Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-18-2008, 04:21 PM   #101
19723DR
19723DR's Avatar
Re: 1972 3dr Suburban Build Thread
Progress on the door panels. I got some of the pieces cut out. I left some slots in the handle, top and bottom, to bolt through the panel and into the door. Here's what it will generally look like:
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 02-18-2008, 04:25 PM   #102
19723DR
19723DR's Avatar
Covered the pieces with vinyl and screwed them together. I made one more piece for the bottom to give it some contour so it wasn't just a flat panel.
97 Z71 3 Door
Old 02-18-2008, 04:33 PM   #103
19723DR
19723DR's Avatar
Here it is hanging there. I had to remove some more around the door handle to make it fit. It was just too thick.
I was lucky enough that I found a vinyl the same color as my seats. It's 2:00am and I am ready to crash and I still have 3 more to do. Saving those for another day.
97 Z71 3 Door
Old 02-19-2008, 07:46 PM   #104
nuke1
nuke1's Avatar
you are doin excellent work, i have an option for your door panels, to install them, go to your local body shop or fastener store and ask for trim panel clips,, they install with a slot in the back of the panel and then push into predrilled holes into the door itself, that is what i do, and to make the door panels look more subtle use 1/4 or 1/8 inch high density foam from a material place, to cover everything, you can cut it out and design it how you want, you have done a great job so far.theses are a few pics of what i did for my brother in law, he is 16 and Happy. Also to stretch the vinyl so you do not get any bubbles or kinks in it warm it up with a heat gun then stretch it over the item. My mom has taught me this, she is great with interiors.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-20-2008, 12:31 PM   #105
19723DR
19723DR's Avatar
Thanks for the info. I'm working on the trim panel clips. The problem I have is attaching them to the back of my panel and if one breaks off then I will need to replace it with a new one. The plan is to make a hole next to the location and then a slot that it slides over into to hold it in. I'll post pics later.
Nice job on that S-10. That looks sweet. You just gave me a really good idea for mine.
97 Z71 3 Door
Old 02-21-2008, 01:31 AM   #106
nuke1
nuke1's Avatar
glad i could help
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 02-21-2008, 03:11 AM   #107
Frizzle Fry
Frizzle Fry's Avatar
Well done! Maybe you should cover your kicks in the same vinyl to cut down on the number of shades you have goin.
Frizzle Fry is offline   Reply With Quote
Old 02-24-2008, 09:55 AM   #108
19723DR
19723DR's Avatar
Sorry, it took so long to answer. The kick panels I painted to test a darker color. All the things I am making I am going to cover in vinyl. Don't worry I am not color blind. Here's one of the rear panels:
97 Z71 3 Door
Old 02-24-2008, 10:00 AM   #109
19723DR
19723DR's Avatar
This we I have found a little time to work on my third-door panel. I made a few changes. I decided to recess the door panel into the first layer to hide the creases in the back of the door handle.
97 Z71 3 Door
Old 02-24-2008, 10:01 AM   #110
19723DR
19723DR's Avatar
I also decided to recess the lighter tan panel into the main door panel. So everything will flow more evenly.
I pulled apart the passenger side door panel and will do the same modification to it as well.
97 Z71 3 Door
Old 02-24-2008, 10:23 AM   #111
jugernot
Life, Be In It.....
jugernot's Avatar
Originally Posted by 19723DR View Post
If yours is lemon drop then mine must be banana cream pie. I'm really diggin' the yellow. I'm still working on how to attach them to the door.
Please keep us posted on how they are attached. I plan designing door panels for lemon drop. Your design is great, nice work. Great tips that will help me out. Thanks.
