Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 06-01-2016, 10:15 AM   #1
63frankintruck
Best bargain sound deadner/ heat shield
What is most economical sound deadner heat shield for inside firewall area? Any suggestions appreciated
63frankintruck is offline   Reply With Quote
Old 06-01-2016, 09:15 PM   #2
Jarwood
Jarwood's Avatar
Re: Best bargain sound deadner/ heat shield
I used Fat Mat. Done all interior minus the roof for about $150.00
Jarwood is offline   Reply With Quote
Old 07-22-2016, 06:14 PM   #3
Diggerdan11
Diggerdan11's Avatar
I used Fat Mat on my 03 Silverado Crew Cab. I did 2 layers on the floor, and 1 layer on all the doors, and it was still cheaper than the next competitor. I will definitely be using Fat Mat on my 69 and my 77
1969 Chevy C/20 Project- Re-built 350 (more info to come) http://67-72chevytrucks.com/vboard/s...=1#post6377987
1977 Chevy K20 Silverado Camper Special- Future Project
1969 Chevelle Malibu
2011 Yukon XL Denali
2013 VW Passat TDI (Daily)
Diggerdan11 is offline   Reply With Quote
Old 07-24-2016, 05:40 PM   #4
bestchevyfan
Where did you get it ?
bestchevyfan is offline   Reply With Quote
Old 07-24-2016, 06:05 PM   #5
Diggerdan11
Amazon
Old 07-25-2016, 03:20 AM   #6
tinydb84
tinydb84's Avatar
If you want to decrease sound you need to go with CCF and MLV. Those stick products are to decrease resonance not block sound.
David
Instagram: myfabguy
Old 07-25-2016, 02:36 PM   #7
Hart_Rod
Hart_Rod's Avatar
Where do you purchase it? How do you install it? Do you put it over the Fatmat?
Hart_Rod is offline   Reply With Quote
Old 07-25-2016, 03:07 PM   #8
tinydb84
tinydb84's Avatar
Here is a great thread on it: http://67-72chevytrucks.com/vboard/s...d.php?t=559596
and another post about it: http://67-72chevytrucks.com/vboard/s...5&postcount=54
Here is a good website that explains it all: https://www.sounddeadenershowdown.co...-vehicle-quiet
You can get it all online. The issue is that MLV is heavy. You can get different pounds per square foot but the shipping is what kills you. If you can find it locally you are golden.
Its kinda hard to work the MLV in tighter spots and depending on what you have close to the floor you might have some clearance issues (gas peddle). Ideally you would want it completely connected. I have used it on other people cars and it makes a huge difference.
David
Instagram: myfabguy
Old 07-26-2016, 03:01 PM   #9
neverfinished52
neverfinished52's Avatar
I used the advice from sounddeadener showdown and I used Noico on my floors for the vibration dampener & ccf
https://www.amazon.com/Noico-deadeni.../dp/B00URUIKAK
https://www.amazon.com/gp/aw/d/B00UR...?ie=UTF8&psc=1
For the mlv I used this product from Home Depot
http://m.homedepot.com/p/4-ft-x-8-ft...96BX/100663624
neverfinished52 is offline   Reply With Quote
Old 07-30-2016, 10:41 AM   #10
Sturvin
It says drywall not included, sorry, but that's a deal breaker.
Sturvin is offline   Reply With Quote
Old 08-14-2016, 09:15 PM   #11
BC10
BC10's Avatar
In terms of sound damping this is some of the best stuff. And a good price. http://store.secondskinaudio.com/b-stock/
BC10 is offline   Reply With Quote
Old 08-16-2016, 08:10 AM   #12
Low Elco
W.R. Grace Ice and Water shield. Home depot online.
