Old 04-29-2015, 11:42 PM   #126
tune_1
Re: 1940 Packard 120 Convertible Restoration
What an opportunity. You will learn a lot when you replace what they have done in the lead. Problem solving is when I learn the most. Great work
Dwight
tune_1 is offline   Reply With Quote
Old 05-01-2015, 10:26 PM   #127
BlueJeep
BlueJeep's Avatar
What do you use for blast media and what blaster do you use? Looks VERY nice! And your work just gets better and better, I like it!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-04-2015, 07:33 AM   #128
theastronaut
theastronaut's Avatar
Originally Posted by swamp rat View Post
I just scrolled thru page 5 and my jaw about hit the floor.... Nuff said?
Thanks!!
Dwight
I've been watching "how-to" vids on youtube to get an idea of what to do. I did a couple seams on the firewall and pillar post last Friday; it was easier than I thought it would be. I decided to go with real lead instead of the lead-free version since it has a lower melting point and a much wider elastic working range. The lead-free version has a pretty narrow heat range before it melts and runs off the panel- didn't think that be good to learn with. I will eventually try the lead-free once I get a better feel of working with the lead version.
Just plain sand, fine/extra fine. We bought a used Volks Air compressor and the blaster came with it. It didn't have any markings on it, not sure who built it.
theastronaut is offline   Reply With Quote
Old 05-05-2015, 09:15 PM   #129
theastronaut
Made a video of the lead work but had to break it up into smaller clips to get it to upload. I'm still trying to get the hang of getting the lead soft but not melted so it's shapeable. The middle section isn't as much of a problem; it heats up pretty evenly. The edges are much more difficult to get the lead heated evenly. The outside "skin" melts and runs off but the inside of the chunks are still hard. I did turn the torch down a bit and that seemed to help.
Old 05-06-2015, 08:54 AM   #130
theastronaut
I went over the area to be leaded with a wire brush to make sure it was smooth/clean before applying the solder paste.
After filing the lead flat. This is an odd area to shape, the upper half is slightly concave in both directions so the flat file could only do so much shaping.
So I sanded it with 36 grit to finish shaping it. I know you're not supposed to sand lead, but the 36 grit is so rough that it doesn't make fine dust particles. I was wearing a mask of course.
The 36 grit lead "dust", almost big enough to be called shavings. This isn't small/light enough to float around in the air so I felt ok about sanding with 36 grit.
Old 05-14-2015, 04:15 PM   #131
theastronaut
Got most of the lead work done, ran out of lead sticks before I was able to finish the last rear quarter/trunk panel seam.
I melted out the last two spots I had left on for reference and blasted the areas to clean out the rust that was underneath. The top pic shows just how far the edge was pounded in from the factory.
Filled in the driver side quarter seam. I'll have to remove the bracing before I can file it smooth.
Door jambs filled and smoothed.
Shot the body with a couple coats of PPG DP74LF epoxy. I'll get it back on the frame next and start welding in the new panels.
Old 05-14-2015, 07:56 PM   #132
Advanced Design
Advanced Design's Avatar
Nice work! How is the vehicle owner holding up?
Advanced Design is offline   Reply With Quote
Old 05-15-2015, 04:45 AM   #133
swamp rat
swamp rat's Avatar
^^ X 2 , ya just don't see lead work much these days..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-15-2015, 03:54 PM   #134
theastronaut
Thanks! He's enjoying the process so far.
We couldn't find anyone local that has used it, had hoped to get some pointers before starting. Had to get on youtube and watch what other guys were doing before I attempted it.
Old 06-15-2015, 04:15 PM   #135
theastronaut
I cut the jump-seat base out and made a new panel. This was an easy piece to make... the rest of the rear seat area kicked my butt...
Like the middle pans, the only thing I had to go by for the rear pans were the pictures and measurments taken earlier from another car. I made a (really) rough draft of a template to start mapping out the bead lines and body mount areas. The pictures I had were barely adequate to get the measurements correct, so there were a couple areas that all I could do was make the proportions look right. I doubt there will be any show judges crawling on their backs under the car with tape measures. Once I had the rough template in the car I made some corrections and transferred that to translucent paper. That template still needed some fine tuning before I could transfer the pattern to sheetmetal.
