06-19-2016, 10:18 PM | #276 |
Re: Project Beatrix
This picture helps a ton. Thank you!
06-21-2016, 07:53 AM | #277 |
Re: Project Beatrix
No problem at all. Hopefully I will see my new motor mounts from Nate soon and have my driveline set up shortly after. If you have any additional questions feel free to ask.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
06-21-2016, 08:19 AM | #278 |
Re: Project Beatrix
Looking good Brandon. So did you need to modify anything else on the inner fenders besides just using ratchet straps to hold them into place?
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
06-21-2016, 09:30 AM | #279 | |
Re: Project Beatrix
I have two issues. First is the stress on the wheel wells and the possibility of them cracking after some road time, and the second is cutting up the edge of my 67 hood. After posting on Kyles build thread and confirming these 2 issues, they may be going back to Curt. We will see how this plays out i guess.
06-21-2016, 10:03 AM | #280 | |
Re: Project Beatrix
06-21-2016, 04:15 PM | #281 |
Re: Project Beatrix
Don't rush into them. I am looking into having these done in either plastic or stamped in steel. I will have more details in a week or so.
06-21-2016, 04:32 PM | #282 |
Re: Project Beatrix
No problem, I don't need them anytime soon so I wouldn't be ordering for a while anyway!
07-11-2016, 08:50 AM | #283 |
Re: Project Beatrix
Finally got some more done on the truck. Had a 3" 2 piece shaft made that turned out really nice. Also got some of the firewall shaved and started working on getting the outer rockers installed.
07-11-2016, 08:53 AM | #284 |
Re: Project Beatrix
Also got the new motor mounts from Nate and they dropped the engine down about an inch and a half. so i am hoping my intake will clear the stock hood now!
07-12-2016, 11:20 AM | #285 |
Still Learning
Re: Project Beatrix
Drive line looks incredible Brandon! It's a shame to cover all that hard work up....
You don't have a picture like that for a one piece drive shaft do you? I feel like my pinion angle may be off a little in my truck. Very nice work on the cab too. Keep it up bro |
07-12-2016, 12:54 PM | #286 | |
Re: Project Beatrix
As for a 1 piece shaft, they are way simpler. The angles should be equal and opposite. Example: 2 down at the trans, 2 up at the pinion. A degree of angle at minimum in a 1 piece and try to not exceed 3 degrees. Just text me if you need more info.
07-12-2016, 03:38 PM | #287 |
Re: Project Beatrix
Nice looking Driveshaft Brandon! I'll be looking to get one made soon myself!
07-12-2016, 05:14 PM | #288 |
6>8 Plugless........
Re: Project Beatrix
That is a really nice drive shaft. The heater delete work looks great too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-12-2016, 07:33 PM | #289 |
Re: Project Beatrix
Super nice!! Keep the updates coming
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
07-13-2016, 07:44 AM | #290 | ||
Re: Project Beatrix
Still working on smoothing these filler panels out and patching the holes in the firewall that are not needed.
07-13-2016, 08:08 AM | #291 |
Re: Project Beatrix
Smoothing theses firewalls is a pile of work but it's definitely worth the effort. Yours is looking great!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
07-16-2016, 12:44 PM | #292 |
Re: Project Beatrix
Ready to see the cab on ! I still have my fingers crossed for the 80e clearance SO it's hard for me to do any work of my own lol.
07-18-2016, 07:40 AM | #293 | |
Re: Project Beatrix
The transmission actually fits to my amazement. I thought for sure I would have to clearance the opening at the rear quite a bit for the tailshaft but I will only make a little room for piece of mind. As for the wheel wells, the driver side actually fit pretty good. I still had to put a little force on them with straps but nowhere near as much as the passenger side. Now I have to figure out how to make these twins fit!!!! Slowly but surely it is starting to look like a truck again. Plan this week is to continue with the metal work and make a bracket for my air tank and compressors.
07-18-2016, 08:09 AM | #294 |
Still Learning
Re: Project Beatrix
Looks great Brandon!
07-18-2016, 09:13 AM | #295 |
Re: Project Beatrix
Looking good Brandon, glad to see that 4L80 fit without anymore modification!
07-18-2016, 09:48 AM | #296 |
Re: Project Beatrix
Thanks Mike
Same here Keith, I was a little nervous when I started setting the cab down but it actually fits like it was meant to be there!
07-18-2016, 10:16 AM | #297 | |
Re: Project Beatrix
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-18-2016, 10:21 AM | #298 | |
Re: Project Beatrix
07-20-2016, 07:37 AM | #299 |
Re: Project Beatrix
Here are a few more pictures of the truck currently. Working on raising the bed floor, working on the body and building manifolds for the turbos.
07-20-2016, 08:00 AM | #300 |
Still Learning
Re: Project Beatrix
