Old 11-26-2012, 06:44 PM   #1
jrdv
jrdv's Avatar
Early X-mas! 6.0 L96+6L90
I bit the bullet and bought this today. It is out of a 2011 2500 2wd with 19,000 mi. It will be going in my 71 chev swb.
I need to start gathering parts. The place I bought it from didn't know which oil pan I needed, but said to find out and they would get me one at cost.
So, first question. What oil pan? I have seen people using an F body pan, ctsv caddy pan, summit pans, etc.
My truck has a 4/6 drop with 18/20 wheel combo.
What is the best?
Thanks in advance for the many questions I will be asking.
jrdv is offline   Reply With Quote
Old 11-26-2012, 07:03 PM   #2
Daaaanz67
Re: Early X-mas! 6.0 L96+6L90
Ctsv for me fit perfect bottom of pan was about 1/4 inch above crossmember. My truck is also 4/6.
Daaaanz67 is offline   Reply With Quote
Old 11-26-2012, 07:14 PM   #3
jrdv
jrdv's Avatar
Does the year matter? Did you buy new or used? Cost?
John
Old 11-26-2012, 08:26 PM   #4
clinebarger
GM swap pan http://www.summitracing.com/parts/nal-19212593
clinebarger is offline   Reply With Quote
Old 11-26-2012, 08:36 PM   #5
jrdv
jrdv's Avatar
Originally Posted by clinebarger View Post
I checked into that earlier. It only covers 6.0 up to 2009. I can't find any other info on the 2011 as far as oil pan swaps go. I don't know for sure if there are any differences.
Thanks for the input!
john
Old 11-26-2012, 08:53 PM   #6
clinebarger
john
I put a '02 5.3L truck pan on a '11 6.2L LS3 a few months back, Worked great.
The list is not complete.
Not sure on AFM (active fuel management) engines though, Does the L96 have AFM?
Old 11-26-2012, 09:06 PM   #7
Hart_Rod
Hart_Rod's Avatar
That's gonna be pretty sweet!
Hart_Rod is offline   Reply With Quote
Old 11-26-2012, 09:11 PM   #8
68Stepbed
68Stepbed's Avatar
I used an f-body pan on mine.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-26-2012, 09:45 PM   #9
jrdv
jrdv's Avatar
I am not sure???????? Will have to check on that.
Thanks Rob!
Is yours a 2011? The are a few differences over the older GenIV motors, like injectors, intake and exhaust valve material (for E85). I am just wanting to be positive that there were no changes to the oil pan or oil pickup, etc.
John
Old 11-26-2012, 09:47 PM   #10
jrdv
jrdv's Avatar
Would that have to do with it being a returnless fuel injection system?
Old 11-26-2012, 11:50 PM   #11
clinebarger
No, AFM engines have a AFM valve in the oil pan 1 in the pic.
It does not appear that the L96 is not AFM...but does have VVT, So the pan will fit.
Old 11-26-2012, 11:54 PM   #12
jrdv
jrdv's Avatar
Thanks Cline,
Do you have any other advice for this swap?
I am from the Old School and don't have much experience with any motors requireing a computer!
I have spent quite a bit of time on LS1tech, but not much info on the L96 and 6L90 over there.
John
Old 11-27-2012, 01:59 AM   #13
Daaaanz67
06-08 pan tried to buy used but the wrecking yards laughed at me paid around 280/300 new heres how it looks in my truck
Old 11-27-2012, 09:16 AM   #14
smoky02
Location: Sunny, Florida, some might call it South Alabama
I am using a 98 corvette pan. Seems to be the only one that doesn't even come close to hanging down below the K member.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 11-27-2012, 12:17 PM   #15
Hart_Rod
Hart_Rod's Avatar
Cool Re: Early X-mas! 6.0 L96+6L90
Thanks Cline,
John
What motor mounts do you plan on using?
Old 11-27-2012, 10:16 PM   #16
jrdv
jrdv's Avatar
Thanks Dan and Smoke! Appreciate the input.
Rob,
I bought the ECE motor mounts and trans mount last year. Not sure if they will be a straight forward setup for this combo. Will probably do a test fit on a bare frame I have and see what kind of mods I will need to do.
The motor should be here sometime next week....I hope.
Getting excited about this project, but I have a long ways to go as far as getting all the parts!
John
Old 11-27-2012, 10:22 PM   #17
Hart_Rod
Hart_Rod's Avatar
Rob,
John
John,
I'm looking forward to seeing the finished product, let me know if you have any questions. If you use the ECE mounts you won't be able to use a FBody oil pan (it hits the front crossmember). I used a 2007 Cadillac CTsV pan, but there are several choices out there. The Doug Thorley Headers work well with those mounts also. You can check out my Suburban build thread for pictures of both.
Here's a good thread on choosing an oil pan:
http://67-72chevytrucks.com/vboard/s...d.php?t=272174
Rob
Old 11-27-2012, 10:28 PM   #18
jrdv
jrdv's Avatar
Thanks Rob.
I bought the mounts with plans to put a 5.3 and 4L60 into a 68 GMC. I may just save the mounts for that project.
What do you think about the DirtyDingo mounts?
I had planned on using the same headers that you did. If I get mine running before the burb is done.....can I use the supercharger for a little while?
I will probably have a lot of questions for you when I get further into the swap.
John
Old 11-27-2012, 10:44 PM   #19
Hart_Rod
Hart_Rod's Avatar
Thanks Rob.
John
I'm thinking of using the Dirty Dingo mounts on my 68. I'm going to be installing a 6.0/4L80E (unless I come across a setup like yours, ). I like the adjustability and would like to move the motor a little further back than the ECE mounts do. I picked up a Maggie TVS1900 for the 68, I could probably loan it to you for a while....
EDIT: Who did you get your motor/tranny from?
Old 11-27-2012, 10:50 PM   #20
jrdv
jrdv's Avatar
Thanks for the pan link. I did a search earlier, but I must have missed that one! Good info!!!!!!!!
The adjustability might be handy with the DD mounts! I would like to use the stock fan setup instead of electric fans.
The supercharger would be nice to borrow, but I bet you will be ready to use it before me!
John
Old 11-27-2012, 10:52 PM   #21
jrdv
jrdv's Avatar
Rob..
pick_a_part on ebay.
Old 11-27-2012, 11:27 PM   #22
Daaaanz67
I'm using ece mounts with electric fans. I don't think it will clear manual fan. When using these mounts with the trans crossmember all my factory holes lined up. Since this is my dd I chose the Holley hooker ls manifolds didn't want to deal with headers even though the thorleys are awesome plus the hookers were cheaper and fit like a glove. Just wanted to share a little info from my recent conversion
Old 11-28-2012, 12:17 AM   #23
jrdv
jrdv's Avatar
Thanks...good to know on the clearance issue. I am open to all ideas, opinions, and experience!
John
Old 11-28-2012, 02:41 PM   #24
Luba
Luba's Avatar
How much was the motor and trans?
Luba is offline   Reply With Quote
Old 11-28-2012, 10:22 PM   #25
mooseknuckles
mooseknuckles's Avatar
hope this helps.... Im running the gm muscle car pan it's shallower than the stock truck pans by 1 1/2". I'm guessing the f-body pans are close to the same as the holley pan...
mooseknuckles is offline   Reply With Quote