The rear pans are mirrored so I can flip the pattern and use it for both sides.
Checking the fit of the right rear pan. It's not in there straight since the outer rear edge needs to be turned down into a flange to fit against the fenderwell. Once that's done it'll slide all the way back into place. I'm 90% finished with the left pan so I can start welding the inner/outer rockers, quarter, and front lower cowl panels in place. The inner/outer rockers sandwich the floor pans so I needed to have all of the pans done before anything else could be welded in for good.
Old 06-15-2015, 10:01 PM   #136
MP&C
MP&C's Avatar
Nice fabrications.......
Robert
MP&C is offline   Reply With Quote
Old 06-16-2015, 01:13 AM   #137
shok
You could probably have a pretty popular YouTube channel with videos featuring your restoration projects.
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline   Reply With Quote
Old 06-16-2015, 10:31 AM   #138
Russell Ashley
Russell Ashley's Avatar
This is going to be he nicest 1940 Packard in existence. The owner must be extremely happy.
Russell Ashley is offline   Reply With Quote
Old 07-07-2015, 02:10 PM   #139
MP&C
MP&C's Avatar
John, saw a nifty little tool online today and thought of you.... may need one for all the floor pan work you're doing..
http://www.allmetalshaping.com/showp...5&postcount=75
Robert
Old 07-09-2015, 07:47 AM   #140
theastronaut
Thanks dudes, appreciate the comments!
I'll have to build one of those! That would be very helpful when I get to the trunk pan. Thanks for posting that!
Old 07-13-2015, 03:56 PM   #141
theastronaut
With the floor pans mostly roughed in I turned back to the section under the back seat. I had the center section made but needed to make the side pieces. The left side is fabbed and welded in, just started on the right side last week.
I bent the back edges of the floor pans to fit against the rear seat floor section. Also trimmed the rear seat pan to fit up nicely once it's ready to weld in, and drilled holes for the plug welds.
You can see how the back edge of the floor pan will weld to the inner fenderwell and bottom of the seat pan.
This is looking into the right quarter panel from the inner fenderwell. The fenderwell should be covering this, so you can't see in... I decided to go ahead and cut this area out since it was in such bad shape and the rear seat pan edges needed to weld to the fenderwell.
After cutting out the lower front fenderwell and edge of the seat pan. It's amazing that the car didn't collapse in on itself; this was a body mount area that is completely rotted away.
Made a new seat pan edge.
Blasted and painted the floor braces with Por15.
Made a template for the inner fenderwell skin.
Old 07-13-2015, 08:55 PM   #142
dantimdad
dantimdad's Avatar
Unreal!!!
As my dad would have said "Jack up the radiator cap and throw a whole new car under it!"
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 07-14-2015, 06:58 PM   #143
flashed
Im still amazed at every update on this project ,looks great.
flashed is offline   Reply With Quote
Old 07-29-2015, 11:09 AM   #144
theastronaut
Originally Posted by dantimdad View Post
Unreal!!!
Steven
That's pretty accurate!
Appreciate it!!
Old 07-29-2015, 11:15 AM   #145
theastronaut
I have the right inner fender bottom welded in, and the rear seat pan welded in on the areas that I can get to. I'll have to flip it on the rotisserie to finish welding the middle section, there is about 16" in the middle that I can't reach from the top side.
With the seat pan in I mocked up the inner/outer rockers and floor pans so I could start on the inner B-pillar brace and finish the outer B-pillar section.
Bottom half of brace made.
Old 07-29-2015, 01:01 PM   #146
Advanced Design
Continued nice work! Really enjoying following along.
Old 07-29-2015, 01:51 PM   #147
Russell Ashley
Amazing. That's he only word I can think of to describe this build.
Old 08-03-2015, 12:40 PM   #148
Low Elco
Awesome! I'm enjoying following.
Low Elco is offline   Reply With Quote
Old 08-03-2015, 01:10 PM   #149
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Simply put REMARKABLE !!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-03-2015, 07:51 PM   #150
Bomp
Bomp's Avatar
Every time I stop to check up on your progress I end up looking at the pics for 45 minutes or so.
Great job.
Keeps me on point with my little attempts.
Bomp is offline   Reply With Quote
