05-07-2023, 09:24 AM | #1 |
Front shock selection for 2" lowering springs
I just installed front 2" lowering springs on my 68 C10 and trying to find a shock that will work without relocating the upper mount.
With the truck sitting on the ground the shock mounting length is right at 11" and the stock shocks are 10" compressed which only gives me 1" of travel before bottoming out. I have searched everywhere for drop shocks for just a 2" lowering spring and most offered are similar in length to the stock shocks lengths. I've found a Monroe shock that is 8 3/8" compressed and 12 3/4 extended with the correct mounts but with these I'm worried that the extended length is too short for when the truck is on the lift since the unloaded mount length is 13 1/2" and the shock would be supporting the weight of the front suspension vs. the upper bump stop. So what shock is everyone using for shock for a 2-3" front drop spring? |
05-07-2023, 02:31 PM | #2 |
Re: Front shock selection for 2" lowering springs
A stock length shock will work fine with the drop springs unless you changed the bump stop height. Truck bottoms out at the same location as stock with the lowering springs. Note that the shock is mounted at an angle and not at end of arm. Suspension movement to shock is not 1 to 1 or as much as wheel travels up and down.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
05-07-2023, 08:46 PM | #3 |
Belltech street performance shocks work great on these trucks. Are available in drop lengths.
Jimmt
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-16-2023, 02:00 PM | #4 |
I used these and trimmed the extra tabs off. Bolted it to the frame rail of my '66, it gave 2-3" more travel using a stock length shock. Rode great with the bump stop brackets removed, KYB Gas-A-Just shocks, and stock spring with 1.5 coils cut off.
https://www.summitracing.com/parts/cur-ce-7020
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
05-17-2023, 12:27 PM | #5 |
Yep.... Another vote for stock shock lengths & if anything upper shock relocation brackets.
