Old 06-12-2008, 03:01 PM   #51
PBFAB.COM
PBFAB.COM's Avatar
Re: Dropmember Rear 63-72 Spy Pic
Originally Posted by gringoloco View Post
Will the inner bridge cap be one piece? Would you have a problem towing with this setup?
What exactly do you mean by "inner bridge cap"?
As for towing... I would not recommend towing with frame that has been notched.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-12-2008, 03:09 PM   #52
gringoloco
A guy with a truck
gringoloco's Avatar
Disregard previous question. I'm an idiot.
Will the inner notch cap be one piece or two? It appears that the upper portion is left open- where the notch rests on the axle tube when aired out.
The two pieces here with the stubby little ratchet:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-12-2008, 03:50 PM   #53
PBFAB.COM
PBFAB.COM's Avatar
The notch pictured had not yet been "finished"... the bottom portion you are referring to is welded in as part of the notch, along with with the two top plates that bolt to the top side of the factory frame rails. Due to the contour of the chassis I use a factory frame as the "jig"... I will be cutting this frame in half shortly so my "jig" won't take up as much space!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-12-2008, 04:17 PM   #54
see ten
WTB this ad
see ten's Avatar
Sweet!
see ten is offline   Reply With Quote
Old 06-12-2008, 04:26 PM   #55
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Awesome!!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-12-2008, 04:44 PM   #56
SCOTI
SCOTI's Avatar
You're going to cut up that fine TX frame?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-12-2008, 10:49 PM   #57
PBFAB.COM
PBFAB.COM's Avatar
Due to the sentimental value of this particular "TX frame" I figured I would immortalize it and make it the fixture for the 63-72 Dropmember Rear!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-12-2008, 11:03 PM   #58
SCOTI
SCOTI's Avatar
I'm sure my neighbors miss it..... .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-12-2008, 11:30 PM   #59
yesman
great work like always. do you tig or mig when building the notch
yesman is offline   Reply With Quote
Old 06-13-2008, 12:04 AM   #60
PBFAB.COM
PBFAB.COM's Avatar
Thanks for the kind words. I use the MIG process on all the plate steel.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-13-2008, 11:41 AM   #61
jimmydean
jimmydean's Avatar
Wow, that's gorgeous Nate.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-14-2008, 10:03 AM   #62
royo
royo's Avatar
WOW great welds !!! Is there any reason this will not work on a lwb.
nickle and dime
royo is offline   Reply With Quote
Old 06-15-2008, 12:57 AM   #63
jasonb72
PorterBuilt Man Crush
Mine is a long bed, and I will be running it.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 06-15-2008, 10:07 AM   #64
royo
royo's Avatar
KOOL THANKS
nickle and dime
Old 06-23-2008, 03:34 PM   #65
royo
royo's Avatar
Ttt
nickle and dime
Old 06-23-2008, 05:57 PM   #66
Slmd92DIME
Slmd92DIME's Avatar
Lookin really good..... those are some very very nice welds...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 06-23-2008, 09:44 PM   #67
Hart_Rod
Hart_Rod's Avatar
Dang it! If I don't stop looking at this thread, I'm going to end up cutting a big hole in the rear of a perfectly good suburban...............
Hart_Rod is offline   Reply With Quote
Old 06-23-2008, 11:46 PM   #68
PBFAB.COM
PBFAB.COM's Avatar
one way to make a "perfectly good suburban" even BETTER!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-23-2008, 11:51 PM   #69
BACKYARD88
BACKYARD88's Avatar
-Mike Owen-
Old 06-24-2008, 01:39 AM   #70
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
+1
I think my personal feelings on the subject are no secret.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 06-24-2008, 12:40 PM   #71
gringoloco
A guy with a truck
gringoloco's Avatar
Worked for my ''perfectly good'' Blazer!
-Chris
Old 06-24-2008, 01:29 PM   #72
SCOTI
SCOTI's Avatar
Whaaaaa? Rear DM for the Blaze?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-24-2008, 03:59 PM   #73
gringoloco
A guy with a truck
gringoloco's Avatar
Nah. Don't count out the p/u though...
-Chris
Old 06-26-2008, 01:01 AM   #74
PBFAB.COM
PBFAB.COM's Avatar
Finally have it 99% buttoned up.
A couple changes include:
-Upper bag mount/bridge favors the 73-87 kit.
-Rear four-link bracket is a weld on piece. Sorry for all the guys hoping that this would be 100% bolt-on, as I had originally intended. In order to get the link bars as close to the chassis as possible (for larger tires) I found it necessary to remove the trailing arm perch fron the axle tube and weld the bracket in place. The bracket is a two piece design, one bracket welds to the axle tube, and the other bolts over it and incorporates the four-link mount, bag mount, and shock mount. I made it modular in order to have some flexibility for fine tuning it with rvarying ride heights and or shock combos.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-26-2008, 01:27 AM   #75
RunninLo
RunninLo's Avatar
I don't have any trouble setting pinion angle myself but, Will there be some sort of locator once the old perches are removed or will this be a get out the measurin' stick and angle finder type of set-up?
just curious cause the magnet on my angle guage fell off and broke the guage so I'll get another if need.
Josh
88 4x4 crew DD
