Old 12-24-2011, 01:25 PM   #101
scotts72heavyhalf
scotts72heavyhalf's Avatar
Re: How about some pics of Static Dropped C-10's
5/7 ECE drop with disc conversion, 245/45/20`s all around a few pics and now in the midst of our frame off, but sticking to the static drop.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 12-29-2011, 09:45 AM   #102
hairlesshobo
hairlesshobo's Avatar
Originally Posted by therapy View Post
Spindles and springs up front flip kit in the rear
Hey therapy, how much drop is this in the front and rear? You mentioned spindles and springs up front but didn't say how much each was. I really like the looks of your truck!
Do you have any other pics of your truck by chance? I would love to see the front and rear suspension up close.
Great job!
Shawty: '84 C10 Silverado SWB, 700r4, SBC 350 - 4 bolt main, bored 60 over w/ Weiand aluminum intake and moderate cam, 2" true dual exhaust, Thrush mufflers, 3.42:1 gears -- Build Thread
The Tranny (wrecked ): '86 Trans Am, SBC 350 (now in above truck), Borg-Warner T-5, 2" true dual, Thrush mufflers, 2.73:1 gears
hairlesshobo is offline   Reply With Quote
Old 12-29-2011, 09:34 PM   #103
therapy
therapy's Avatar
Great job!
I dont have any suspension pics..Has 2 inch spindles,2 inch springs with a coil cut.. Rear is a flip kit I believe that is like 5 and then the over load removed placed on top to dearch the spring to give it even more drop. Has drop shocks on all 4 corners and and a min c in the rear frame rails..This is now my Daily/Project cause I got rid of the other square got a 50 model and now got rid of that.....Im now in the process of buying everything to bag the daily grind..
therapy is offline   Reply With Quote
Old 12-29-2011, 10:06 PM   #104
Hart_Rod
Hart_Rod's Avatar
5/8 drop... Front: 3" springs, 2" spindle, Rear: 6" springs, 2" block....
Hart_Rod is offline   Reply With Quote
Old 12-29-2011, 10:39 PM   #105
mongoose
mongoose's Avatar
front; 3" spring, 3" spindle, 245/40/20
rear; flip kit, 285/35/20
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-02-2012, 01:03 AM   #106
stealth_weapons
Here's mine; 63 C10 front- CPP 3in drop springs,POL Tubular UCA/LCA, 2.5in drop spindles rear-4in CPP drop springs
and underneath;
the Stealth Weapons 63 project, all comments, advice, and critiques welcome!
http://67-72chevytrucks.com/vboard/s...d.php?t=438235
stealth_weapons is offline   Reply With Quote
Old 01-03-2012, 04:12 PM   #107
snacks
snacks's Avatar
front ece drop spindle 3'' springs 215/70/15=5.5'' drop
rear leaf sprung flip kit,1'' block,leaf removed 235/70/15= 8'' drop
bed floor over rear end raised and frame mini notched
custom made rear shock mounts upper and lower truck rides so good
snacks is offline   Reply With Quote
Old 01-03-2012, 04:31 PM   #108
shawno72
C/10 junkie
shawno72's Avatar
Hey snacks do you have any pics of the mini notch and the rest of the underneath?? BTW your just about 45 minutes north of me.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-03-2012, 04:40 PM   #109
snacks
snacks's Avatar
next time i pull the bed off ill take some pics, your truck in your avatar is sick is it bagged , one of the best looking ones iv seen
Old 01-03-2012, 04:48 PM   #110
shawno72
C/10 junkie
shawno72's Avatar
Not yet... photoshopped for motivation. Will be doing a bag set up later on this year.... if all goes well.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-03-2012, 05:02 PM   #111
snacks
snacks's Avatar
do you do all your own work(welding and fab) if not we can hook up i can help you out if needed
Old 01-03-2012, 05:21 PM   #112
shawno72
C/10 junkie
shawno72's Avatar
Actually I do all my own work, certified welder, used to do iron work til the economy took a dive. Now I manage the Midas Auto Service in Lodi. Still might get ahold of you for some help, thanks I appreciate that. Hey what would you charge to install a cnotch like you have?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-03-2012, 05:22 PM   #113
shawno72
C/10 junkie
shawno72's Avatar
Hey Hart_Rod are those 5 or 6 lug wheels?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-03-2012, 05:27 PM   #114
snacks
snacks's Avatar
cool man i help run a speedee oil change in roseville, the notch i have is one of those pre fabed cpp notches that i welded in , if you drove down here we could do it in an afternoon ,pull the bed ,cut the frame , weld it in, beer and food on you haha
Old 01-03-2012, 05:52 PM   #115
shawno72
C/10 junkie
shawno72's Avatar
Sounds good. I'll let you know, thanks.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-03-2012, 05:58 PM   #116
cory d
cory d's Avatar
flipped and 1 1/2 coils cut off
cory d is offline   Reply With Quote
Old 01-03-2012, 06:03 PM   #117
shawno72
C/10 junkie
shawno72's Avatar
Welcome aboard Cory. You are on the best forum on the web!!
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-03-2012, 06:04 PM   #118
OC 72
OC 72's Avatar
The trucks on this last page sure have nice stance!
OC 72 is offline   Reply With Quote
Old 01-03-2012, 06:05 PM   #119
cory d
cory d's Avatar
thanks, ive been a member of c10forum for a while now but this gets allot more traffic
Old 01-03-2012, 06:09 PM   #120
shawno72
C/10 junkie
shawno72's Avatar
Here is how mine looks today.
And here is how I want it to look by the end of the year I still have the stock steelies and will put them back on when I bag it.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-15-2012, 12:59 PM   #121
creativecustoms
Re: static drop pics
Originally Posted by TxSqueeze View Post
Here's mine with a 5.5/7 and 20's
Where can I find these wheels? I've searched all over and can't find 20x10/5x5 anywhere
creativecustoms is offline   Reply With Quote
Old 01-15-2012, 06:29 PM   #122
bigsmitty75
Is there anyone out there can help me out with my dilemma. I have a '85 GMC SWB. 2WD that I'm currently restoring. I want to do a static drop on my truck. The wheels that I'm gonna run are a 24x9 with a 255/30/24 in the front and a 24x15 with a 405/25/24 in the rear. I don't want to bag my truck. Can some please help a brother out?
bigsmitty75 is offline   Reply With Quote
Old 01-15-2012, 07:25 PM   #123
Slammed66
Needs a Big Block
Slammed66's Avatar
What's the dilemma??
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 01-15-2012, 11:46 PM   #124
Narxoleptic Customs
Bigsmitty75:
R u going to have room to run a 15" wide rear wheel and not narrow the frame? If u don't have to narrow the rear frame: Just do a flip rear kit (5-7" drop) and 3" spindles and 2" coils for the front.
If u do have to narrow the rear frame: it sounds like u r in over ur head, find a shop close to u and pay them to do it...
Narxoleptic Customs is offline   Reply With Quote
Old 01-17-2012, 04:20 PM   #125
bigsmitty75
I am going to narrow my rear end in order to accommodate the 24x15 rim in the rear.
