Old 01-15-2011, 07:10 PM   #326
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Originally Posted by Rokcrln View Post
Here are a few parts coming your way! I made yours out of 18ga then added a few beads into it for looks and rigidity. They will mail out Tuesday.
Kevin
LFD Inc.
Nice!
I am pulling your parts right now.
Will mail them Monday.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 01-15-2011, 09:53 PM   #327
swamp rat
swamp rat's Avatar
Originally Posted by drewskiren View Post
Thanks to everyone who follows along and takes time to comment.
I'm in the engineering jigsaw puzzle phase!
Still cant figure out how to multable quote replies like that, but you can add me to the list too.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-15-2011, 10:24 PM   #328
drewskiren
drewskiren's Avatar
Originally Posted by swamp rat View Post
Don't ya just hate it when ya cut on the wrong side of the line!!
Tell me more about the blue stuff in the drip rail (also looks like its on the front passenger side below the window) is it seam sealer or some kind of special drip rail filler? Thanks! The roof has made some real progress too, when i first saw the pick showing the different slopes i was about mortafide.. over my head..
I cannot beleve he didn't put some kinda reserve on it! Musta been really hurtin for cash.. Good score! I'd give up all 3 of my rollaways and top chests for that.
Its not too hard, I just poked around til I found it.
There is a button right next to the quote button. It has a quote icon with a plus mark, stands for multiquote. Click it and all the others you want and then click on the normal post reply button.
Drew
Old 01-15-2011, 10:45 PM   #329
swamp rat
swamp rat's Avatar
Ok thanks..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-17-2011, 10:39 PM   #330
drewskiren
drewskiren's Avatar
More slow go because of Denali work. White front cap painted green to fix green yukon into a Denali. Frame bent gray one donating its interior to the black theft job to be sold on Ebay. Most other parts off the white crispy critter have been sold, gray parts are next to be sold.
Be back on the real project this week.
Drew
Old 01-17-2011, 10:49 PM   #331
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Have fun. That is a nice change of pace and a great way to get parts, like you already know.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-17-2011, 10:51 PM   #332
classicchev
classicchev's Avatar
I need some heat control switches, Im sure you have the front and rear switches. Tan trim would be great.
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 01-17-2011, 11:15 PM   #333
drewskiren
drewskiren's Avatar
Darren
Call me to discuss what you are asking for. 901-864-1726
Drew
Old 01-17-2011, 11:18 PM   #334
67chevy1series
67chevy1series's Avatar
wow i would definatly say you are the king of denalis!!!
67chevy1series is offline   Reply With Quote
Old 01-18-2011, 12:33 AM   #335
classicchev
The seat heat control switch that is in the front doors, and I think the rear seat controls are in the rear of the console.
Darrne
Old 01-18-2011, 01:50 AM   #336
drewskiren
drewskiren's Avatar
Darrne
Oh, sorry I was thinking HVAC controls. I don't have any rear ones, but I do have the fronts. They are black, not tan or gray.
Drew
Old 01-18-2011, 02:24 AM   #337
classicchev
Do you have 4, and if so how much??
Darrn
Old 01-19-2011, 08:30 PM   #338
drewskiren
drewskiren's Avatar
OK, Need a little help with my old body on late model frame. I am measuring where my body height is and need some confirmation. I currently show 19 inches from the top of my sill/rocker to the ground. This is a good hard edge to measure from. Open your truck door and measure from level ground to the opening of the door - top of the sill or top of the "rocker". That first hard edge that the outer rocker firsts starts to roll into the door jamb. This is an easier measuring spot than somewhere on the curve of the rocker or the bottom pinch weld that varies somewhat. Follow me?
I have no weight on my suspension now and it will drop 3 inches with everything installed. (I measured another new truck). What distance is there on a stock truck? If a stock truck has rake measure at the front of the rocker near the fender. What distance do other people have with lowered trucks? Please list how much drop you have to help me convert the results.
