Today, 09:46 AM | #1 |
Just picked up an LT4 swapped '86 C10
Hey y'all, I just picked up a new to me '86 C10 Silverado with a '96 LT4 swap. Working through some issues with it, but the intent is to daily drive it so I can sell my newer truck & get rid of any car payments! Working on tracking down why I experienced massive oil loss (2 quarts in ~250 miles) without seeing or smelling burning oil. The front of the engine was wet so put new timing cover gaskets/seals in. Hopefully that helps.
Next up is fixing the amateur hour wiring job one of the previous owners did (i.e. turn signals only work when headlights are off). Anyway, glad to be here & I expect I'll be spending an inordinate amount of time on the forum as I work through everything. |
Today, 10:47 AM | #2 |
Re: Just picked up an LT4 swapped '86 C10
Nice rig! Sucks you're eating oil though, might be time to bust out the bore scope and take a look in the cylinders. Its either burning it or leaking it, not many options for losing that much oil that quickly.
As far as wiring goes, should be pretty simple to track down if you have a decent schematic and a DMM. If you need any electrical help just holler
84' C-10 Custom Deluxe 97' & 98' C-1500 Silverados |
Today, 10:52 AM | #3 | |
I may end up pulling all the random aftermarket wiring the guy did out & redoing it properly. Can't stand to have stuff rigged. Last edited by F/51 LRS; Today at 01:37 PM. |
Today, 11:12 AM | #4 | |
Today, 02:51 PM | #5 |
It's pretty rare to see a gen2 SBC swap! Do you have any engine bay pics? Those 1990's LT1 and LT4 engines were some of the best looking engines out there.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
Today, 03:10 PM | #6 |
Good looking Square!
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
