08-17-2017, 04:59 PM | #1 |
Lowest static drop, Who has it ?
Who has the lowest static drop? It can be bolt on,body drop or anything else just as long as it's static. Shortest distance between the rocker and the ground.
08-17-2017, 07:29 PM | #2 |
Re: Lowest static drop, Who has it ?
Torsion bars and 3" of travel before hitting inner fenders. Rear was baged now all air.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-17-2017, 08:40 PM | #3 |
very nice did you use stock spindle or a drop spindle ? torsion bars Rule !!! thx Hop
Save a tree support your local drag strip !!! |
08-17-2017, 09:42 PM | #4 |
Just bars no bumpstops right before Portebuilt swap. I would tell all to keep the bars. Cost to rebuild now less than when I got the new on the sceen PB. For 60-62 frame.
08-18-2017, 09:45 AM | #5 |
08-18-2017, 11:12 AM | #6 |
I'm running a CPP Grand Slam kit and a 2" block in the rear. Lowest part of my rocker is at 6" off the ground. Bottom of control arms are a different story lol..... 2.5"
08-18-2017, 11:50 AM | #7 |
5.5/7 drop
08-18-2017, 12:17 PM | #8 |
I had about 1.5" before the front tire would hit the inner fender. Had to take one of the inner fender bolts out to keep it from shredding the tire.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
08-18-2017, 12:48 PM | #9 |
Moderator
And that is the weak spot for lowering unless you can modify the front fender area.
08-18-2017, 12:55 PM | #10 |
May be a little smaller tire?
08-18-2017, 01:06 PM | #11 |
The crossmember was too low already, a smaller tire would make it even lower.
08-19-2017, 06:20 PM | #12 |
Measured the rocker on mine and it's 8" off the ground
08-19-2017, 08:14 PM | #13 |
8-3/4 bumper anf cab mount 235/60/15 or park on wet grass
08-23-2017, 01:37 AM | #14 |
When I bought my truck the front crossmember was about 2 inches from the ground.
08-23-2017, 10:52 AM | #15 |
So if you slam the truck, the front inner fender is what hits first?
How is the clearance on the rear with a 5-7" drop in rear?
It's what you learn After you know it all that counts! |
08-23-2017, 03:44 PM | #16 | |
I never had any rear clearance isssues at a 6-7" drop in the rear with a small pipe notch. Lower than that, the pumpkin hits the bed floor before the axle tubes hit the frame (with a notch), so at that point you'll need to raise the bed floor and do a step notch.
08-23-2017, 04:16 PM | #17 |
There a picture of my truck post number 7 it's 5-7 drop
08-27-2017, 12:18 PM | #18 |
ive done a 7/ 6 1/2 on my 65
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 |
08-27-2017, 12:41 PM | #19 |
Do you bottom out at all in the front?