Low Elco is offline   Reply With Quote
Old 08-16-2016, 08:44 AM   #13
calvin78612
calvin78612's Avatar
GTMATT on Amazon.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 08-16-2016, 09:37 AM   #14
AnotherWs6
AnotherWs6's Avatar
That first thread is interesting. Three layers though?! I'd be worried about how it all fit back together. Especially on the roof which I desperately need to do. Need to do all of it really. Even after quieting the exhaust down it's tough to talk to my wife, especially when she rides in the back with my daughter.
And will any of that stuff that he used help with heat? I get a lot of heat from the firewall and front floor. I have a cigarette lighter usb charger for my phone that displays volts and temp. (I dunno why it shows air temp but it does so ok) and it settles in around 107 degrees if it's not too hot out. So a couple of feet away from the firewall and a couple of feet off of the floor, it's getting HOT!
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 08-26-2016, 07:30 AM   #15
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
I used FatMat also, highly recommend it.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 08-26-2016, 03:59 PM   #16
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
times 3..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 08-27-2016, 10:40 AM   #17
Sturvin
Does anyone have any recommendations when it comes to the kick panels? How would you block noise from there?
Old 09-13-2016, 10:40 AM   #18
NJ C10 Guy
Go to sound deadener showdown and get their CLD Tiles. I think I spent a little over $100 for my '86. I was able to find MLV locally and got more than I needed for $65. The CC foam I got for around $20. It's work, but when done correctly there isn't much better you can do.
Edit: I jut saw you're in westchester, NY. The place I got my MLV from was in Montclair, NJ which isn't too bad of a drive.
NJ C10 Guy is offline   Reply With Quote
Old 09-13-2016, 10:52 AM   #19
AnotherWs6
AnotherWs6's Avatar
Thanks. Not ready yet but when I am I will check it out.
Old 09-13-2016, 10:55 AM   #20
NJ C10 Guy
Sounds good. Just check craigslist, that's where I found mine.
Old 09-17-2016, 11:36 AM   #21
Domer
Domer's Avatar
I to have fatmat in both of my trucks. And the biggest proem I found, is it doesn't resist heat well. I had 3 layers on the passenger side, which is where the exhaust runs on my dually, and it got so hot towing through Nevada, that it melted the fatmat and my wife couldnt put her feet on the floor. I also had a bagged and body dropped c10, that I ran 2 layers of fatmat, and the same problem, it melted to the carpet and didn't resist heat. Works great for sound control and reducing rattle. If you use it, I recommend using a foam with some sort of heat control.
Project Roxy...
Shes Bad, Low, and Blown...
http://67-72chevytrucks.com/vboard/s...d.php?t=673333
Domer is offline   Reply With Quote
Old 09-17-2016, 01:26 PM   #22
Hart_Rod
Hart_Rod's Avatar
What do you recommend?
Old 09-17-2016, 02:48 PM   #23
Domer
Domer's Avatar
Lay the fatmat for sound and rattle insulation. Then use a foam with a foil to reflect heat. I have foam from a generator enclosure on a yacht, it is 1" thick, with lead shielding, and thick reflective foil. Floor stays cold.
Here's a quick link I found.
http://www.boatstoreusa.com/engine-p...03oaAqwS8P8HAQ
Project Roxy...
Old 09-17-2016, 09:25 PM   #24
lsversaw
lsversaw's Avatar
Here's a source that is mentioned on corvetteforum.com, but I have not compared prices:
http://www.raamaudio.com/small-suv-crossover-hatchback/
Scott
1972 C20 long-wide. 350/350, Cheyenne Super, wood bed, PS, PB, dual batteries, dual tanks, leaf springs, gauges. No significant rust. No significant paint.
1971 C10 short step. Originally a 250/3ott with no options, now a 350/4L80. I purchased it already restored; only needs about 300 little details fixed.
lsversaw is offline   Reply With Quote
Old 09-21-2016, 10:34 PM   #25
Sturvin
Has anyone used the kit available from brothers?
https://www.brotherstrucks.com/67-72...tinfo/DSD72TF/
