Door fitment
Howdy! I recently ordered some doors from KeyParts. I found that the doors were not similar in dimensions. The drivers side door had a 2 3/8 inch gap between the bolt and the flange. The passenger side had a 2 1/2 gap between the bolt and the flange. This effected the hinge placement, and the door alignment. Has anyone else had this problem? Where could I buy some quality repop doors that won't cause a headache?
Re: Door fitment
Passenger side door |
Re: Door fitment
Driver side door |
![]() ![]() Join Date: May 2015
Re: Door fitment
Sounds like the same ol repop song and dance....
That's why everyone says use OEM whenever possible...
![]() Join Date: Feb 2014
Re: Door fitment
You have more than that much adjustment in your hinges, you may not find any that are any better, your going to adjust them to fit your openings any way
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
Re: Door fitment
I originally bought repop for both doors, but ended up going to the local Classic pick a part to get OEM doors, as the fit on the repop are all over the map. My repop pass door fit good, but even it had a gap (where you place the felt and rubber wiper strips) that was 1/4" larger than expected for the door glass. The drivers side repop door was soo bad that I ended up scrapping it.....Repop = many hours of fabrication work.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi 1997 C2500 Ext Cab 5.7 Liter 1955 3/4 ton 1st series w/ 235 straight six Sold it ![]() |
![]() Join Date: Dec 2012
Re: Door fitment
I assembled my truck together from all original GM sheet metal and to get the gaps tight like I wanted I still had to open up the holes in the hinges to put the doors where I wanted.
There was some adjustment but still not enough. Like I said it was all GM parts. If you have to use aftermarket you have to just assume you will have to alter/adjust in places where you normally would not have to. Good luck.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Re: Door fitment
Found a great place in Cameron Tx. Has tons of OEM parts! around 10-50 selections for almost any C10 part or piece. Found a great set of OEM doors that are practically flawless besides mirror holes.
Re: Door fitment
Place is called Greens repair & restoration
Almost Satisfied
![]() Join Date: Mar 2002
Re: Door fitment
I just purchased a new door from Classic Parts. The door fits pretty well, but when I installed my new cab corners I matched them to the OEM door I thought I was going to use. Now I have a bigger gap at the bottom of the door than I would prefer. I continue to adjust and I am getting close, but not sure I like the width of the gap. In fairness, the OEM door fit just as poorly when I started with it.
But, when I picked up my door from Classic they told me that if I didn't like the fit to bring it back and we would try another. I'm close to them so that is an option. Shipping would kill you I would guess.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
![]() Join Date: Aug 2015
Re: Door fitment
You could weld a wire to the edge and then taper it for a nice even gap.
Re: Door fitment
Works well 1/8 in tig wire
#13 | |
Almost Satisfied
Re: Door fitment
Re: Door fitment
Right here in paint and body work look back through the thread’s I believe it was called fitment of aftermarket parts I did the same thing to my truck but do not have pictures but basically you take 1/8 welding wire and tack weld it to the edge of the door and when you’re done you file it down until you have the gap you want on my original doors there were some areas it took two wires where I put the new skins on actually fit a little better
#15 |
Re: Door fitment
Here's a topic I made about using 1/8" welding rod to even out panel gaps.
http://67-72chevytrucks.com/vboard/s...d.php?t=497761
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Tags |
door alignment, doors, key parts, key parts 72 door |
