#276 |
A day late and $1 short...
Re: Project "Just an Old Truck"
Thanks brother, I appreciate the good words! Now about that parachute...
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#277 | |
-Rus |
#278 |
A guy with a truck
Can't remember; did you do the trailing arm flip on this one? That will help correct pinion angle, too. Wheels are gonna look good!
![]() Posted via Mobile Device
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#279 |
C/10 junkie
I think your truck is gonna look great with those wheels!!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#280 | |
I agree 100%. This board is full of great people who are very helpful. If I need to know something, 99% of the time I can search this site and find it. If it's not there, you can ask a question and usually have it answered the same day. Pretty cool little online community that's been established here. Not to mention some of the very high profile trucks that have their builds posted here. Pretty cool. ![]()
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac |
#281 |
67cheby
![]() Join Date: Sep 2008
very nice work on the trans crossmember
#282 |
When I started the tail shaft was 5° down and the pinion was 0° (neutral), and the output shaft and the pinion gear were the same height from the ground. Right now I will have to estimate how much raising the tail shaft corrected the downward angle at the tail shaft, but lets say it is now 3° down. Having moved the tailshaft up 1" the output shaft should be 1" above the pinion gear, which opens the possibility of increasing the pinion angle (up). I have a choice here, I can install the 3.5° shims I borrowed from Hart_Rod or flip the trailing arm brackets. The shims are the easiest, and could provide a good test but depending on how many degrees it changes the pinion angle, moving the trailing arm bracket might be the better permanent fix. Does anyone know how many degrees the pinion angle changes by flipping the brackets? The other possible advantage to moving the brackets might help with is centering the wheel in the wheel well. So, I am going to try the shims next and then the flip if the shim help eliminate vibration. I will try and get numbers at each step so that we will know how the flip affects the pinion angle.
#283 | |
#284 |
Tot Roddin'
And I'm just 20-25 from his 90.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#285 |
Wheels got here today! But the rears don't fit... wrong backspace. Seems like the website that says they make a 5" bs is wrong so I was sent 5.5"bs. I am working with the guys at Old School Wheel on a fix. The fix (spacers) will be temporary until I build the longer rear end I have. Crappy pics in the garage...
#286 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Wheels look good.
Sorry about Coys shipping out the wrong BS.
#287 |
Yessss!!!!!! So nice!
-Rus |
#288 |
That's a bummer about the rears, but it still looks awesome!
Got any info on plugging the tank filler hole in the cab? That's on my to-do list... Posted via Mobile Device
#289 |
Looks great! So you are driving out to St.Louis?
Justin |
#290 |
Ran thru your build might have missed it but whose fuel tank did you use? considering moving mine under the bed too.
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#291 |
Tot Roddin'
Love it!
#292 | ||
I appreciate your restraint as I know you have more to say...
Thanks! Quote:
Thanks, I wasn't sure how I'd like them but I knew I wanted to do something different. And, besides the fact that they don't fit, I love them too! ![]()
#293 |
Can't wait to see it backed out in the open!
Justin |
#294 |
![]() Join Date: Dec 2006
Wheels look great on your truck, sorry to hear about the bs mistake. Can't say I'm shocked, they did the same thing to me and told me to run a spacer if it bothered me. Eventhough their customer service sucks they do have some very nice wheels as seen on your truck.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#295 | |
#296 |
With the help of some spacers I borrowed from Hart_Rod I was able to get the wheels off of the bed sides. I don't want to run spacers permanently, and I really like these wheels so I am going to start collecting parts to rebuild the 70-72 rear end I have sitting in the corner. The one thing that swapping the rear end won't fix is the placement of the wheel in the wheel well. Since I lowered it the rear wheels are too far back in the opening. Does anyone know if flipping the trailing arm brackets will correct this? Please let me know if you have any info on this. Measurement pics I took...
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 12-12-2012 at 12:40 AM. |
#297 |
Pics... Gonna have to do something about the drums and the exhaust, whew that is UGLY!
#298 |
C/10 junkie
Wheels look great. Big wheels = big view
#299 |
I wonder if you could run a Porterbuilt tubular trailing arm crossmember,... and position it 1" forward?
How much do you think it is off? hot trux has a set of 1.5" lowering blocks on his truck,... and that kinda helps kick the rearend forward.
#300 |
Shhh... Be quiet.. Do you hear that? What's that sound behind you?
Oh it's the sound of a snow ball effect starting to roll. Lol. Rear disc, new exhaust lay out, just a little bit lower.... Next thing you know ![]() Lol Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
