#676 | |
Re: LFD's 4dr Tahoe Build
I was planning to add an additional bolt in the area directly under the bag to triangulate the fasteners. The rest of the plate would just rest on top of the 'shoulder' of the a-arm.
#677 | |
Kevin LFD Inc. |
#678 | |
#679 |
No progress but I did pick up a few new toys that will find their way into this build. Also here is a shot of the next customer build that will be rolling in as soon as the AccuAir is all installed in the Tahoe.
Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() |
#680 |
Life, Be In It.....
![]() Join Date: Oct 2003
Damm, I wish I did not have to spend so much time studying, because I would probably move into you shop. A few more months and it will all be over. PM sent to you about the pictures attached below
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 08-09-2009 at 02:13 PM. |
#681 |
We "Got Air" AccuAir to be exact! I have the first part of the system installed and working now I just need to mount and set all the ride height sensor's and this stage will be done until the body comes off. Here are just a few pics because I will be doing a full write up once it is all finished up and working.
But so far I have 8hrs into it start to finish and I was working at a semi relaxed pace. With the tanks empty it was less then 4 min for them to fill and sut off and I am running (2) 3 gal tanks. With the system filled and the vehicle laid out it went to all the way down to all the way up in under 3 seconds and the tanks were filled again in the 2 min. So right all lines are ran and hooked up but mounting is temporary until the body comes off so I can do it how I want with ease. Also all wiring is temp because their is no vehicle wiring in the Tahoe at this time. Also I have 10" of total lift!! Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() Last edited by Rokcrln; 08-09-2009 at 11:32 PM. |
#682 |
![]() Join Date: Apr 2005
That's dayum sweet!!!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#683 |
The leveling sensors pictured. Are those just simple single pole double throw switches from an electrical stand point? Eventually I want to do bags like on LoBuck, and those look like the cats meow for maintaining level.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#684 | |
No their are far from simple but I don't know how to properly explain how they work. They sense through the entire range of motion and will return your vehicle to any of your preset points on command with in about 1/8" every time! Keep a look out for my How-To install on AccuAir and I am sure the owners will chime in with tech info. Kevin LFD Inc. |
#685 |
Correct me if I'm wrong but they probably measure the difference in resistance(something like a fuel level sending unit) I think you can see them almost like a potential meter.
Looks like a nice set though, Is your engine already in the correct position? Looks like it sits under quite an angle.
Anybody can restore a classic, takes a man to cut one up..... http://www.arnoldscustoms.com Last edited by 38chevyhotrod; 08-10-2009 at 10:02 AM. |
#686 |
![]() Join Date: Aug 2005
Most of those level sensors I've seen are just linear potentiometers. Would be simple to rig something up from Radio Shack. The challenge is that you need a control unit with sensor inputs and firmware to use the signals and act accordingly. Plus I'm sure the sensors in the AccuAir kit are nicely sealed for exposure to the elements.
#687 |
man i just spent like 12 hours reading this whole thread. Your work is amazing cant wait to see more of what you have in store
#688 | |
![]() Kevin LFD Inc. |
#689 |
Small progress but progress all the same. I made the tabs to hold my front height sensors and tacked them in to make sure everything fit and the through was correct for the sensor travel. See even know my system has about 10" of lift the sensor can only see 2 3/4" during that full range of motion. Now that I know everything clears during full cycling and turning I will pull the brackets off and punch them out to follow the look I have started on all my other brackets.
Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() |
#690 |
Señor Member
#691 |
Yep I kept finding blue dust every were!
Kevin LFD Inc. |
#692 |
![]() Join Date: Nov 2008
Kevin, what are the plans for the 41-46 chevy? Can you tell us a little more about it? Thanks.
#693 |
I see. I did not realize that there were multi-height settings. Thanks.
#694 |
amazing work. thanks for the updates. keep them coming
#695 |
Kevin,
Movin right along! I might have to come by and check out the progress! *****Sales are limited to classified area and you must be a subscriber to initiate a post there.******Staff Edit Last edited by Palf70Step; 08-12-2009 at 05:02 AM. Reason: For sale |
#696 |
You know were I live! 4:30 +
Kevin LFD Inc. |
#697 |
Who's is this???
#698 |
Thanks kevin, makes sense now, yah that will work no problem, btw, looks great dropped down, but is the front 1/2 inch higher than the rear, may have to do some tinkering yet. Looks great none the less.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#699 |
I'M TRUCK CRAZY!
yeah, who's is that?
#700 | |
Kevin LFD Inc. |
