Old 01-05-2010, 12:46 PM   #76
americanmusc1e
americanmusc1e's Avatar
Re: Show your motor...
Originally Posted by mosesburb View Post
just a big heavy six cylinder. Turbo'd, intercooled, and fuel injected. Runs on diesel too.
i want one!!!!!!
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 01-06-2010, 01:21 AM   #77
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
Just a big heavy six cylinder. Turbo'd, intercooled, and fuel injected. Runs on diesel too.
A 6BT in a 72 Burb; I have now seen it all
Anyone like seeing diesel engines in anything check out this site
www.4btswaps.com/
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 01-06-2010, 02:10 AM   #78
howard_m18
howard_m18's Avatar
I thought I posted mine,BUT can't find it? My mind is my best friend, I just wish it would visit me more often!! The stock 350 came out of a 68 conversion van that I had & it is hooked up to a 700 trans!
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI.
howard_m18 is offline   Reply With Quote
Old 01-06-2010, 02:13 AM   #79
s_nova69
Here is my 500 hp 406. 5.7 gm pm rods, stock crank, Chapman ported Sportsman II heads, stainless rockers, gmpp alum water pump, fully balanced. Is installed in my 70 Longhorn now. Runs hard.
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 01-06-2010, 03:44 AM   #80
c10seconds
c10seconds's Avatar
Originally Posted by rob32472 View Post
Here's mine
what headers and motormount adapter did you use? are you happy with the clearance? Im in the process of converting my 67 2wd to an lsx. trying to figure out the best way to do it.
c10seconds is offline   Reply With Quote
Old 01-06-2010, 10:56 AM   #81
Hart_Rod
Hart_Rod's Avatar
They are Doug Thorley Headers and Early Classic Enterprises (ECE) motor mounts. It's the same setup I have on both of my trucks. Clearances are great and both products work as advertised.
Hart_Rod is offline   Reply With Quote
Old 01-07-2010, 04:45 PM   #82
425HP409
425hp409
425HP409's Avatar
Here is the engine I have finished for my 68. It is a Gen 5 454 with original 402 heads, intake & exhaust manifolds, and accessory brackets. I installed a Holley Spreadbore that I rebuilt and I test ran it and made all adjustments on my engine stand, and now am ready to install it in the truck.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 01-10-2010, 11:46 PM   #83
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Finally got my engine done to the point of needing to install back in the frame.
Went from this,
To this,
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-16-2010, 11:41 PM   #84
po_bird
po_bird's Avatar
Yeah! Keep em coming
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
po_bird is offline   Reply With Quote
Old 01-16-2010, 11:50 PM   #85
'72customdeluxe
lol srsly? And if it's cranking out 500 why are you running flowtechs with 1.5" primaries. Need more like 1-7/8
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 01-17-2010, 01:15 AM   #86
AJs72K5
AJs72K5's Avatar
BBC 460. Edelbrock aluminum heads. Edelbrock MPFI. Comp hydraulic roller cam. 10:1 compression. Camquest says: 515hp @ 5000; 580tq @ 4000. Going in my 72 K5.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 01-17-2010, 05:34 AM   #87
420am
420am's Avatar
Work in progress..
350 cid
Edelbrock 650cfm
Edeldrock 1" carb spacer
Edelbrock EPS Manifold
Lunati Bracket Master II Cam / Lifters / Pushrods
Comp Cams Roller Rockers
Comp Cams Double Roller
'906' Iron Vortec Heads
Not pictured..
MSD Distributor Cap/Rotor
MSD Streetfire Wires
I've done about everything I can without pulling the motor. I know if I pull it out I'll tear it completely down and I won't have the money to put it together before summer. This motor was just a O'Reilly's rebuilt motor with maybe 20k on it that I was going to replace a head gasket on.. then replace a head gasket and port and polish the old crap '882' heads on.. then I got new heads, which required a new intake.. Hahaha.. I wonder when I'll be done.
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 01-17-2010, 01:06 PM   #88
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Heres the 454 in my 72 sounds good still have not even drove the damn thing...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-17-2010, 09:26 PM   #89
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Originally Posted by Old Red View Post
Here's a 427 with 3 two's
I want that!!!
-Ron-
OldSkool71 is offline   Reply With Quote
Old 01-18-2010, 12:12 AM   #90
nuke1
nuke1's Avatar
Here's mine, i love showing it off, but next winter she will be apart agaoin.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-18-2010, 12:14 AM   #91
po_bird
po_bird's Avatar
Green is mt fav color
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
Old 01-18-2010, 12:39 AM   #92
ozman3803
Sweet thread, I love SBC but how about some 500+ci BBC
ozman3803 is offline   Reply With Quote
Old 01-18-2010, 01:30 PM   #93
Inked Okie
Inked Okie's Avatar
68 chevy 350 still under construction
Wade
Inked Okie is offline   Reply With Quote
Old 01-18-2010, 02:28 PM   #94
dznucks
dznucks's Avatar
68stepbed, bigsnookmaster,
What engine paint are you two using? those two motors look awsome.
dznucks is offline   Reply With Quote
Old 01-18-2010, 02:42 PM   #95
Fitz
572/620 in my 67 Stepside:
Fitz is offline   Reply With Quote
Old 01-18-2010, 04:34 PM   #96
kvn1011
Kvn1011
kvn1011's Avatar
nice!!!
kvn1011 is offline   Reply With Quote
Old 01-18-2010, 06:37 PM   #97
68Stepbed
68Stepbed's Avatar
dznucks, I used rattle can touchup paint(MOPAR to match truck color) for my block and heads. The VC's, intake and other bits and pieces, I used DupliColor Cast Coat Iron engine enamel from Advanced Auto Parts.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-18-2010, 10:22 PM   #98
po_bird
po_bird's Avatar
Fitz thats one bad azz motor
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
Old 01-20-2010, 09:18 AM   #99
dznucks
dznucks's Avatar
Thanks 68stepbed
Old 01-23-2010, 09:44 PM   #100
Fastest32
Fastest32's Avatar
Fastest32 is offline   Reply With Quote
