Old 11-11-2014, 10:42 PM   #476
nlped
nlped's Avatar
Re: Project: Shiro
Awesome. Glad you're back on it.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-11-2014, 10:45 PM   #477
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project: Shiro
Originally Posted by Hart_Rod View Post
Nice progress! Sorry I couldn't make it over today.
Thanks brutha! No worries about today, but there is bed removal and some sheet metal repair in your future.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 11-12-2014, 08:58 AM   #478
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Shiro
Very nice progress Buck.
Old 11-12-2014, 09:07 AM   #479
Hart_Rod
Hart_Rod's Avatar
Re: Project: Shiro
Sounds like a plan.
Hart_Rod is offline   Reply With Quote
Old 11-12-2014, 09:41 AM   #480
Rusbuilt
Rusbuilt's Avatar
Re: Project: Shiro
Looking good sir!
Rusbuilt is offline   Reply With Quote
Old 11-12-2014, 09:49 AM   #481
C10_ustacould
Re: Project: Shiro
Sounds like a plan.
Originally Posted by Rusbuilt View Post
Looking good sir!
Thank you gentlemen, I look to get the front fenders off tonight. And anything beyond that will be be gravy.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-12-2014, 01:39 PM   #482
track70
track70's Avatar
Re: Project: Shiro
Looking good..need any help with the heavy lifting..Let me know..I'm only a hop skip away and i won't be like Rob and not show up LOL j/k
TRACK70 BUILD -> http://67-72chevytrucks.com/vboard/s...d.php?t=589761
King's Speed Shop
track70 is offline   Reply With Quote
Old 11-12-2014, 09:50 PM   #483
C10_ustacould
Re: Project: Shiro
Progress for the night...
"Rust free" California sheet metal...
Stopping point for the night.
I think I'll tackle the heater box tomorrow after work.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-12-2014, 10:04 PM   #484
Hart_Rod
Hart_Rod's Avatar
Re: Project: Shiro
"Hidden rust".....
Old 11-13-2014, 10:09 PM   #485
C10_ustacould
Re: Project: Shiro
Tonight's progress and findings...
So the forward cab mount bolts are tack welded, weird or common?
Floors are pitted pretty bad, thinking I may need to replace them. Mike (mcbassin), are you sure you don't want to move to Florida? We could use your skillzzzzz!
These are the strange holes in the passenger side toe board. I think they were for the A/C, easy fix, just thought I'd share
And finally the progress. Nothing cosmic, mostly pulled bumper brackets and such, then pulled the outside portion of the heater box.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-16-2014, 03:02 AM   #486
smbrouss70
smbrouss70's Avatar
Re: Project: Shiro
The welds on the cab mount bolts is common. They were there to make sure the bolts didn't push up and out when they set the cab on the frame at the factory. The rear bolts go up from the bottom so obviously they weren't welded. On the Blazers all 10 bolts were welded from the factory... lots of cutting to change body mounts.
Those floors aren't that bad. It looks like it was scaley rust that was de-scaled and painted. I would trust those floors over replacement sheetmetal, but I have recently come to the conclusion that re-pop parts SUCK. So, I might be biased.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 11-17-2014, 06:59 AM   #487
C10_ustacould
Re: Project: Shiro
Thanks for the info on the mount bolts Steve, I just thought it was odd because it makes it tough to change the body bushing if they fail. As far as the floors go the pits are very deep. I imagine that if you hit them with a blaster you would have Swiss cheese. I am building this truck for longevity so I am going to give them a very close look once I get the rest of the interior out and move on from there.
Didn't get any work done on the actual truck this weekend but I did get the cab and bed dollies made.
