10-16-2019, 06:40 PM | #1 |
any recommendations on brightening the dash lights?
i need to brighten up the dash lights in my 66 c10 i have read up on many ideas. more power, leds, ect but i need to get a recent education on this subject. i am looking to go brighter but non blinding bright.
any responses is appreciated. thx dave
1971 K5 CST Blazer 1951 -3100 5 window short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
10-17-2019, 06:39 AM | #2 |
Re: any recommendations on brightening the dash lights?
I use the Sylvania long life bulbs in my dash with 1816's for the dash and 1895's for the turn signals and the indicators ( i use the tandem lock for my TC lockup light). Seems to be good as far as brightness. I am going to do a dash for my old C20 soon and it will get led equivalents to see how it works.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-17-2019, 07:42 AM | #3 |
Another trick might be to paint inside the light "tunnel" with bright paint (silver, white, or chrome paint).
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-17-2019, 08:27 AM | #4 |
I used green LEDs in mine..
I bought them from https://www.superbrightleds.com/ The bulbs I bought were 6 green, and one red. They also have white if you prefer. The red was just for the headlight "BRIGHT". |
10-17-2019, 02:34 PM | #5 |
I experimented with white and green LEDs along with a green and white cluster interior. I wound up using green LEDs and a white interior.
Of course, the brightness desired is always a personal preference, but I used a PWM dimmer and find myself dimming it a little. Roll the Dice's cluster is pretty much a good representation of what mine loooks like. |
10-17-2019, 03:41 PM | #6 |
Moderator
Clean up your grounds also.
10-18-2019, 06:09 PM | #7 |
white LED's. You can't dim them. I didn't put them in to dim them.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
10-18-2019, 06:57 PM | #8 |
An LED dimmer, (Pulse Width Modulator), will. I used the unused choke knob location for the control.
10-21-2019, 07:35 PM | #9 |
Who Changed This?
If you use a headlight relay kit to brighten up the headlights, that will brighten up your dash lights with all that load removed. ALL my running lights got brighter, too. You can compare that here-
https://67-72chevytrucks.com/vboard/...d.php?t=782071
10-22-2019, 05:52 PM | #10 |
Chevy addict
What part number LED bulb did you guys use ?
10-22-2019, 06:05 PM | #11 |
I've found that fresh stock bulbs are very adequate, to the point of needing to dim them so the cluster lighting isn't more intense than the headlights even with upgraded Cibie H4 headlights. You want your headlights to be the brightest/most intense lighting so your eyes can adjust to how the road is illuminated, not the brightness of the gauges. I haven't tried them but I imagine LEDs will be much more intense than the headlights, so I've stayed away from them for that reason.
Long life bulbs usually have less lumens so stay away from those. I tried aluminum tape in the light tubes to brighten those lights up, but that only works for the intermittently illuminated tubes- the high beam indicator stays on too long when driving back roads. The tape doesn't allow enough heat dissipation so it burns the gel. Having smoke coming from the cluster late at night isn't fun...
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 10-22-2019 at 06:12 PM. |
10-22-2019, 06:14 PM | #12 |
I posted which ones I used above in post 4...click on green or red in that post...hope that helps.
10-22-2019, 06:49 PM | #13 | ||
Now the shift indicator was way too bright. I had to disable, (destroy), all the LEDs except for one to get it to match the cluster. |
10-22-2019, 07:14 PM | #14 |
Coloring them with a black Sharpie dims them down.
