Old 04-18-2018, 06:12 PM   #1
rcranger
Finishing Static drop
When is low to low finishing up the suspension doing static drop, have to stay in what budget , kind of surprised how low this turned out have done several 67-72 but first time for this gen, have 4.5 inches at cross member in Upstate NY this is marginal with heaved roads and potholes going to give it a try see how goes
rcranger is offline   Reply With Quote
Old 04-18-2018, 07:38 PM   #2
raidmagic
raidmagic's Avatar
Re: Finishing Static drop
Looks good to me.
raidmagic is offline   Reply With Quote
Old 04-18-2018, 07:44 PM   #3
tinydb84
tinydb84's Avatar
4.5 at the cross member gives you about 2.5 at the LCA. That's too low for me.
David
Instagram: myfabguy
Old 04-18-2018, 07:57 PM   #4
PGSigns
PGSigns's Avatar
There is still 300 pounds to go on that truck. It will be bottoming out. Whats in it for parts on the drop.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-18-2018, 09:30 PM   #5
rcranger
The 4.5 was with 2 guys on the front rails have 2.5 front drop spindles I coil off front springs drop rear springs with all parts including manual dual master and proportioning valve rotors bearings seals calipers hoses pads and misc pieces have $425 all in don't think that is to bad for all new parts
Old 04-18-2018, 09:51 PM   #6
CousinTone
I see you have gone with a crate engine. Good choice. Ride height looks good.
CousinTone is offline   Reply With Quote
Old 04-18-2018, 10:37 PM   #7
rcranger
haha on the crate , weather has been crappy here snowed yesterday says some for tommorow have car in garage on lift that needs work so covered engine dont want to leave outside but no choice for couple days , on the engine though found a 307 bored .40 over done top to bottom balanced nice cam only run to break cam in ,and a th350 all rebuilt 2200 stall convertor and shift kit have $1000 all together, low buck not a ls motor want a good driver go to some shows but not to show because we use them
Old 04-19-2018, 08:49 AM   #8
hewittca
hewittca's Avatar
Ride height is lookin' good. How much suspension travel do you have before the inner fenders bottom out on the tires? I'm fighting this issue on my '68 right now. I am in the process of putting it all together and will have 2" of travel before my fenders bottom out. I'm thinking I need to remove the inner fenders and possibly modify the fenders for more clearance. Maybe even relocate the hood hinges.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 04-19-2018, 12:04 PM   #9
theastronaut
theastronaut's Avatar
I ran my '66 with 215/75-15's up front and had about 1.5" of travel before it hit the inner fenders. The crossmember/LCA's would occasionally bottom out over really rough spots. Go with a stiffer gas shock to help it from bottoming out as easily. Mine still rode as good as stock with relocated KYB Gas-A-Just shocks up front.
theastronaut is offline   Reply With Quote
Old 04-22-2018, 08:34 PM   #10
BeardedCowboy87
BeardedCowboy87's Avatar
Looks great! What size drop is this?
BeardedCowboy87 is offline   Reply With Quote
Old 04-22-2018, 08:44 PM   #11
theastronaut
Thanks! 2.5" spindles with 1.5 coils cut off the original springs up front, rear had 1.5" drop blocks and I bought the springs used so I'm not sure the exact drop amount. They were supposed to be 5" but I'm pretty sure they were only 3 or 4". There's a ~220 pound crate in the bed in that pic, so go with 5" springs and 2" blocks to match that look.
Old 04-22-2018, 09:01 PM   #12
BeardedCowboy87
Thanks! I just installed 4” CPP springs and shocks on all 4 corners of my ‘65. I’d really like to get another inch or so up front. What would you suggest? I still have drum brakes on all 4 as well. Would you cut a half inch out of the front springs to get another inch? Here are a few photos of mine attached.
Old 04-22-2018, 09:11 PM   #13
BeardedCowboy87
Old 04-22-2018, 11:34 PM   #14
Hollow65
Hollow65's Avatar
Ece 4/6 drop
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 04-22-2018, 11:42 PM   #15
theastronaut
If you're already on 4" springs you'd probably want to go to dropped spindles next. You're just about at the point of running out of travel if you go any lower with springs. Do you have the bump stop brackets cut off already? If you just installed the springs then drive around on them a bit, some say they'll settle.
Old 04-23-2018, 12:12 AM   #16
BeardedCowboy87
I have the rubber bump stops cut off but I have not removed the brackets yet. I have seen where some people cut the factory springs to lower it 5 1/2”.. that’s why I was thinking maybe I could cut half inch out of my 4” drop springs to get another inch out of it.. i think if I did that and removed my bump stop brackets I would have plenty of travel and not bottom out.
Old 04-23-2018, 12:13 AM   #17
BeardedCowboy87
Also, I have had the springs on for about a week or two.
Old 04-23-2018, 11:30 AM   #18
rvrfoot
rvrfoot is offline   Reply With Quote
Old 04-23-2018, 12:58 PM   #19
BeardedCowboy87
Originally Posted by rvrfoot View Post
That looks sick! What size drop?
Old 04-23-2018, 02:42 PM   #20
rvrfoot
5 inch up front. 7 in the rear. 18 inch wheels.
Old 04-23-2018, 06:23 PM   #21
BeardedCowboy87
Awesome, man! Looks great! Need to see more pics of this truck
