02-12-2009, 04:54 PM | #326 | |
Spanked once
Re: project INCREDIBLE HULK 6.2L with 6L80E
Thanks again BTW the Gen 2 is cable less also
The ole 350 budget build. |
02-12-2009, 05:07 PM | #327 |
killer had a gen IV and down in louisiana it worked gr8!
R.I.P. Killer 71 10/26/07 |
02-15-2009, 08:44 PM | #328 |
getting this thread back to the top.....got some new custom made moser axles (they are a great co. to do business with) they are really short and fit awsome.....
also i cut up the new ART arms, so they'ld fit the new V3 DM design...and bolted up the uppers arms too....next week ill get the rack installed and hopefully have the steering linkage hooked up too... here are the pics |
02-15-2009, 09:40 PM | #329 |
That looks pretty sweet..........
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-15-2009, 11:10 PM | #330 |
PROJECT 7DEUCE
Front cross member looks killer..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-16-2009, 12:52 AM | #331 |
looking good, gotta love the look of the short axles just means wide rubber, it also looks tlikethe two of us got some frontt suspension put together, way to go.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
02-16-2009, 09:46 AM | #332 |
Mr. Thread Killer
Looking good. How about a wide angle shot of how far along everything is just to put the project into perspective.
Any updates on the gauges? Interior? |
02-16-2009, 04:43 PM | #333 |
True Addiction
Looks GREAT! What are you doing for Brakes?
RCC |
02-16-2009, 10:40 PM | #334 |
02-16-2009, 11:32 PM | #335 |
True Addiction
68 Short Step,
I was wondering because I have a narrowed 9" moser out back as well. I can't decide what I want to run. Great Build!!!
RCC |
02-22-2009, 10:28 AM | #336 |
got the front of the frame notched for the rack.... the rack fits fine, but the low mount alt. hits the the steering part of the rack...so a adaptor bracket is gonna be made to locate the alt. out and clocked at about 20* so it'll fit without hitting anything.....
02-22-2009, 10:30 AM | #337 |
also if anyone wants to know how these builds go with parts comeing in almost everyday, this is about 2weeks of boxes stacked up, and most of the boxes have boxed inside ......
02-22-2009, 10:46 AM | #338 |
Man, looks like it's gonna be a chore routing the steering linkage from the column to the steering box!
02-22-2009, 03:08 PM | #339 |
its gonna be about a 45* angle from the steering column to the rack, the manufacture says that 65* or less is fine, so we should be fine
02-22-2009, 03:25 PM | #340 |
Formerly- 1972SuperCheyenne
Looking killer. What rack are you using?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-23-2009, 09:57 PM | #341 |
This looks about like my corner in my friends shop where all my stuff is, except I have a set of wheels and tires in the stack too.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver Last edited by babyblueoval; 02-23-2009 at 10:26 PM. |
02-24-2009, 02:56 AM | #342 |
Restoring a 68 SWB
Can you tell me a little about how you did your notch? What size pipe, etc. I bought a bolt on notch but thinking of sending it back and doing this instead. I was thinking of boxing the inner frame for strength. Do you think it needs it?
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 02-24-2009 at 02:57 AM. |
02-24-2009, 10:21 PM | #343 | |
as for boxing the frame there, it cant hurt.....do i think its strong enough and safe without boxing it, yes...... |
02-25-2009, 02:00 AM | #344 |
Good lookin build their 68 short step
bondo bob http://s424.photobucket.com/albums/p...albumview=grid <<<link to my stuff and project 68 step side build |
03-14-2009, 10:54 PM | #345 |
ok, i got the new alt bracket fabbed up....it spaces the alt out about 1 5/16" and clocks it 20* to clear the rack......also had to remove the ear off the alt. (since it was clocked)... also got some new sheetmetal hung, the fit on the front fender is good (little hole enlargeing, to get proper gaps), and the door is decent.....it will require a bit more massaging, welding, and cutting (more on this later).....but it cames with the aftermarket panels, i guess.....
also got some bed panels in too....the rear cross sills are polished stainless steal (still have the protective film on in the pics tho) and the bedsides are original ones (from the boys at stoked out in rockwall TX) the one center cross sill (goes between the tires) is too long ,do to the rear end being narrowed, so it will need to be trimmed.....also the bed wood will need to be raised a bit to clear the rearend houseing, and the tubs widened, but that was planned on anyways.....here are a few pics... |
03-14-2009, 10:54 PM | #346 |
03-15-2009, 12:06 AM | #347 |
Lookin good!
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
03-15-2009, 01:26 AM | #348 |
Under Construction
nice work Don!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-15-2009, 10:53 AM | #349 |
PROJECT 7DEUCE
B!tchin...
03-15-2009, 10:59 AM | #350 |
