#477 |
A day late and $1 short...
Re: Project: Shiro
Thanks brutha! No worries about today, but there is bed removal and some sheet metal repair in your future.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 11-12-2014 at 09:05 AM. |
#478 |
Still Learning
Re: Project: Shiro
Very nice progress Buck.
#479 |
![]() Join Date: Apr 2005
Re: Project: Shiro
Sounds like a plan.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#480 |
Re: Project: Shiro
Looking good sir!
-Rus |
#481 |
Re: Project: Shiro
Thank you gentlemen, I look to get the front fenders off tonight. And anything beyond that will be be gravy.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#482 |
![]() Join Date: Jun 2013
Re: Project: Shiro
Looking good..need any help with the heavy lifting..Let me know..I'm only a hop skip away and i won't be like Rob and not show up LOL j/k
TRACK70 BUILD -> http://67-72chevytrucks.com/vboard/s...d.php?t=589761 King's Speed Shop |
#483 |
Re: Project: Shiro
Progress for the night...
"Rust free" California sheet metal... ![]() Stopping point for the night. I think I'll tackle the heater box tomorrow after work.
#484 |
Re: Project: Shiro
"Hidden rust".....
#485 |
Re: Project: Shiro
Tonight's progress and findings...
So the forward cab mount bolts are tack welded, weird or common? Floors are pitted pretty bad, thinking I may need to replace them. Mike (mcbassin), are you sure you don't want to move to Florida? We could use your skillzzzzz! These are the strange holes in the passenger side toe board. I think they were for the A/C, easy fix, just thought I'd share And finally the progress. Nothing cosmic, mostly pulled bumper brackets and such, then pulled the outside portion of the heater box.
#486 |
Re: Project: Shiro
The welds on the cab mount bolts is common. They were there to make sure the bolts didn't push up and out when they set the cab on the frame at the factory. The rear bolts go up from the bottom so obviously they weren't welded. On the Blazers all 10 bolts were welded from the factory... lots of cutting to change body mounts.
Those floors aren't that bad. It looks like it was scaley rust that was de-scaled and painted. I would trust those floors over replacement sheetmetal, but I have recently come to the conclusion that re-pop parts SUCK. So, I might be biased. ![]()
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#487 | |
Re: Project: Shiro
Didn't get any work done on the actual truck this weekend but I did get the cab and bed dollies made. Now I just need to gather the man power to put the cab and bed on them! ![]()
#488 |
![]() Join Date: Dec 2006
Re: Project: Shiro
Looking good Buck, your making good progress and nice job on the dollies. I'll be following along closely for the LS1 swap
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#489 |
Still Learning
Re: Project: Shiro
Nice progress on your truck Buck. Yep you will need a small cutoff wheel or dremel to cut that pesky welded bolt. I have taken a bunch of cabs off these model trucks, they are always like that from GM. Do you have an engine hoist/cherry picker on wheels? You can manhandle the cab by yourself if you have a decent one. You just need to make a bar or board to go across the inside of your cab. If you're like me it can be hard to get 3 helpers in the shop at one time.... Good luck.
Nice dollies btw. |
#490 | ||
Re: Project: Shiro
#491 | |
Re: Project: Shiro
#492 |
Re: Project: Shiro
Today's progress...
The bed on the dolly I built. This frame needs some Porterbuilt love... ![]()
#493 | |
TNT-MOTORSPORTS
Re: Project: Shiro
#495 |
Re: Project: Shiro
I feel like I've been run over by a truck! But I'm relieved we were able to get a lot done this weekend. Here is today's progress...
Here is my youngest son removing the drive shaft. He hung out with me for two days working on Shiro, good times. Engine removed, we also removed the exhaust, all the shocks, the glove box, the inside portion of the heater box, and the high hump! Good bit of progress... ![]() Anyone need a 250 I6? Previous owner claimed it had 41,730 miles when I bought it and I've put about 1500-2000 miles on it over the last year. I'm not really sure about the mile at this point... ![]()
#496 |
Re: Project: Shiro
Well Ernie, I just read your thread from start to finish before going to bed tonight. I'm not sure how I've missed it but I haven't been on here much either. What a roller coaster ride you guys have been through on this.
I can't wait to see the progress and final product. You and your son are going to have a lot of great memories(and a few, "remember that time?")when this is all done. |
#497 |
Re: Project: Shiro
More progress today, we removed the seat, carpet, steering column, insulation, some wiring, fuel tank, fuel lines, and the front cab mount bolts. The cab mount bolts didn't go very well due to the "tack" welds the factory puts on them...
![]() Here you can see the difference in how the cab mount bolts came out. As soon as I started trying to remove it a crack formed immediately. ![]() Beginning to look a little sparse... Another angle Fuel tank removed Fuel tank in the yard!!
#498 |
![]() Join Date: May 2007
Re: Project: Shiro
Tear down is always quick and easy and fun.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#499 |
Re: Project: Shiro
My body doesn't agree with it being quick and easy!
#500 |
![]() Join Date: May 2013
Re: Project: Shiro
Nice progress buck. Been a while since I checked in so you're doing a ls1 now?
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435 |
