Old 05-22-2023, 04:56 PM   #1
kglowacky
a/c charged and cooling
well today was a big test for me and my truck. After driven it for 2 summers in Houston without a/c. I decided to see if an old factory a/c system with only a new type compressor and a orifice change would cool. Well it did with a couple challenges still left
Info. 78 c-10 Silverado, new r-34 compressor and condenser. 2002 Camero ls 1 and 460 e.
Here are what I am trouble shooting.
idle is good and when I turn on a/c it adjust perfectly
cold air
had to bypass a new binary switch. Going to go back to the low pressure oem typed switch. hopefully it will work.
Then my mechanic put the truck on the computer, and all was good except it threw a alt. volt code. At idle no a/c 13 volts. Turn on a/c drops below 13 not sure but my guess 11.5 sometimes it will come back up at idle sometimes it doesn't this is in drive sitting still. Go down the road it goes back to 13. He thinks my alt needs rebuilt. I thought I read somewhere on here 12,8 is normal.
last my engine temp running 181. He thinks too low. I have it hooked up when turn on a/c cooling fans come and run all the time. I also have a big, oversized radiator. I am old school and always believe the cooler the better. He says maybe running to cool and may affect my gas milage as it is around 10mpg,
last on MPG I have a 3.70 rear end ratio gear thinking of going to a 3.07. Any thoughts how much this will improve my milage?
Thoughts???
kglowacky is offline   Reply With Quote
Old 05-23-2023, 07:28 PM   #2
Jason Banks
Jason Banks's Avatar
Re: a/c charged and cooling
I kind of agree with you on temp. My straight 6 truck has a 4 core radiator and can idle in a 4th of July parade for hours. My LS swap, I'm getting up to closer to 212+ when the high speed fans kick on. I'm pretty sure your mechanic is right about it being more efficient/clean burning at higher temperatures.
I think you can mathematically what kind of increase in MPG you would get out of the lower gears, but you are still driving a brick into the wind, I'd imagine the improvement is minimal, since you already have overdrive, the RPM's at speed are not that high anyway...
Jason Banks is offline   Reply With Quote
Old 05-24-2023, 08:25 AM   #3
Rich84
Rich84's Avatar
10 MPG is quite low. Is there a chance that your odometer might not be accurate? I have a 6.0 with 3.73 gears and average about 15MPG around town on 2 different trucks (1986 long bed, 84 stepside). They both run at 195 degrees. Fans come on at 205 IIRC.
Rich84 is offline   Reply With Quote
Old 05-26-2023, 09:50 AM   #4
clay68c10
clay68c10's Avatar
Your gearing should be fine with the 4L60e. 3.07 would be a downgrade. Look at some online gear/rpm calculators and compare what the stock LS equipped trucks run for rpms at different speeds. I bet you're close to that now.
Get the right 195 thermostat in there, it's probably not helping you mileage.
Those low temp thermostats don't fix anything, these engines are made to run around 200-210. The stock fan settings are higher than you would think, like low at 210, high at 220.
Your system voltage is low, 13-14v at idle is normal. I'd say your guy is right, it's new alt time.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-26-2023, 11:02 AM   #5
jjzepplin
jjzepplin's Avatar
Off topic... Could you post a pic or two of your AC system?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-27-2023, 01:15 PM   #6
kglowacky
here's a couple pics of my a/c system
If you need anymore let me know what it is you are looking for.
Old 06-12-2023, 12:32 PM   #7
Hart_Rod
Hart_Rod's Avatar
You should be seeing about 13.7 volts if the alternator is charging correctly.
Hart_Rod is online now   Reply With Quote
