Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 02-20-2010, 08:58 PM   #1
joeelutz
joeelutz's Avatar
Custom radiator cover upper support REDUCED PRICE
This radiator cover will add a unique style to your engine compartment and is sure to gain attention whenver you pop the hood. It is designed to
dress the top of the radiator and radiator support on 67-72 Chevy pickup trucks. It is CNC laser cut and press brake formed from of 16ga steel for a rigid support. the corners are TIG welded and ground smooth. The cover is available in 4 options. Full covers replace the stock upper radiator support mounts and are useful when using an electric fan and want to eliminate the unused stock upper shroud mounts. Partial covers are used when you want to keep the stock mounts in case you are using the stock fan shroud. It fits between the stock mounts using the inner two bolts for attachment. Both styles attach using the stock bolt holes for V8 radiator location so no drilling is necessary. Stainless steel button head bolts and hardware are included! These covers are available for both standard V8 and HD V8 radiators. To determine which radiator you have, measure the stock upper mounts overall
length. Standard mounts are 5 1/2" long and HD mounts are 6 1/4" long.
You can purchase through my website at http://www.hotroddynamics.com/Products.html
joeelutz is offline
Old 03-01-2010, 08:26 PM   #2
pcmcobra
pcmcobra's Avatar
Re: Custom radiator cover upper support
where's the 73-87 love?
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline
Old 03-01-2010, 08:38 PM   #3
joeelutz
joeelutz's Avatar
It may work on those too. I haven't tried it.
joeelutz is offline
Old 03-01-2010, 09:50 PM   #4
AJs72K5
AJs72K5's Avatar
What's the difference between the full and the partial cover?
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline
Old 03-02-2010, 02:20 PM   #5
joeelutz
joeelutz's Avatar
Full cover replaces the stock upper mounts eliminating the upper shroud mounting holes. This is benificial if you are using an electric fan. Partial cover goes between the stock upper mounts and would be useful if you are using the stock shroud. If you want a full cover and want to use the stock shroud, you may be able to modify the shroud to work with a full cover.
joeelutz is offline
Old 03-02-2010, 10:44 PM   #6
jugernot
Life, Be In It.....
jugernot's Avatar
Are they avaliable WITH OUT the six holes in the top?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline
Old 03-02-2010, 11:37 PM   #7
joeelutz
joeelutz's Avatar
Yes, I can make one that way.
joeelutz is offline
Old 03-03-2010, 09:16 PM   #8
joeelutz
joeelutz's Avatar
I have significantly reduced the price on these and added the option of with or without holes. For now I only have the Full covers.
Check the options and pricing on my website where you can use secure checkout to purchase through PayPal.
joeelutz is offline
Old 04-09-2010, 06:03 PM   #9
Hart_Rod
Hart_Rod's Avatar
Got mine today Joe. They look great! I can't wait to get them installed. Pictures to follow....
Hart_Rod is online now
Old 04-10-2010, 12:03 AM   #10
givengold
If it will fit a '77 big block, I am in. Any way you can check fitment?
Dan
givengold is offline
Old 04-10-2010, 10:04 PM   #11
joeelutz
joeelutz's Avatar
Dan
I believe 73 takes an entirely different radiator support and it would not work without significant modifications.
joeelutz is offline
Old 05-22-2010, 08:18 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Do you use the stock style rubber mounts inside the cover? Like the ones that are already in my HD brackets?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline
Old 05-22-2010, 08:20 PM   #13
Hart_Rod
Hart_Rod's Avatar
Gary
Thats what I used in mine.
R/
Old 05-26-2010, 10:50 AM   #14
GASoline71
GASoline71's Avatar
Thanks Rob...
Gary
Old 05-27-2010, 01:41 AM   #15
98gmc
Man you need to make something for 88-98 caus ei am about to put electric fans and would love something like this
98gmc is offline
Old 05-27-2010, 10:45 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
joeelutz- Please contact me regarding your account status.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Closed Thread
