Old 11-06-2009, 11:08 PM   #151
VA72C10
VA72C10
VA72C10's Avatar
Re: 68 S/C update.....
very nice!!!
Old 11-07-2009, 12:35 AM   #152
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
whats up with the okie plates
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-07-2009, 08:23 AM   #153
But you aren't in Kansas, wait, New Mexico, wait Oklahoma.. no more
Very nice Rob! That interior is real sweet!
Old 11-07-2009, 09:05 AM   #154
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
That's one sweet ride!
ChuckDriver is offline   Reply With Quote
Old 11-09-2009, 02:17 PM   #155
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
ooooooooo.. nice. So, is the truck registered under those plates?
wait a minute, wrong state
LOW DOUGH is offline   Reply With Quote
Old 11-09-2009, 03:13 PM   #156
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Rob, the interior turned out real nice. I'm curious on the story behing the OK plate as well...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-09-2009, 06:22 PM   #157
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
hey great looking truck, im gonna be getting that same steering wheel in my blazer. how does it feel, too big or anything like that and is it weak, does it flex alot. that rhino liner sure did your bed justice
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 11-09-2009, 09:25 PM   #158
Hart_Rod
Hart_Rod's Avatar
Originally Posted by VA72C10 View Post
very nice!!!
Thanks!
I was born in 68, I grew up in OK, and I drive a farm truck........
Thanks!
See above, .
See above, .
I really like it alot. It's smaller than the original and has a nice feel to it. I drove the truck without power steering for a couple of months and I never noticed any flexing. I think the liner really cleaned everything up in the bed. I know purist probably think I should have just painted it back to orginal color, but believe it or not, I plan on using it as a truck, .
Hart_Rod is offline   Reply With Quote
Old 11-10-2009, 12:12 AM   #159
djracer
djracer's Avatar
Rob what did you do with the real big wheels and tires that had the hubcaps. I bought my son a truck that needs a fat rear tire.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-10-2009, 12:21 AM   #160
Hart_Rod
Hart_Rod's Avatar
Kevin - those are my Welds wheels that I had just set the hubcap in place to take the pictures.
Nice truck by the way. What powerplant are you going to use?
Old 11-10-2009, 12:26 AM   #161
djracer
djracer's Avatar
10/4 I thought it was a different set. You may have your 20x12's by the time I need any. My son is only 12!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-10-2009, 12:31 AM   #162
Hart_Rod
Hart_Rod's Avatar
, I've thought about selling these awhile back until I started checking on prices....
Old 11-10-2009, 05:54 PM   #163
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
are you making a build thread
Gage
Old 11-11-2009, 06:05 PM   #164
Hart_Rod
Hart_Rod's Avatar
I put the 68 to work today, . Check out this sleeper that was at my buddy's shop.....
Old 11-11-2009, 09:30 PM   #165
msgross
msgross's Avatar
vortec S-10... I smell a race coming...
don't you have keys to the airfield?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-15-2009, 02:18 PM   #166
justcuz
justcuz's Avatar
Nice truck and a great set of additions. I like the fact that you made it usable as a truck again and yet maintained all the go fast goodies. A true dual purpose vehicle.
I take it you are done in New Mexico and back in Florida permanently.
Quite a change I bet. Nice picture with the family, now I know why you are building a Suburban and a Crewcab!
Thanks for keeping us in the loop with your builds, they are top notch!
I am considering converting my 72 long bed to 3/4 ton since I need a good tow vehicle. I have the HO52 (4.56 or 4.11 I have both) and front disc spindles, calipers, hubs and LCA's.
Plan is 350 4bbl, 700R4, HO52 with disc brake conversion and a 14 bolt Detroit Locker, 8 lug disk brake front end conversion. I will probably leave the 1/2 ton springs in it and use 265/75x16 tires on late model Chevy aluminum wheels and caps. Air bags or factory add on leaf overloads in the rear to handle toungue or load weight.
Looking at the rear axle I am figuring a 3.20 overall ratio in OD if I use 4.56's and 2.90 if I use 4.11's. Probably only a couple hundred RPM difference at 70-75 cruise speeds. If I use the 4.56's I'll have a lot of low end grunt to get stuff moving.
Final consideration is a Blazer tank in the rear between the frame rails, with the filler behind the tailight or side marker and move the step bumper up, by replacing the S bracket with straight stock and running the receiver hitch through the bumper to the rear crossmember.
I see in your vehicles you have gone away from 8 lug to lighter running gear but for me and the way I use my vehicles I prefer the beef of the 3/4 ton running gear and brakes.
justcuz is offline   Reply With Quote
Old 11-15-2009, 02:24 PM   #167
justcuz
justcuz's Avatar
It would not surprise me if the S-10 and the 68 weigh within a couple hundred pounds of each other. I personally give the edge to the 68 being lighter.
Old 11-16-2009, 09:21 PM   #168
Hart_Rod
Hart_Rod's Avatar
, that's a thought....What are they going to do, kick me out??
Thanks for the post and the props, . I just like having the options to swap wheels back and forth. I don't plan on working any of them to hard, .
I'm guessing the 68 will probably weigh around 3400, I'm going to check the next time I'm over near the scales. I think I can take him........
Old 11-17-2009, 01:29 AM   #169
GASWAGON
AMERICAN IRON ADDICT
Killer truck!! Love the welds! Any chance you would share the sizes on the wheels and rubber?
GASWAGON is offline   Reply With Quote
Old 11-20-2009, 11:07 PM   #170
Hart_Rod
Hart_Rod's Avatar
Fronts: 15 X 5 (3" BS), 225 75 15
Rears: 15 X 12 (6" BS), 29 tall, 15.5 wide Hoosiers
Old 11-20-2009, 11:58 PM   #171
67_ShortFleet
67_ShortFleet's Avatar
Nice truck! Where did you put the fuel fill with your new tank?
67_ShortFleet is offline   Reply With Quote
Old 11-21-2009, 12:11 AM   #172
CheyenneShop
CheyenneShop's Avatar
Rob, this truck looks great, from family picture at the local pumpkin patch to Drag strip sleeper - it almost sounds like a superhero comic or something
Ronnie
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 11-21-2009, 12:21 AM   #173
thelonerife
thelonerife's Avatar
Rob, truck looks great. I think you've done a great job with the upgrades. Plate looks good too. I'll have to find me a 68 TN plate now.
thelonerife is offline   Reply With Quote
Old 11-21-2009, 11:19 AM   #174
Hart_Rod
Hart_Rod's Avatar
I'm still working on that......
Ronnie
, Thanks Ronnie. It's a really fun truck and I've enjoyed using it as one. Any progress on yours?
Thanks! The tag fits the truck perfectly, now if I could only find an aluminum camp shell to go on it..........
I pulled the valve covers to change the gaskets and snapped a shot of the goodies underneath, .
Old 11-21-2009, 11:51 AM   #175
Rokcrln
Rokcrln's Avatar
I would love to drop a Paxton or similar on LowBuck but it would require way too much money to redo the computer system. I have Painless's kit and it is not end user friendly at all. They want another $800+- just for the software to unlock the ECU. So I think I might just need to wait and put a Mag'y on the Tahoe
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
