Old 02-13-2012, 09:37 PM   #26
mooseknuckles
mooseknuckles's Avatar
Re: PSI Conversions
well I won't be needing that then....thanks man.
mooseknuckles is offline   Reply With Quote
Old 02-16-2012, 07:20 PM   #27
terrylgreenjr
Re: PSI Conversions
which part number did you order from them? I just ordered mine too Im pumped
terrylgreenjr is offline   Reply With Quote
Old 02-16-2012, 07:27 PM   #28
mooseknuckles
Re: PSI Conversions
I don't know, I talked to Jon through emails and told him what I had (lq4/4l80e) and thats what he had sent....
Old 02-16-2012, 07:43 PM   #29
terrylgreenjr
Re: PSI Conversions
I've got a 4L60 so mine will be a little different I guess
Old 02-16-2012, 08:03 PM   #30
mooseknuckles
Re: PSI Conversions
a little, and $25 cheaper...
Old 02-16-2012, 10:18 PM   #31
52 Rat
52 Rat's Avatar
Re: PSI Conversions
I installed my PSI harness this past weekend. The quality is better that OE and the customer service is awesome. Jon did a great job on my stand alone harness. I went with PSI because of the good reviews over at LS1tech.com.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 02-16-2012, 11:33 PM   #32
Kim57
Kim57's Avatar
Re: PSI Conversions
I talked to Jon yesterday. My harness is supposed to be here early next week.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-19-2012, 03:11 AM   #33
19seventeeCustom
Re: PSI Conversions
I ordered mine friday, and forgot to ask if it came with a
diagnostic port, but it looks like it does, according to the pics???
19seventeeCustom is offline   Reply With Quote
Old 02-19-2012, 10:31 AM   #34
52 Rat
52 Rat's Avatar
Re: PSI Conversions
Yes, it does.
Old 02-19-2012, 11:01 AM   #35
mooseknuckles
Re: PSI Conversions
yep it's there..
Old 02-19-2012, 11:09 AM   #36
Jonboy
Slots go on anything!
Re: PSI Conversions
Does that harness put the PCM and fusebox in the cab?
1974 Jimmy- 5.3/4L80e/NP241
Old 02-19-2012, 11:21 AM   #37
Kim57
Kim57's Avatar
Re: PSI Conversions
When I talked to Jon he said all their harnesses are 4' to 5' from the back of the engine.
He also said if they were any longer you could have trouble with a voltage drop.
I'm hoping I can get mine under my seat but will settle for it being in the cab.
Kim
My build thread
Old 02-19-2012, 11:23 AM   #38
mooseknuckles
Re: PSI Conversions
yep....should have enough wire to get it in behind the dash somewhere.....
Old 02-22-2012, 11:54 AM   #39
terrylgreenjr
Re: PSI Conversions
Got my harness today Looks great. Its getting started this weekend for sure
Old 02-22-2012, 04:40 PM   #40
terrylgreenjr
Re: PSI Conversions
Where is the best looking place to drill the hole for the harness to pass into cab? I want it to look clean not just like a random hole drilled
Old 02-22-2012, 04:48 PM   #41
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: PSI Conversions
are you keeping your deluxe heat? the one that hangs on the PS firewall.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-22-2012, 04:49 PM   #42
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: PSI Conversions
I like where Dennis put his on "Silver" in his build thread. It is right behind the block/intake in the center of the firewall.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-22-2012, 05:02 PM   #43
terrylgreenjr
Re: PSI Conversions
One day I'd like to go with a under dash unit and get rid of the big box in the engine compartment That's later on though
Old 02-22-2012, 06:44 PM   #44
Clyde65
Clyde65's Avatar
Re: PSI Conversions
Terry, you talking about the heater? I am in the middle of using the old heater under the hood for a cold air, I havent gotten far since I seem to not have any time for nothing
Clyde65
Rebuild of Clyde
support our troops!
Old 02-22-2012, 06:46 PM   #45
mooseknuckles
Re: PSI Conversions
center of firewall, just behind the intake is where mine is goin.....
Old 02-22-2012, 07:42 PM   #46
Kim57
Kim57's Avatar
Re: PSI Conversions
I got mine and it's a very nice piece.
Unfortunately I'm still quite a ways from getting mine started but hope to be there in a couple months.
Here's a pic.
Harness, new pedal, E38 computer, re-flashed TC, and a MAF sensor.
Kim
My build thread
Old 02-22-2012, 07:46 PM   #47
mooseknuckles
Re: PSI Conversions
nice!
Old 02-22-2012, 08:27 PM   #48
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: PSI Conversions
Have a very good look at where you will have space to store your PCM in the cab before you drill your hole...too far to either side might be too visible and you may run out of wire to the PCM but too far in the middle and you may not have room behind the block to run the harness through the firewall.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-22-2012, 11:53 PM   #49
19seventeeCustom
Re: PSI Conversions
got my psi harness in yesterday,, great looking piece, cant wait to install it.
im still wondering where to run the harness through the firewall also???
Old 02-23-2012, 06:53 AM   #50
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: PSI Conversions
Are you all getting the DBW pedal and TAC module from PSI as well?
I was thinking of mounting the battery on the driver side and mount the computer under it.... I think the fuse box ends up on the driver side....
Rich
1972 K5 Blazer CST Click HERE
