Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-21-2018, 02:40 PM   #51
04ls1gto
Re: Project Money green
Lots of elbow grease and the frames got a fresh coat of paint. Pulled all the old brake lines out and will be installing the SS ones I have this week. Next on the list is to prep and paint firewall.
04ls1gto is offline   Reply With Quote
Old 01-21-2018, 08:09 PM   #52
LockDoc
The Older Generation
LockDoc's Avatar
Lookin' good. Keep it up and before you know it you will be on the road.....
LockDoc
Leon
Old 01-21-2018, 08:26 PM   #53
04ls1gto
LockDoc
Thanks, try to keep progress rolling. This is way better then 3 months of rust replacement
Old 01-22-2018, 02:58 PM   #54
nastety92
Looking good man, you do nice work. Is your garage heated at home?
nastety92 is offline   Reply With Quote
Old 01-22-2018, 07:06 PM   #55
04ls1gto
Thanks, I built the garage probably 6 years ago. It's 24x30 with 11' ceilings, I insulated all the walls and ceiling and hung sheetrock which made a big difference. I have a small Bottle Dawg heater but if I leave it on 50 its fine. Natural gas is awsome my bill is usually 200 bucks for the whole winter
Old 02-18-2018, 06:35 PM   #56
04ls1gto
Lots and lots of scraping and sanding this morning. Need to patch a few holes and it's ready for primer. I really want to do vintage air setup to clean up firewall
Old 02-19-2018, 09:31 AM   #57
nastety92
Looking good almost there. Are you going to paint the engine bay black or green again?
Old 02-19-2018, 10:46 AM   #58
04ls1gto
Firewall is going to match green, picked up base clear for that. I have to paint the new inner fenders black and might do bottom of hood black as well because it's pretty rusty and the black will hide it better
Old 03-11-2018, 08:48 PM   #59
04ls1gto
Got some work done on the firewall and installed aeromotive stealth fuel pump in tank. My vintage air setup should be here Tuesday and Ill start welding in firewall plate. Hoping to test fit motor and trans this upcoming weekend.
Old 03-11-2018, 08:51 PM   #60
04ls1gto
More pics, also started mocking up Corvette fuel filter
Old 03-12-2018, 07:47 AM   #61
nastety92
Looking good. That is the setup he used in my truck as well. Corvette fuel filter with built in regulator. We went with an external pump though. Can't wait to see this truck this year. Hopefully we can meet up once the weather gets nicer and my truck is actually roadworthy.
Nick
Old 03-12-2018, 06:56 PM   #62
04ls1gto
Nick
My goal is having it on the road end of may. Not sure if I'm gonna make it but gonna give it he'll. Definitely have to meet up once we're on the road
Old 03-14-2018, 08:41 AM   #63
Hart_Rod
Hart_Rod's Avatar
Nice progress!
Hart_Rod is offline   Reply With Quote
Old 03-19-2018, 08:43 PM   #64
04ls1gto
Vintage air kit came in and very pleased with the quality. Welded in the firewall plate and body worked it. Finished prep on firewall and shot some epoxy primer. Next step is to test fit motor and trans
Old 04-01-2018, 09:12 AM   #65
04ls1gto
Motor is in and test fit went well. Stands are in forward position and speed engineering plates all the way back. Headers fit great, going to need a little clearance on the belhousing where starter mounts. Also looks like I'll be able to keep the low hump floor and just trim lip between firewall and floor. Making progress
Old 04-02-2018, 08:28 AM   #66
nastety92
Looks great, your making some good progress now. Must be a nice feeling when everything is finally test fit and you know all the parts work together.
Is the motor stock and is it going to stay that way?
Old 04-02-2018, 08:57 PM   #67
04ls1gto
Thanks, I upgraded to a 216/220 texas speed cam and PAC springs, trunion upgrade and new head gaskets. I wanted a mild cam as my gto has a good sized cam and driveability suffered a little. The 350 that was in the burb had maybe 175hp so the 6.0 should be much better. Excited to get the painting done and get on with putting back together
Old 04-04-2018, 10:08 AM   #68
Hart_Rod
Hart_Rod's Avatar
Looking good, .
Old 04-04-2018, 12:24 PM   #69
Duraburb
Duraburb's Avatar
sweet build! Looking forward to the progress!
1972 C20 Suburban, Bagged and c10 swapped Suspension (sold)
1969 Jimmy, 2wd swapped. bagged, body dropped
Duraburb is offline   Reply With Quote
Old 04-18-2018, 06:17 PM   #70
04ls1gto
Firewall is green now. I am by no means a body and paint guy, but I'm not afraid to try. Paint came out nice, I could have spent a lot more time on body work. I am very happy with results as it's my first time spraying base/ clear coat.
Old 04-18-2018, 08:56 PM   #71
Advanced Design
Advanced Design's Avatar
Came out nice. Good work!
Advanced Design is offline   Reply With Quote
Old 04-18-2018, 10:06 PM   #72
LockDoc
LockDoc's Avatar
Looks good. You can come and do mine now....
LockDoc
Leon
Old 05-20-2018, 04:48 PM   #73
04ls1gto
Been working on little things for the past few weekends. Got the brakes all back together and bleed, power steering lines are done. Harness is on and into cab of truck. Headers are on and I built a trans cross member this morning. Exhaust and get the front sheet metal back on is next
Old 05-21-2018, 07:59 AM   #74
nastety92
Looking great man, keep it up.
Old 06-03-2018, 08:51 PM   #75
04ls1gto
Looking like a truck again! Got the front sheet metal back on and installed cold case radiator and fan setup which was super easy. Drops right into the stock HD brackets and fits like a glove.
Third row seat brackets are done and installed, now I can install the fuel tank and lines for good.
