03-23-2015, 09:51 AM | #651 |
Re: Project Roxy
So I bought these big fancy brakes from CPP. In trying to adjust them yesterday, I finally got fluid through the lines. However, I couldn't get the caliper to clamp the rotor in the front or rear. I bench bleed the M/C and had fluild coming out of all four calipers.
I noticed that I have a deep bore M/C that CPP provided in the kit and the booster has an adjustment to accomadate the bore. However, the pedal still goes to the floor and doesn't stop the rotor from spinning.. I'm stumped on this one..
///Relaxed Atmosphere |
03-23-2015, 10:15 AM | #652 |
Re: Project Roxy
You may have already looked at all of this, but I'll try to jog your memory or give some ideas where to look...
Are you sure the pedal is contacting the piston in the master? Sometimes there is a spacer required between the pedal pin and the master cylinder to engage them both. I think this might be your problem. It's possible to have the brakes bleed by gravity alone instead of pedal force. I assume you're using a vacuum booster, but if you are using hydro boost, make sure you've bled your power steering and don't have low fluid or frothy fluid (lots of air in the system). Are there any obstructions in your master preventing the fluid from leaving the reservoir? Maybe debris in the lines? Did you replace all of your brake lines or reuse factory stuff? What kind of proportioning valve do you have? Is it a factory style from these trucks, a newer factory style (typical upgrade in most disc kits), an adjustable valve only to the rears? Air can be trapped in a factory style unit. It's possible to bleed some of them, from what I've heard (never done it myself) but I've had air in my lines because of one of those types. At the time, I didn't have many brake tools so I had to have a mechanic pressure bleed my lines to get the last of the air out. These last items require the pedal to fully engage the master though, which it doesn't sound like is happening.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-23-2015, 10:23 AM | #653 |
Re: Project Roxy
There is an adjustable pin on the booster that is making contact with the bore on the M/C. and I am using a vacuum booster.
All the products are new, including the lines. I'm using a CPP disc/disc proportioning valve that came with the kit. I was going to do a gravity bleed and let it sit for a few hours, followed by a mechanical bleed.
03-23-2015, 12:16 PM | #654 | |
Re: Project Roxy
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-23-2015, 12:42 PM | #655 |
Re: Project Roxy
6772FRBK6-BB is the kit from CPP that I bought. It came with a deep bore M/C. However, after reading it appears that deep bore is for manual brakes only and not disc/disc.
03-23-2015, 03:57 PM | #656 |
Re: Project Roxy
I don't know for sure, but it seems like either you aren't getting full engagement from the pedal to the master or there's still a lot of air in the lines. Even if you booster was bad, you should still have some caliper movement with manual type brakes (just harder since you'd be fighting the booster). The only way I can see the calipers not moving would be due to the pedal and master not engaging completely, too much air in the system, blockage in the lines, or binding in the calipers. Or, the adjustment from the pedal to the booster isn't set correctly (pedal goes to floor before completely engaged with master cylinder).
Maybe I'm missing something, but that's all I can think of. I'll step out now and let someone else chime in.
03-23-2015, 04:03 PM | #657 |
Re: Project Roxy
Yea.. I figure it's one of those four issues.. I just have to hunt to find it. I ruled out blockage because I'm getting fluid to the caliper. However, it's not going threw with alot of pressure.
03-26-2015, 11:00 AM | #658 |
Re: Project Roxy
Did that kit come with a plastic syringe to help get the air out of the mastercylinder?
03-26-2015, 11:11 AM | #659 |
Re: Project Roxy
Some helpful articles:
http://www.classicperform.com/Instru...PDF/CP0105.pdf http://www.classicperform.com/TechBo...oubleshoot.htm http://www.classicperform.com/TechBook/BrakeBleed.htm
03-26-2015, 04:14 PM | #660 |
Re: Project Roxy
I did get some emails from CPP on things to try on narrowing the problems down. They suggested plugging the M/C to see if I get pedal. If I don't then, I know I have a booster/M/C issue..
