03-28-2014, 11:50 AM | #1 |
C10 Club Tennessee
2 Piece Driveshaft question for a bagged 71 Suburban
Not having any luck over in the suspension area so I'll ask it here.
First of all, I have a 4L60E transmission and my front shaft has already been cut and the carrier bearing has been installed. My question is what is the best option for the rear, a slip yoke? What's the best way to measure so I can give them the correct measurements at the driveshaft shop. Is it a measurement of all the way aired out and then at max height? The front shaft is original, it is just shortened at the yoke end. Also, are there any parts (slip joints) from other vehicles I can use to lessen the cost from having an entire new one made? Thanks for any suggestions.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 03-28-2014 at 11:56 AM. |
03-28-2014, 11:34 PM | #2 |
The Older Generation
Re: 2 Piece Driveshaft question for a bagged 71 Suburban
I think you would have to have a slip yoke at the front of the rear shaft like the original shafts do. Don't take this as gospel but I read somewhere that to figure drive shaft length slide the shaft all the way in, then pull it out 1/2" and mark your length. You might want to PM bradman_72 and ask him, he works in a driveline shop. LockDoc
03-29-2014, 12:41 AM | #3 |
Why not just get a one piece made if there cutting the front half already? You have to measure from flange to flange and if you measure on the bottom of one measure on the bottom of the other one.if that makes sense.
04-02-2014, 10:43 PM | #4 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-12-2014, 11:32 PM | #5 |
I use a slider shaft from a company called Inland Empire Driveline in california.
It allows the shaft to change length when you lower the truck. I used to eat up u joints and now I dont have any trouble. |
04-13-2014, 12:13 AM | #6 |
I ended up getting the rear shaft with slip that CPP makes. I got it from Justin at Scott's Hot Rods. When I mocked it all up it worked just fine.
Juan
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
04-13-2014, 08:01 AM | #7 |
I am going to have to look into this when I put the Gear Vendors OD in the 1968 Suburban. I wonder if I can use the same 2 piece shaft that is in my 67 C 20 It has a slip yoke at the trailing arm cross member.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
