Old 08-31-2012, 08:07 PM   #1351
El Campo
El Campo's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Frizzle you are a twisted man. And I love it! This is an amaaaaazing build. Has to be the coolest thing ever to have a Honda engine.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 08-31-2012, 09:40 PM   #1352
BlueJeep
BlueJeep's Avatar
Originally Posted by Frizzle Fry View Post
Some parts on the way-
Heater hose firewall bulkhead fittings:
These are actually glass. Pics don't do them justice. Made by Hella. Goodbye sealed beams:
Heat-Shrink Hose Clamps:
Looks like this installed:
Nice T-Bar Clamps for the engine connections:
More info on the lights please! Are those just a replacement for a normal sealed beam light?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 08-31-2012, 11:07 PM   #1353
Frizzle Fry
Frizzle Fry's Avatar
Yep. Direct replacement for 7" sealed beam low/hi beams.
Should work on chevy trucks too.
Frizzle Fry is offline   Reply With Quote
Old 09-01-2012, 04:19 PM   #1354
Frizzle Fry
Thanks man
Decided the exhaust tone was a little too mild. So I went ahead and put the Coast Fabrication muffler on to see how I like it. Sounds more aggressive I can easily swap back to the FM if this one turns out to be too much.
Need to get a sound clip.
Park/Turn housings refurbed. This one had a little rust spot. Thus cleaning and painting was required (for both). Can't just put it back the way I found it..
This is the 2nd worst rust spot I've found on the whole car (other one was in the eng comp near the DS hood hinge - fixed).
Modular headlights arrived:
OG on left:
You can see the new one has less dome (I like the original look more, but oh well - Should be worth it)
New:
OG:
New on PS OG on DS:
Made up a harness for running the lights through relays. This way I can upgrade the bulbs later to higher wattage.
Old 09-01-2012, 04:25 PM   #1355
Frizzle Fry
Also shortened the the throttle cable... Top is the removed length:
Crimped bead:
Inside (Focus fail)
On eng:
Old 09-01-2012, 04:33 PM   #1356
hgs_notes
GEARHEAD
hgs_notes's Avatar
I used a different brand of headlight kit, PAL I think, looks almost identical to your hellas. They have about the same amount of crown to the glass. I had tried some cheap set before and they were perfectly flat on the glass. They were poorly built and I didn't like the look so I sent them back to amazon. The new lights made a huge difference, especially once I go tthem aimed properly. You're going to like the upgrade.
Nice job on the throttle. Looks unmolested.
hgs_notes is offline   Reply With Quote
Old 09-01-2012, 05:20 PM   #1357
watahyahknow
watahyahknow's Avatar
http://biertijd.com/mediaplayer/?itemid=36630
swedes and there volvo's.......
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-02-2012, 12:54 AM   #1358
Frizzle Fry
Thanks man. Good to hear more positive reviews on the lights. They are all hooked up with relays now and look BRIGHT. Can't wait to drive with them!
Old 09-02-2012, 12:55 AM   #1359
Frizzle Fry
Deleted
Old 09-02-2012, 03:12 AM   #1360
76C10Stepside
76C10Stepside's Avatar
Originally Posted by watahyahknow View Post
you shouldve seen some of the builds that the swedes are doing to volvo's , turbo is the magic word there and there definetely not youre average grannies car
the amazon does have a lot of space it wil seat 4 or 5 comfortably and the shape allways reminded me of a leadsled out of the 50s
now lets see ...... a eurocar that has nice shapes........ french car maibe?
peugeot cv4
The other day, I had deja vu when I saw this twin of the CV4 you posted at a car show. It had every option you could get on it. Check out the rare hood ornament! The guy that owns it also owns the customized '46 Fiat Topolino below, with a Buick V-6 transplant:
76C10Stepside is offline   Reply With Quote
Old 09-02-2012, 12:33 PM   #1361
El Campo
El Campo's Avatar
Weatherpacks on turn signals: brilliant idea. Although I am irritated with you now because now my regular old 1972 connectors on the C10 are not going to be good enough (now that I have seen that) and I will have to do the same thing!!!
Hook em Horns!!!
Old 09-02-2012, 06:18 PM   #1362
Frizzle Fry
Yep, raising the bar for myself too. Now I can never go back
Old 09-02-2012, 07:09 PM   #1363
jb1016
"Oh well, it's a driver."
jb1016's Avatar
The "might-as-wells..." They get me too, just at a much lower level of craftsmanship.
Old 09-02-2012, 07:50 PM   #1364
Frizzle Fry
well, I didn't replace or even weld up that light housing. Gotta draw the line somewhere if I ever want to drive this beast!
Old 09-02-2012, 09:15 PM   #1365
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Lots of great ideas on here! Real cool build FF. love the different stuff.
Zoomin is offline   Reply With Quote
Old 09-02-2012, 11:48 PM   #1366
65Pickup
65Pickup's Avatar
Who is the bulk head manufacturer?? Great parts, I need those lights too, gotta drive with my high beams on, sadly I don't ever get flashed!
65Pickup is offline   Reply With Quote
Old 09-02-2012, 11:55 PM   #1367
65Pickup
65Pickup's Avatar
Plus one more, can you explain the wiring for this set up.
Old 09-03-2012, 07:43 PM   #1368
Frizzle Fry
Bulkhead Fitting here.
The relays simply take the headlight current instead of the switch and dimmer. Now the headlight switch and dimmer switch activate the relays, while the relay passes the high current directly from the battery to the lights. I know there's a FAQ on it here somewhere... If you don't find a diagram let me know and I can make one.
Old 09-03-2012, 08:59 PM   #1369
65Pickup
65Pickup's Avatar
Thanks for the info, that fitting is real nice. I'll look for that FAQ for more info. A friend used the same lights, just curious about the install. Great work as usual.
Old 09-03-2012, 10:34 PM   #1370
Frizzle Fry
The lights bolt-in/plug-and-play! I only added the relays for added brightness and future bulb wattage upgrades.
Old 09-04-2012, 12:17 PM   #1371
theastronaut
theastronaut's Avatar
Here's what you've got to look forward to. These are Cibie's with 80/100W Hella's, 50 amp relays, and 10g wiring straight from the battery. Now you just need a pair of narrow spot beam driving lights wired into the high beams!
theastronaut is offline   Reply With Quote
Old 09-04-2012, 01:32 PM   #1372
65Pickup
65Pickup's Avatar
Thanks guys, that's exactly what my truck needs, much safer than the tobacco washed light I have now!!
So the relays make the halogens brighter, and you can upgrade the bulbs for even more light?
Old 09-04-2012, 04:06 PM   #1373
watahyahknow
those heatschrink clamps look like the bees knees ... verry nice
never knew they existed i wonder how whell they would work on turbo piping
Old 09-04-2012, 08:32 PM   #1374
Frizzle Fry
Nice!
When It's time to upgrade I plan to go with something like this.
Should work. They go up to 3.25" http://www.mcmaster.com/#standard-hose-clamps/=j5h1nu
Old 09-04-2012, 10:57 PM   #1375
theastronaut
Good choice on the Osram bulbs, high quality and no ricer bling! Are you using ceramic connectors? Might need them with the extra heat from higher wattage bulbs.
