Old 02-17-2011, 12:13 AM   #1
polock07
Polock07
Project: ROGUE GMC
After Six months and countless hours researching online, i have finally acquired the necessary items to hopefully build a 1-ton quad cab 1969 GMC. The last part, a 1969 suburban i dragged into my garage this weekend after i put a coat of sealer on the bed, fenders and hood for the project, so i could move them outside. The search for parts is over; now the real work begins
polock07 is offline   Reply With Quote
Old 02-17-2011, 12:20 AM   #2
67chevy1series
67chevy1series's Avatar
Re: Project: ROGUE GMC
well sounds like a great build gotta love 4 doors!
67chevy1series is offline   Reply With Quote
Old 02-22-2011, 12:54 AM   #3
polock07
Polock07
Project: ROGUE GMC
finished cleaning out the suburban, found out it was my brother buddy from high school rig, explains all the dents in the back, its time to preform some civil war surgery and take off the back with a sawzall
Old 02-22-2011, 01:07 AM   #4
threeonthetree
threeonthetree's Avatar
Rick its only a 3 door!
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 02-22-2011, 01:07 AM   #5
threeonthetree
i hate to see you hack that suburban up man there to cooool....
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-22-2011, 01:44 AM   #6
project 67 sub
project 67 sub's Avatar
x2, but it just makes them even more unique and worth more the less of them their are
project 67 sub is offline   Reply With Quote
Old 02-22-2011, 01:47 AM   #7
threeonthetree
good Point!
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-22-2011, 01:55 AM   #8
project 67 sub
yup. oh well, at least i already have mine
Old 02-22-2011, 02:10 AM   #9
threeonthetree
not to many suburbans left in Wisconsin.....
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 03-04-2011, 11:54 AM   #10
polock07
Polock07
I felt bad about chopping up the suburban those things are great, but the back was in horrible shape and "you got to break a few eggs to make an omelet".
spent the weekend pulling the axles off a 1 ton, two dana 60 should fit my project nice. got a little further on combining the two cabs the right side looks pretty straight forward its the drivers side that i'm still working out, the want to make it a four door is there, next week is dead week then finals week so not going to get much done, but spring break should be able to makeup time
Old 03-16-2011, 10:57 PM   #11
polock07
Polock07
Started working on the fourth door this weekend was able to get all the sheet metal off with no damage to it so hopefully i can turn it into the fourth door skin
Old 03-27-2011, 04:10 PM   #12
polock07
Polock07
started attaching the back of the cab today, once it all lines up the welding will begin
Old 03-27-2011, 04:16 PM   #13
Maxxd07
Maxxd07's Avatar
Cant wait to see this one done!
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 04-24-2012, 01:20 PM   #14
polock07
Polock07
Well finally starting to look like a four door, went to scrap yard and found a GMC front clip and a roof that's in good shape for the front of the roof, issues going to be connecting the back to the front and making the inside look stock.
finally decided on a 12 valve cummins turbo diesel, manual, figured i'd set the crew cab on the dodge frame and move body mounts to fit. but that's a ways off still need to finish roof and build fourth door and alter third door
Old 04-24-2012, 02:56 PM   #15
Hart_Rod
Hart_Rod's Avatar
Nice build! Looking forward to more pictures.
Hart_Rod is offline   Reply With Quote
Old 04-24-2012, 03:25 PM   #16
JRANGER
JRANGER's Avatar
should be sweet
JRANGER is offline   Reply With Quote
Old 04-24-2012, 09:19 PM   #17
Tinkermc
I am wanting to do the same thing with my 67. So you have me hooked, I be here until the end. Looks good so far
Tinkermc is offline   Reply With Quote
Old 07-01-2012, 12:51 PM   #18
polock07
Polock07
having an issues getting door to line up, decided to use a cab top to get the roof right inside and outside, but having an issue lining up the gap between the door and windshield, if you can see it in the picture it looks like it starts then starts to go off at an angle. the original looks angled to me too. all the other gaps around the door look good, uniform through out and same measurements throughout. the angle is off by less than a half degree from the original angle so i'm at a loss on how to get that upper corner down to fit and get the gap aligned?