Drew
Old 01-19-2011, 08:37 PM   #339
swamp rat
swamp rat's Avatar
>scratching head< Well maybe some pictures may help? part of the problem may be having the weight of the truck off the tires too?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-19-2011, 09:00 PM   #340
jbclassix
Junk Yartist
jbclassix's Avatar
after reading your post twice I think what you are looking for is body height off the ground? If you are here some points...
body height effects powertrain clearance
body height determines how the truck looks overall
body height effects center of gravity
If you have the engine/tranny I would get them on the frame.
get a set of wheels on (pref the height of the tire you want to run).
mount your front fenders on your cab
set your cab over your frame
center your front wheels in the fenders
set your bed over the frame
use the denali screw jacks to pos the body where it looks good to YOU...
since you are not using a stock frame and building your own custom body mounts the choice is yours. this will also give you a good point to determine your rear axle CL in the wheel wells. Did i ramble or am i way off?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-19-2011, 09:02 PM   #341
jbclassix
Junk Yartist
jbclassix's Avatar
basically what I am saying is you may just want to mock the body over the frame to get it set where YOU want it
-Jeremy
Rebuilding an NP205
Old 01-19-2011, 11:03 PM   #342
Hart_Rod
Hart_Rod's Avatar
Drew,
I measured 12" at the front of the rocker and 13" at the rear. I'm running a 28" front tire and a 31" rear tire. I have a 5" drop in the front and a 7" drop in the rear. Hope this helps let me know if you need any other measurements.
R/
Hart_Rod is offline   Reply With Quote
Old 01-19-2011, 11:35 PM   #343
drewskiren
drewskiren's Avatar
Something like THIS ?????
We had to drop the frame to the ground to get the lift to clear the bedsides over the rail.
Drew
Old 01-19-2011, 11:37 PM   #344
67chevy1series
over here i think they call that ridin cali
Old 01-19-2011, 11:41 PM   #345
Dieselwrencher
Drew, I'm not trying to be hypocritical, but it looks like the cab could go back some more to get the front tire centered in the wheel well. Maybe about 1-1 1/2" or so.
Ryan
Old 01-19-2011, 11:42 PM   #346
drewskiren
drewskiren's Avatar
Again it is just sitting there, but it looks like my calculations were spot on with channeling every bit of the cross bracing off of the bed to drop the bed down to meet the cab that rides on rubber mounts. I would still love to figure out if this will be normal ride height for cab of a stock 72 pickup. I won't really know until I load everything onto the frame and see where it settles out.
Drew
Old 01-19-2011, 11:43 PM   #347
hgs_notes
GEARHEAD
hgs_notes's Avatar
I have 14-1/8" front, 14-3/8" rear on mine. It is basically stock with 3-1/2" drop springs all around. Running 235/70-15s front and 275/60-15s rear tires. There are a few things in the bed, but no glass or interior, so I'm guessing it will drop some once it's re-assembled.
hgs_notes is offline   Reply With Quote
Old 01-19-2011, 11:47 PM   #348
drewskiren
drewskiren's Avatar
Yeah, the cab slid a little in all the fighting. It is just sitting on the frame, I'm still afraid to commit.
Drew
Old 01-19-2011, 11:52 PM   #349
lolife99
67-72 parts collector,…
lolife99's Avatar
Instead of channeling all the bed cross bracing,... why don't you just raise the bed floor?
(1"-3")
Keith
Convert to disc brakes.
Old 01-20-2011, 12:03 AM   #350
drewskiren
drewskiren's Avatar
Originally Posted by Hart_Rod View Post
Drew,
R/
Thanks Rob!! Thanks HGS-notes??? !!
If you extrapolate both of your information, ya'lls measurements are within a half inch of each other. This makes me more sure of the numbers. More to compare would really solidify if anyone else wants to whip out a tape measure.
Using these 2 trucks, I have a hunch I am about a half inch higher than a stock 1972 truck. Not bad at all, but of course I was hoping to be lower before doing my bags and drop.
Thanks again to both of you spending a little time on my behalf. Let me know if I can ever do the same.
Drew