Thanks for the links, Rob. I will give them a read later tonight.
03-28-2015, 09:50 PM | #661 |
Re: Project Roxy
So I spent the better part of 6 hours trying to get these brakes to work and I'm no farther ahead then I when I started. I gravity bled, vacuum bled and had the wife press the brake while I open/closed the bleeder.
I can't get the rear hose that goes into the caliper to stop leaking. Used different crushable washers and it still leaks. So if fluid is coming out air is getting in.. I'm totally frustrated with this truck at this point...
03-28-2015, 10:37 PM | #662 |
VA72C10
Re: Project Roxy
I understand the frustration. It can ruin your enthusiasm. The brakes on my shop truck build kept me from making it to a meet/show once with similar issues. Came down to a bad master cylinder and air getting in through old/weak rubber lines. Sounds like air is the issue here also at the caliper. Another CPP issue....
Looking for a 67-72 swb or blazer project in or around VA. |
03-29-2015, 10:13 AM | #663 |
Re: Project Roxy
It's a banjo-bolt connection at the caliper? What's the spotface look like at the port on the caliper? Is the tube hitting the caliper, keeping the hose end from coming down flat on the washers? Photo?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
03-29-2015, 11:45 AM | #664 |
Re: Project Roxy
It is a banjo bolt and the face on the caliper is not smooth. That's a good possibility that I never thought to check. I will give it a look when I get home.
03-29-2015, 11:53 AM | #665 |
67-72 parts collector,…
Re: Project Roxy
I understand your frustration with CPP parts.
I have made up my mind I will only use Wilwood M/C from now on. Aluminum body so they won't rust and a Super quality product. Also check the "free play" at your brake pedal, and make sure it's not excessive.
04-05-2015, 10:09 AM | #666 |
Re: Project Roxy
Well, I'm beyond my wits end with these brakes. So since it has to go to someone else to have the exhaust and pinion angles done, I'm going to have them fix the brakes too.
///Relaxed Atmosphere Last edited by Rochlow; 04-05-2015 at 10:21 AM. |
04-05-2015, 12:18 PM | #667 |
Re: Project Roxy
I went from a chrome master to a wilwood master made a huge difference also using a wilwood prop valve.
Jake
61 Ford uni http://67-72chevytrucks.com/vboard/s...d.php?t=623422 ryans 77 c10 http://67-72chevytrucks.com/vboard/s...d.php?t=626594 |
04-07-2015, 10:31 AM | #668 |
Re: Project Roxy
How did the frame paint hold up?
04-07-2015, 09:14 PM | #669 |
Re: Project Roxy
It's held up a lot better than I expected.
05-22-2015, 05:51 PM | #670 |
Re: Project Roxy
So I'm trying to figure out the driveline angles currently. My issue is the trans yoke is hitting the cab and the trans angle is already down 6 degrees. However, I had to get engine mounts from Porterbuilt that raised the motor a half inch because the oil pan was hitting the rack and pinion.
Has anyone else ran into this problem running a first generation small block and a th350 trans?
05-22-2015, 09:54 PM | #671 |
Re: Project Roxy
I really wanted to get this taken care this weekend. Left a phone message and sent emails, there were responses but no resolution.
05-23-2015, 12:15 AM | #672 |
Re: Project Roxy
Sorry man I know it's frustrating when your trying to wrap stuff up.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
05-23-2015, 02:34 AM | #673 |
Re: Project Roxy
cut the cab?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
05-23-2015, 07:51 AM | #674 | |
Re: Project Roxy
(or is it setting on the wheels at ride height?) My Ginger chassis had a first generation Dropmember in it and I was able to get it set at 5 degrees down.
05-23-2015, 08:23 AM | #675 | |
Re: Project Roxy
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-23-2015 at 08:29 AM. |
