Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 11-05-2012, 05:54 PM   #201
c.brown
c.brown's Avatar
Re: 1966 suburban slammed fuel injected 6.2L
Originally Posted by Bomp View Post
You sir have some talented skillz and some of the best little helpers.
The burb is sweet too.
subscribed.
thanks alot those helpers take some time but worth every second ill have to check your build out
Originally Posted by jasonhall View Post
Where is your ECM going to be placed?
putting them inside under the dash
My build
c.brown is offline   Reply With Quote
Old 11-05-2012, 08:22 PM   #202
jasonhall
jasonhall's Avatar
Did you provide the measurements for the harness or does he know how far to lengthen it??
jasonhall is offline   Reply With Quote
Old 11-06-2012, 06:06 PM   #203
c.brown
c.brown's Avatar
i just told him what i had and what i wanted to do
My build
Old 12-13-2012, 06:12 PM   #204
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Hey any updates this whole suburban thing is catching on!!!
gostranger is offline   Reply With Quote
Old 12-14-2012, 02:56 PM   #205
c.brown
c.brown's Avatar
Ya have noticed a lot more now .working on fuel system trying to get it fired soon. I
My build
Old 01-16-2013, 07:08 PM   #206
gostranger
gostranger's Avatar
C.Brown you have to get this build onto the suburban section!
Old 01-16-2013, 07:26 PM   #207
c.brown
c.brown's Avatar
That's awesome there's a suburban section but how do u get moved there I see yours needs to be moved
My build
Old 01-23-2013, 12:03 AM   #208
Hart_Rod
Hart_Rod's Avatar
Nice build!
Hart_Rod is offline   Reply With Quote
Old 01-23-2013, 02:42 PM   #209
c.brown
c.brown's Avatar
Originally Posted by Hart_Rod View Post
Nice build!
Hey thanks been chipping away at small thing gathering all new parts for rear brakes and down to a couple fittings on the fuel system then should be able to here the motor run
My build
Old 06-25-2013, 02:51 PM   #210
c.brown
c.brown's Avatar
Finally some progress have a radiator now,working on driveshaft now
My build
Old 06-26-2013, 06:34 AM   #211
gostranger
gostranger's Avatar
looking good!!!
Old 06-26-2013, 05:51 PM   #212
aggie91
I'm just glad to be here!
aggie91's Avatar
Just read thru this one. Tuning in for the home stretch....
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-26-2013, 06:28 PM   #213
c.brown
c.brown's Avatar
looking good!!!
thanks
hope to keep some more progress going
My build
Old 06-26-2013, 09:01 PM   #214
c.brown
c.brown's Avatar
Here's my cold air intake setup had to modify a little for the mass air and eventually make an airbox
My build
Old 06-27-2013, 06:06 AM   #215
gostranger
gostranger's Avatar
wow that looks nice and clean!!!!
Old 06-30-2013, 10:54 PM   #216
jmedero
jmedero's Avatar
Super cool build man.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-03-2013, 10:56 AM   #217
c.brown
c.brown's Avatar
Thanks guys trying to chip away at it
My build
Old 07-04-2013, 08:37 AM   #218
Hart_Rod
Hart_Rod's Avatar
Good progress. How's the driveshaft coming? Any pics?
Old 07-08-2013, 12:13 AM   #219
kpc01
C.brown I saw you got a boyd welding tank. I am looking for one for my 64 suburban that I will be doing porterbuilt suspension on. Can you tell me if the tank he sells fits well with the porterbuilt and if it will allow it to drop all the way still? I'm doing a LS motor as well so will be doing the EFI tank probably exactly like yours. My stock tank is only an inch or so from the floor but its about 13" tall and his is 10" I believe.
Any input or advice?
kpc01 is offline   Reply With Quote
Old 07-08-2013, 12:31 AM   #220
68GMCburban
68GMCburban's Avatar
Awesome build! I can't wait to see it finished.
-Holden
1983 & 1972 Chevy Longbeds
(16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc)
1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806
(6) 60-66s (shortstep, rollback, two-ton, longbeds)
(3) 47-59s half tons
+ MANY more and always looking for more
68GMCburban is offline   Reply With Quote
Old 07-09-2013, 09:57 AM   #221
c.brown
c.brown's Avatar
so far on driveshaft cut the yokes off and had the old tubes milled of now just have to shorten and weld back together
I would call them mine was the first one of these years he did I seen somebody else's on here from them and turned out a little better great guys to deal with and if your running Porterbuilt in the rear don't use the 4 link setup I was the Guinea pig and would go a different rout with what's out there now
thanks its been slow I can't wait either
My build
Old 07-09-2013, 02:39 PM   #222
c.brown
c.brown's Avatar
Here's the yokes after being milled and mounted my transmission cooler
My build
Old 07-09-2013, 02:44 PM   #223
Hart_Rod
Hart_Rod's Avatar
How much do you have to raise your carrier bearing? What angle did you set your motor at?
Old 07-09-2013, 02:53 PM   #224
c.brown
c.brown's Avatar
Im in the process of figuring that out I will let u know when I do
My build
Old 07-09-2013, 03:04 PM   #225
Hart_Rod
Hart_Rod's Avatar
take a look at this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=563461
