
Old 09-10-2016, 02:25 AM   #16
Nut Case
Nut Case's Avatar
"59"
That rear suspension is real slick....
What a nasty looking mill.
Keep on keepin on
Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 09-15-2016, 09:24 PM   #17
59 Turbine
Here is a pic of the transmission tunnel a few people have asked about.
Name:  transmission tunnel.jpg
Old 09-15-2016, 10:46 PM   #18
jaws61
Wow Looks Awesome and Thanks for the Information on the Oil pan and motor placement!! That is a huge help to me and looks like now ill be doing a tunnel after seeing your last pic!! Truck looks awesome and any chance you have a pic of the driver side of the motor with the steering?? Thanks Again and cant wait to see more!!
Old 09-21-2016, 04:10 PM   #19
RockinKees
RockinKees's Avatar
Nice build!!
Just read it and want to see more!!
Motor is looking pretty Angry
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 09-21-2016, 05:43 PM   #20
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Great build! Please post lots of pic's!!!
ChuckDriver is offline   Reply With Quote
Old 09-21-2016, 09:06 PM   #21
Rods57
Rods57's Avatar
Very cool build, love the tunnel
Rods57 is offline   Reply With Quote
Old 09-25-2016, 11:38 PM   #22
SLCviaAK
This is such an awesome build! Love what Hales Speed Shop is doing.
SLCviaAK is offline   Reply With Quote
Old 09-26-2016, 12:52 PM   #23
hooliganshotrods
So nice! Wondering if you have any more info/pics on how you did the front control arm mounts!
I just took on another build a 58 Apache that I'm bagging, got it laid out with a heidts mustang II front and narrowed control arms but the arms stick way way up and liked what you did.
What size rims and tires are you using?
hooliganshotrods is offline   Reply With Quote
Old 09-26-2016, 01:30 PM   #24
tinydb84
tinydb84's Avatar
Hale's makes some very cool rides. Should be fun with all that HP. I don't understand why they 2 link everything though. I would think that with the amount of work and time put into each ride they would opt for a better rear suspension set up.
David
Instagram: myfabguy
Old 10-02-2016, 10:59 AM   #25
59 Turbine
Rolling to Good Guys Lone Star Nationals today.
bagged, t-56, tremec, turbo ls
