Closed Thread
Old 11-19-2009, 08:05 AM   #76
fatboys69
fatboys69's Avatar
Re: LFD's gas pedal adapters (71-72 gas pedals in 67-70's)
Got mine yesterday, THANKS !!!!
fatboys69 is offline
Old 11-19-2009, 08:49 AM   #77
lolife99
67-72 parts collector,…
lolife99's Avatar
Hmmm,... still waiting on mine to arrive. Hopefully today.
Keith
Convert to disc brakes.
lolife99 is offline
Old 11-19-2009, 11:41 AM   #78
jorgensensc
jorgensensc's Avatar
GOt Mine! Thanks! Looks fantastic with easy to follow directions!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline
Old 11-19-2009, 12:14 PM   #79
Rokcrln
Rokcrln's Avatar
Originally Posted by Hart_Rod View Post
Just showed up, ,
Rob double check your package for an extra shinny flat toy! Sorry guys I owed Rob a piece and used his shipping dime to deliver
Should be today but with a name like LoLife what did you really expect!
So for the most part our Post office still has what it takes. They did not go out (the second time) until mid morning Monday and most of you have them 2 days later. If you really think about what they charge for delivery and what that gets you it is amazing!
Kevin
LFD Inc.
Rokcrln is offline
Old 11-19-2009, 02:14 PM   #80
Woody
Just ordered one for my 69 !! PM sent with details...
Woody
Woody is offline
Old 11-19-2009, 06:20 PM   #81
lolife99
lolife99's Avatar
Got mine today.
Thanks Kevin!
Keith
lolife99 is offline
Old 11-19-2009, 10:01 PM   #82
Sinister
Between Trucks...
Sinister's Avatar
Just got mine, Thanks Kevin.
Beat it to fit,
Paint it to match...
Sinister is offline
Old 11-19-2009, 11:55 PM   #83
gcburdic
Restoration Virgin!
gcburdic's Avatar
Kevin....I hope this isn't a hijack of the thread, but maybe useful for a rookie like me wanting to install one of these....I have a quick question....I have a holley carb (not sure what cfm...could find any #'s on it)...is there anything special I need to hook up the cable to the throttle connection?? Can somebody direct me to what the connection looks like too???
Thanks...
Okay...nowback to the regularly scheduled programing....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline
Old 11-20-2009, 12:01 AM   #84
Rokcrln
Rokcrln's Avatar
Thanks...
I do not have the answer as everything I have is fuel Injected I am sure in the next few days we will start seeing installs and your question should be answered.
Kevin
LFD Inc.
Rokcrln is offline
Old 11-20-2009, 12:18 AM   #85
Hart_Rod
Hart_Rod's Avatar
Thanks...
Should be a ball stud. If you don't have one, you should be able to pick it up at a hardware store.
http://www.midwestcontrol.com/catdis...ort.php?pg=506
Hart_Rod is offline
Old 11-22-2009, 01:43 PM   #86
Sinister
Between Trucks...
Sinister's Avatar
Got to work on my pedal setup today. Going to use a Lokar throttle cable. First pic is factory pedal. 2nd pic is cut and welded to work with the Lokar cable. 3rd is with the cable installed. Had to weld up the factory hole for the throttle cable and redrill. Might redrill and put a plastic bushing in. If you use the Lokar cable you have to use their throttle cable bracket and kickdown setup.
Waiting on a part so I can install when I do my intake and carb.
Beat it to fit,
Sinister is offline
Old 11-30-2009, 03:10 PM   #87
fatboys69
fatboys69's Avatar
just tried "bolting" mine together with the pedal and plastic bracket and one of the tapped holes doesnt quite line up. Nothing I cant fix by opening up the hole in the plastic base and the sheetmetal retainer. Just an FYI
Old 11-30-2009, 04:02 PM   #88
67cheby
67cheby
67cheby's Avatar
this might sound stupid but i am a little confused if the peddle and cable dont come with it what am i buying ?? i dont see anything else ?? i am interested in switching my 67 over i am running a tbi 350, please tell me what i am overlooking , and can i get a cable to got to the tbi ??