I did a quick search from clips and found these. I would imagine anyone of these would would, but it would be nice to see how they look on the door panel.
http://www.perfectfit.com/dept.asp?d...15974&l2=15290
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 02-24-2008, 05:50 PM   #112
Hart_Rod
Hart_Rod's Avatar
Your panels look great. Have you thought about using the stuff Rod Doors uses to attach their panels?
http://www.roddoors.com/pages/f-t-f-how.html
http://www.roddoors.com/pages/gumbo-dir.html#glue
Hart_Rod is offline   Reply With Quote
Old 02-24-2008, 06:37 PM   #113
Rokcrln
Rokcrln's Avatar
Wow you make it look so simple! What glue are you using for attaching the material to the board?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 02-24-2008, 09:53 PM   #114
MisterE72
Keep Your Nose Clean
You make the door panel work look easy! I just might give it a try when at that stage of my build. Thanks for the pics.
MisterE72 is offline   Reply With Quote
Old 02-25-2008, 04:06 AM   #115
jugernot
Life, Be In It.....
jugernot's Avatar
That looks like heavy duty velcro. I think it would work nicely.
Old 02-25-2008, 06:38 AM   #116
nuke1
nuke1's Avatar
thoses clips that jugernot showed you are what we use in the industry for upolstery, that heavy velcro over time and with the heat tends to seperate, the clips are the way to go.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 02-25-2008, 07:22 AM   #117
Hart_Rod
Hart_Rod's Avatar
I don't know if I would call it heavy duty velcro (I know that's what it looks like). The are actually made of hard plastic. I've used them before, they won't slip.
Old 02-25-2008, 10:36 AM   #118
19723DR
19723DR's Avatar
Kevin
LFD Inc.
Using spray adhesive for the material to to the board. Then I am using a hot glue gun to attach it to the back of the board. I'm using Elmer's Wood glue to attach board to board. This particular brand of spray adhesive has three spray settings.
97 Z71 3 Door
Old 02-25-2008, 10:44 AM   #119
19723DR
19723DR's Avatar
I found some more time today to work on the panels. I've tried 4 different types of clips and finally found one that is durable enough not to break. I just found most of the types to be too brittle.
I made a framework that would recess inside the door where I could attach the clips.
3/4" hole saw to make the slots and holes for the clips. You could use a little smaller one but that is what I had.
Here are the clips I found to be the best. I had to enlarge the holes in the door one size bigger for these to fit. They can pretty easily be removed without destroying them.
97 Z71 3 Door
Old 02-25-2008, 10:53 AM   #120
19723DR
19723DR's Avatar
Before I put the two pieces together I ran a bead of hot glue around the slot and the hole. This held the two boards far enough apart that I could get the clips in. These boards are hot glued together.
Here are the clips installed:
Here's it snapped into the door.
The bottom will be attached with Velcro or something like what Hart_rod mentioned. I'll make more progress tomorrow.
97 Z71 3 Door
Old 02-26-2008, 03:00 AM   #121
19723DR
19723DR's Avatar
Last night I glued the outer panel to the inner panel. I tried something a little different. I used head liner carpet on top and bottom for a little padding and also make a contour for the middle piece so the bottom wasn't so flat. I started off by hot gluing a piece of vinyl to the top so that I could spray adhesive both sides at the same time. I didn't spray the carpet so that it would smoothly pull over the top of it. I used the kid's Playdoh roller to smooth things out and get in all the corners.
97 Z71 3 Door
Old 02-26-2008, 03:04 AM   #122
19723DR
19723DR's Avatar
After I pressed the vinyl into all the grooves I cut the center section out so that handle piece would recess into it. I used some grabber screws to hold it in place and hot glued the edges. I also hot glued the exterior and pulled it tight. Here it is all snapped on:
97 Z71 3 Door
Old 02-28-2008, 04:20 AM   #123
69face
69face's Avatar
new subscriber! awesome!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 03-01-2008, 05:29 AM   #124
kyull67
kyull67's Avatar
NICE! That's going to be one classy ride!
kyull67 is offline   Reply With Quote
Old 03-01-2008, 09:20 PM   #125
38chevyhotrod
38chevyhotrod's Avatar
Very nice indeed, brings up some ideas.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
