Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-16-2009, 05:34 PM   #1
383 Stroker
383 Stroker's Avatar
Ran a 7.12 @94mph
I ran a 7.12 @94 mph with a 1.54 60ft yesterday... This was on a 150 shot. I put some 90/10's on it. It got a little air under the tires this time...
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 11-16-2009, 06:48 PM   #2
Super73
Super73's Avatar
Re: Ran a 7.12 @94mph
Right on.. Looks fairly level on the launch as well..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-16-2009, 11:53 PM   #3
71Dragtruck
71Dragtruck's Avatar
Awesome!
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 11-17-2009, 12:43 AM   #4
team39763
NICE WORK BRO! That's awesome.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 11-17-2009, 03:11 PM   #5
383 Stroker
Thanks. Here's a video of me racing a ZO6.
Old 11-17-2009, 11:09 PM   #6
Hart_Rod
Hart_Rod's Avatar
What rpm do you shift at?
Hart_Rod is offline   Reply With Quote
Old 11-17-2009, 11:17 PM   #7
383 Stroker
I try to shift at 6000rpm...
Old 11-17-2009, 11:46 PM   #8
383 Stroker
Here's a video of me trying to make a nitrous pass on a poorly prepped lane...
Old 11-17-2009, 11:59 PM   #9
Hart_Rod
Hart_Rod's Avatar
Is that when the motor quits pulling or just what you like to shift at? Do you have a rev limiter? Sorry for the "dumb" questions, but I'm getting ready to take mine to the track and haven't done a lot of racing. Just trying to do a little research, .
Old 11-18-2009, 01:06 AM   #10
383 Stroker
I have turned it 6800rpm with the nitrous, but don't like to turn it that hard. I really don't want to break it before i get the 421ci built... I don't have a rev limiter. I'm just running a HEI distributor.
Old 11-18-2009, 02:42 PM   #11
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
good numbers man truck looks good
_______________________________
1968 c-10 stepside "THE GRAPE APE"
all motor
1.56...60ft
7.41...1/8
89.41..1/8
limitedstreetoutlaw is offline   Reply With Quote
Old 11-18-2009, 03:52 PM   #12
BossHogg69
motor exploder
BossHogg69's Avatar
383 Stroker - what are the details on your suspension setup?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-19-2009, 09:45 AM   #13
djracer
djracer's Avatar
Sweet!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-19-2009, 07:45 PM   #14
383 Stroker
The front has drop spindles, stock springs with half a coil cut, 90/10 shocks. I also took the limiters off the upper control arms. The rear has Eibach 4" drop springs, doeshtec shocks. I flipped the shock brackets over to get a little more travel.
Old 11-19-2009, 08:11 PM   #15
69trk
69trk's Avatar
nice 60' times
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 11-20-2009, 01:37 AM   #16
BossHogg69
motor exploder
BossHogg69's Avatar
wow, that's hookin' pretty hard for a pretty simple setup! Thanks for the info.
Adam
Old 01-07-2010, 02:30 PM   #17
Ont67shortbox
Do you remember the Brand and pt number of the 90/10 shocks?
Ont67shortbox is offline   Reply With Quote
Old 01-07-2010, 04:19 PM   #18
bigboybodry
bigboybodry's Avatar
That is allsome !!!!! I wish mine was running. Truck looks great!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
