Old 12-26-2012, 02:12 PM   #376
theastronaut
theastronaut's Avatar
Re: Project Goldilocks, '66 C10 SWB BBW Build
Hope everyone had a very Merry Christmas!! The engine mounts came today and they were better than I expected them to be! Thick 1/4" plate for the plate and tabs and the edges were scalloped for weight reduction too. Nice grade 8 hardware and the steel sleeve for the bushings fit tight around the bolt. The holes in the tabs for the mounting bolt is a tight fit too- no play at all. Very nice kit!
theastronaut is offline   Reply With Quote
Old 12-26-2012, 10:36 PM   #377
El Campo
El Campo's Avatar
Those are very nice looking!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 12-29-2012, 10:58 PM   #378
Desert.Chevy
Desert.Chevy's Avatar
Those look good!
How about a picture of the truck.
Desert.Chevy is offline   Reply With Quote
Old 12-31-2012, 06:36 PM   #379
theastronaut
Originally Posted by Desert.Chevy View Post
Those look good!
The truck is apart but there's pics of the pieces on the first page. It'll be awhile before it's a truck again!
Old 01-01-2013, 09:38 PM   #380
theastronaut
I started cutting up the Chevrolet script valve cover to see if I could reshape the ends to match the flange of a LSx cylinder head. I cut the whole flange off and made a few relief cuts, then hamered one corner into a rounded shape. Once I had the shape like I wanted it I aligned the weld seams, welded the seams, then ground/sanded them smooth. Just a start to see if it would work; I want to shorten the whole cover atleast an inch and maybe make the ends more rounded at top corners like an original LS cover is.
They'll get painted the original '66 327 color and have the original 327 decals on them.
Old 01-01-2013, 10:44 PM   #381
plainred65
plainred65's Avatar
Those valve covers look like they'll be a nice touch!
plainred65 is offline   Reply With Quote
Old 01-01-2013, 10:50 PM   #382
pdxhall
pdxhall's Avatar
I really like the valve cover idea. Great work.
pdxhall is offline   Reply With Quote
Old 01-02-2013, 09:59 AM   #383
aggie91
I'm just glad to be here!
aggie91's Avatar
I really like the Valve Cover idea. Are the gen1 valve covers the same length as the LS ones?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-02-2013, 12:49 PM   #384
theastronaut
Thanks!
There is about 1/16" difference in length, measuring from the outside of the flanges. The Gen 1 covers are 3/8" wider, measuring from the outside of the flanges. I'll have to make a new steel flanges for the reshaped covers and if possible I'll weld tabs/drill/tap holes into the valve cover sealing area on the LS heads to accept the Gen 1 perimeter bolt pattern. Not sure if I'll be able to use an LS style O-ring seal (have to machine a groove in the flange) or just use cork gaskets.
Old 01-02-2013, 03:40 PM   #385
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Love the subtle touch the valve covers will have on that motor. Nice metal work.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-02-2013, 10:58 PM   #386
66redw/white
made in america
66redw/white's Avatar
you, my friend, do fantastic work
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 01-02-2013, 11:29 PM   #387
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Just a heads up....the '98 LS1's had the perimeter bolt pattern. don't know the casting numbers tho.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-02-2013, 11:47 PM   #388
theastronaut
Thanks a lot!!
Thanks for that info, I'll look into those for ideas on mounting my covers. I'll eventually use LS3 heads which have center bolts.
Old 01-14-2013, 03:17 PM   #389
theastronaut
I've been working on restoring the cluster that I'll be using in Goldilocks and it's nearly finished. Just waiting on Jason to finish up the reprinted lens.
Originally Posted by duallyjams View Post
I think you should do a step by step write up on the cluster for the fact section.
Ask and ye shall recieve...
http://67-72chevytrucks.com/vboard/s...d.php?t=559922
Old 01-14-2013, 04:35 PM   #390
likaroc13
Rollin' Old Skool
beautiful work man...gotta love the attention to detail!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-15-2013, 12:02 PM   #391
theastronaut
Finished shaping the other side of the first end. It wasn't as easy as I thought it would be to match the shape to the first corner! Also need to find another cover to have a pair.
Old 01-15-2013, 11:17 PM   #392
65Custom
nice work on the Valve cover I like the idea, think I might have to steal your idea and use it on mine if I ever get that far, that will make that 5.3 almost look like it was there from 65, a nice idea. as always great work.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 02-02-2013, 10:02 PM   #393
theastronaut
I cleaned out a shed we have behind our shop so I could mock up the 5.3/T56 without having to tear it apart and move it out of the shop during the week to make room for customer cars. I moved the frame back there today and I'll get the cab moved up here from the house and set it on the frame to check for firewall and floor clearance.
OCD kicked in again on the gauge cluster and I ended up polishing the bulb holders with 0000 steel wool and metal polish.
I also wrapped the tach harness with cloth friction tape to match the cluster harness. Even tied one end so it looks factory.
And I'm working on a deal for a NOS in the box four speed shift knob. I haven't told the guy I'm buying it from that the numbers will be smoothed off and re-stamped with the six speed pattern... Just said that I'm building a truck and trying to keep the details correct. Didn't want him to back out for fear of NOS parts getting mutilated.
Old 02-02-2013, 10:17 PM   #394
greg65
greg65's Avatar
Sweet looking oval.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 02-02-2013, 10:22 PM   #395
theastronaut
Originally Posted by greg65 View Post
Sweet looking oval.
Thanks, that's my Dad's- he's had it about ten years. Still has a 36 hp, original oval brakes, non syncro first trans, and bias ply tires. I fully understand the "Drive 55, arrive alive" saying back then; it's a wild ride with 1" wide brake shoes and squirmy tires!!
Old 02-02-2013, 10:38 PM   #396
likaroc13
Rollin' Old Skool
Sweet looking oval.
x2....and great job with the cluster...I don't think anyone on the board has anymore attention to detail than you!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-02-2013, 10:38 PM   #397
theastronaut
Off topic, but if you're wondering what the two "tricycles" in the shed are, they're drift trikes. The rear tires are sleeved with PVC tubing for decreased grip so they slide through corners. I build the green one from a 20" mountain bike last year. I'm going to add decals from a John Deere pedal tractor to complete the look.
Youtube vide of these things in action.
Old 02-02-2013, 10:53 PM   #398
likaroc13
Rollin' Old Skool
Youtube video of these things in action.
wow, I completely overlooked the trikes...those are cool...but the dudes in the video are crazy! I'd be wearing more protective gear than they were...and bare feet
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-02-2013, 11:00 PM   #399
theastronaut
Oh we do wear shoes or at least flip flops. And we don't have hills like that so we don't get up as much speed so it's not as crazy as they make it look.
Old 02-02-2013, 11:26 PM   #400
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Crazy detail and those trikes are wild.
Alan's Classic is offline   Reply With Quote