Now I just need to gather the man power to put the cab and bed on them!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-17-2014, 09:05 AM   #488
Bennett68C10
Bennett68C10's Avatar
Re: Project: Shiro
Looking good Buck, your making good progress and nice job on the dollies. I'll be following along closely for the LS1 swap
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 11-17-2014, 09:29 AM   #489
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Shiro
Nice progress on your truck Buck. Yep you will need a small cutoff wheel or dremel to cut that pesky welded bolt. I have taken a bunch of cabs off these model trucks, they are always like that from GM. Do you have an engine hoist/cherry picker on wheels? You can manhandle the cab by yourself if you have a decent one. You just need to make a bar or board to go across the inside of your cab. If you're like me it can be hard to get 3 helpers in the shop at one time.... Good luck.
Nice dollies btw.
Old 11-17-2014, 10:50 AM   #490
C10_ustacould
Re: Project: Shiro
Thanks Keith, the swap will be a mixture of what I did on the '68 and some of the things Hart_Rod has learned over the last year. The big things will be the use of a BP Automotive harness, manifilds instead of headers, and I think I will give a go at building the exhaust myself.
Nice dollies btw.
Thanks Mike, I have some worn out discs I think will work on those bolts. I though about buying the plans for LFD's cab lift, but I think I'll just use human power.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-17-2014, 11:19 PM   #491
Bennett68C10
Re: Project: Shiro
If you don't mind me asking, what's the reason for running manifolds instead of headers? Clearance issue with the dropmember of did you have an issue with the headers on your stepper?
Keith
66 Suburban
IG: bennett68c10
Old 11-22-2014, 04:58 PM   #492
C10_ustacould
Re: Project: Shiro
Today's progress...
The bed on the dolly I built.
This frame needs some Porterbuilt love...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-22-2014, 05:47 PM   #493
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Re: Project: Shiro
Today's progress...
Attachment 1327475
Attachment 1327476
Nice progress ..... !
ksbrktracer is offline   Reply With Quote
Old 11-22-2014, 07:05 PM   #494
nlped
nlped's Avatar
Re: Project: Shiro
Excellent to see progress...
Carter
Old 11-24-2014, 12:34 AM   #495
C10_ustacould
Re: Project: Shiro
I feel like I've been run over by a truck! But I'm relieved we were able to get a lot done this weekend. Here is today's progress...
Here is my youngest son removing the drive shaft. He hung out with me for two days working on Shiro, good times.
Engine removed, we also removed the exhaust, all the shocks, the glove box, the inside portion of the heater box, and the high hump! Good bit of progress...
Anyone need a 250 I6? Previous owner claimed it had 41,730 miles when I bought it and I've put about 1500-2000 miles on it over the last year. I'm not really sure about the mile at this point...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-24-2014, 01:41 AM   #496
Malamute
Malamute's Avatar
Re: Project: Shiro
Well Ernie, I just read your thread from start to finish before going to bed tonight. I'm not sure how I've missed it but I haven't been on here much either. What a roller coaster ride you guys have been through on this.
I can't wait to see the progress and final product. You and your son are going to have a lot of great memories(and a few, "remember that time?")when this is all done.
Malamute is offline   Reply With Quote
Old 11-29-2014, 02:16 AM   #497
C10_ustacould
Re: Project: Shiro
More progress today, we removed the seat, carpet, steering column, insulation, some wiring, fuel tank, fuel lines, and the front cab mount bolts. The cab mount bolts didn't go very well due to the "tack" welds the factory puts on them...
Here you can see the difference in how the cab mount bolts came out. As soon as I started trying to remove it a crack formed immediately.
Beginning to look a little sparse...
Another angle
Fuel tank removed
Fuel tank in the yard!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-29-2014, 09:39 AM   #498
duallyjams
duallyjams's Avatar
Re: Project: Shiro
Tear down is always quick and easy and fun.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-29-2014, 12:23 PM   #499
C10_ustacould
Re: Project: Shiro
My body doesn't agree with it being quick and easy!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-29-2014, 09:33 PM   #500
SeTx67
SeTx67's Avatar
Re: Project: Shiro
Nice progress buck. Been a while since I checked in so you're doing a ls1 now?
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
