10-04-2012, 11:39 AM | #1426 |
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
true words, right there. I just change the part where you said "his project" to "my projects"
"I feel the need for speed!"... as soon as I am done with my nap. |
10-05-2012, 12:02 AM | #1427 | |||
So you're son is not alone. It's easy to get overwhelmed when there are countless unknowns on the road ahead, but as he checks off each task confidence and momentum will build. Quote:
Posted via Mobile Device Posted via Mobile Device |
10-05-2012, 05:39 PM | #1428 |
he prollt start getting interested one week before his 16th birthday , and knowing you a little the only thing left is to buff up the paint a little
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
10-06-2012, 07:31 PM | #1429 |
Knowing me..? take a look at when I started this project.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
10-06-2012, 10:41 PM | #1430 |
I dun gradjiated collij!!!
Damn Mike, has it really been 3 years?
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
10-07-2012, 12:55 AM | #1431 |
I know... no more messing around! I'm getting ready to do a fully mocked up shake-down drive!!!
10-09-2012, 02:04 AM | #1432 |
Get it done already!
10-12-2012, 02:39 AM | #1433 | |
Boss Hogg
And then get back to work on the "Tahoe". *cough* *cough* |
10-12-2012, 01:46 PM | #1434 |
PROJECT 7DEUCE
I wanna go for a ride!!!!
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-13-2012, 12:38 PM | #1435 |
Waiting..........................................
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
10-13-2012, 02:01 PM | #1436 |
Bleed brakes, install wheels and seat; drive! But the rear brakes don't want to bleed! Already replaced mc. Using vac pump. Wish me luck!
10-13-2012, 04:11 PM | #1437 |
maibe it helps to jack the rear up as far as it wants to go
makes the bends that are above the bleednipples go below it
10-13-2012, 04:29 PM | #1438 |
You don't need back brakes with those huge front discs. Get in it and drive, we are waiting!!!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-13-2012, 09:40 PM | #1439 |
the pollock
Id double check any flare fitting... they have a tendency to suck air with the mighty vac, but work semi allright under pedal...
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
10-13-2012, 10:38 PM | #1440 |
Well, it seems there may be a fundamental design flaw in mounting the MC rotated 90*. I can't get good pedal pressure at all. Even with the rear circuit port capped and good solid fluid streams at both front calipers.
The last option to try before addressing the MC (either make an adapter to turn it or buy a different MC all together) will be to try a pressure bleeder... |
10-14-2012, 12:20 AM | #1441 |
Sucky, my solution.......
You have 3 options: A) No brakes needed, just be a great driver and never stop B) fred flintstone the car, hole through the floor and some good work boots C) E-brake only I think those are some fine options and that is what should be done, you have some very impatient ppl here waiting, inc me!!! hehe
10-14-2012, 02:57 AM | #1442 |
I do have a good functioning turning brake and skills to use it
10-15-2012, 01:02 PM | #1443 |
cap the prop valve to the rear and just run the E brake! That sounds like a little excitement every day.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
10-15-2012, 07:59 PM | #1444 |
Not messin around. Got this on the way...
10-16-2012, 07:55 AM | #1445 |
Man of Mini-Talents
That should take care of it.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
10-17-2012, 06:48 PM | #1446 |
10-17-2012, 08:29 PM | #1447 |
UPS Status = Delivered
10-17-2012, 08:40 PM | #1448 |
Good man! I like parts. They are like little packages from heaven. Hehe
10-19-2012, 03:11 AM | #1449 | |
Let's get caught up to present: Cooling lines installed. Some of the gates shrink clamps too. The S2000 MC that ultimately didn't work due to failure to bleed: Had set up some 90* fittings and a bracket for the reservoir to mount in this orientation: Clutch slave cylinder flex line bracket: Key oreintation flipper 180* Reduced width and primered (no pic of it installed...) : Removed broken bolt from rear: Success: Wilwood MC installed and BLED!!! (FYI the nut on the firewall above is for the fuse panel and will be relocated to the inside/welded in before paint) Rack ready to go in: ...and back on her wheels: Just waiting for a clear day now... Better/outside pics to come! |
10-19-2012, 09:04 AM | #1450 |
Coolest thread on the site, definitely the one I'm watching the closest! Awesome work on everything you've done to it!! Anxious to see it out and driving!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