67cheby is offline
Old 11-30-2009, 04:53 PM   #89
Rokcrln
Rokcrln's Avatar
Yes this was addressed in the directions with the same solution you came up with. I have 4 pedals and they all are just off of each other a bit so I made the bracket as close as I could to make all of them work. I found if you just start a few threads in each bolt they will start then tighten them all down. I will also go back and check my jig for good measure. Sorry if it was off a touch.
What you are buying is the adapter plate and hardware that bolts to the 67-70 cab then the 71-72 pedal bolts to that. You should be able to get a cable that will work with your TBI easily.
Kevin
LFD Inc.
Rokcrln is offline
Old 11-30-2009, 06:31 PM   #90
fatboys69
fatboys69's Avatar
hey NO PROBLEM !!!! I understand about having to tweek things. To many variables to take into consideration. Appreciate all the help.
Old 12-01-2009, 10:56 PM   #91
Bruce88
Bruce88's Avatar
Hi Kevin of (Lewis Fabrication Design)
I’ve already obtained one of your gas pedal conversion kits and thought you might like to see how I modified the installation instructions to a weld in installation. Thanks for putting a good conversion kit together. You can see my installation on my build post #189 http://67-72chevytrucks.com/vboard/s...45#post3650045
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline
Old 12-01-2009, 11:58 PM   #92
ripdog28
ripdog28's Avatar
I copied Sinister. quick cut and ran a bead. about 10 min tops.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline
Old 12-02-2009, 12:18 AM   #93
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Sinister....what did that Lokar setup cost ya?
Geoff with a G
gcburdic is offline
Old 12-02-2009, 12:22 AM   #94
Hart_Rod
Hart_Rod's Avatar
I was able to use the Lokar setup without cutting and welding the end on the pedal. Just remove the clevis on the end of their cable....
Hart_Rod is offline
Old 12-02-2009, 12:24 AM   #95
Rokcrln
Rokcrln's Avatar
Looks great! I to like the smooth look but I know their are a lot of guys with painted cabs that still need to swap over do to engine conversions or linkage bind or they just want the cable. So I am glad it worked for you and now others have a second way to do it if they want.
Kevin
LFD Inc.
Rokcrln is offline
Old 01-03-2010, 01:07 AM   #96
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
Got mine a while back and I'm finally getting around to playing with it.
I'm taking the cheap way out and modifying my existing '70 pedal assembly to work with the adapter.
I cut both ends off of the mid point in the fulcrum, flipped them and welded them back on. I had to take into account the fact that the adapter moves the bracket and pedal assembly a couple of inches to the left, so when I welded the ends back on I made sure to angle them inward. After double and triple checking the pedal falls right in the middle on one end and the other end that pulls on the throttle cable falls directly in line with my planned hole in the firewall.
All that was left was to chop off and rotate the very end of the rod where the cable passes through, turn it 90 degrees, drill and tap two new holes in the plate and cut the plastic rod retainer down on one end.
This is what I've got right now and so far the mock-up looks promising. I've still got to modify the pass through in the firewall, weld up some extra holes and try bolting it in place.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline
Old 01-03-2010, 01:32 AM   #97
Sinister
Between Trucks...
Sinister's Avatar
Sorry, I don't remember, DOH. I got it from Summit though.
Edit: Throttle cable was $42, throttle cable bracket was $24, Th400 kickdown switch/cable was around $90. They have kickdown cables for th350's as well.
Beat it to fit,
Sinister is offline
Old 02-18-2010, 08:08 PM   #98
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Will this mod work with 350/3ott what else will I need for the install besides cable? What're the advantages with 'locar' throttle cable? Thanks! Do you still have any of these left?
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 02-18-2010, 10:12 PM   #99
jbristo67
resident oilfield trash
jbristo67's Avatar
I did this exact same thing a long time ago. Putter had a big write up on it on here some where
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline
Old 03-06-2010, 10:08 PM   #100
Rokcrln
Rokcrln's Avatar
Yes I have about a dozen left. Two more are going out Monday.
Kevin
LFD Inc.
Rokcrln is offline
Closed Thread
