Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-08-2017, 05:33 PM   #1
lower50's
lower50's's Avatar
How to swap your sealed 7" to LED
I converted my 7" sealed beam headlights on my '52 GMC to LED bulbs.
I will put links to the parts I used, and pictures on what I had to do.
I have now put the same LED bulbs in 3 different vehicles. My friends '07 Jeep, my '67 Jeep, and my '52 GMC all with great results. I'll just say the bulbs work from 9V-32V so if you have a 6V truck it probably won't work.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-08-2017, 05:54 PM   #2
lower50's
lower50's's Avatar
Re: How to swap your sealed 7" to LED
I will be showing some pictures of my Jeep's lights sometimes but the conversion is the same.
This is the LED bulbs I bought.
http://www.ebay.com/itm/Philips-LED-...NZDB8e&vxp=mtr
I also bought new H4 headlight plugs from my parts store they where $6 ea.
1951 MG TD
Old 05-08-2017, 06:02 PM   #3
lower50's
lower50's's Avatar
You will also need a after market headlight lens/reflector. I used different ones in my Jeep and GMC it's really personal preference. Both mine use a H4 bulb. You can also find a lens from a newer Jeep 07-15 should work.
First 2 are my GMC
Second 2 are my Jeep
1951 MG TD
Old 05-08-2017, 06:17 PM   #4
lower50's
lower50's's Avatar
As for installing it is really quite easy. The H4 ring comes off the bulb install it into lens.
Then you may have to trim the rubber but push it on.
Click LED back into ring.
1st ready to go, don't worry about the wires they are for my headlight rings
2nd H4 ring installed
3rd rubber pushed on
4th Led bulb clicked back into place.
The last pick is from my Jeep I cut off the red and black you see.
GMC http://www.ebay.ca/itm/7-ROUND-DIAMO...item56993ba35f
Jeep http://www.ebay.ca/itm/86-95-Suzuki-...item4ac7f40961
1951 MG TD
Old 05-08-2017, 06:25 PM   #5
lower50's
lower50's's Avatar
After that you should just be able to install like any other stock headlight. Just plug in and go.
This is a low and high beam shot from my GMC
And a low and high beam shot from my Jeep for comparison.
They are so nice and bright white, easy to see everything. Also the street signs glow.
1951 MG TD
Old 05-08-2017, 07:44 PM   #6
oldman3
oldman3's Avatar
Lower, nice how to on the LED set-up...Jim
oldman3 is offline   Reply With Quote
Old 05-08-2017, 07:48 PM   #7
crossfire84
crossfire84's Avatar
Nice job there.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 05-09-2017, 12:49 PM   #8
Hart_Rod
Hart_Rod's Avatar
Good write up. Did you see any difference on your electrical system? Since the LED draws a lower current, did you change your headlight fuse to a lower rating?
Hart_Rod is offline   Reply With Quote
Old 05-09-2017, 03:11 PM   #9
lower50's
lower50's's Avatar
Ya voltage gauge dropped a bit before now it doesn't move at all. No I left the fuse the same, won't hurt. The fuse will still blow if there is a short.
1951 MG TD
Old 05-09-2017, 03:53 PM   #10
Hart_Rod
Hart_Rod's Avatar
Thanks, good to know. I was thinking about putting in a 15-20 amp fuse, just as a precaution.
Old 05-09-2017, 04:13 PM   #11
lower50's
lower50's's Avatar
It's always a good idea to have fused circuits even if is higher amp than the draw.
1951 MG TD
Old 05-10-2017, 03:11 AM   #12
mongocanfly
Post Whore
mongocanfly's Avatar
Any preference ,one over the other ,style you did? Led ring vs, not
Old 05-10-2017, 08:45 AM   #13
Hart_Rod
Hart_Rod's Avatar
Agree 100% on all your circuits being fused. And just in case I wasn't clear, I didn't mean not to use any fuses, I just mean to drop the standard headlight fuse down from 30A to 20A.
Also, are you worried that the rubber seal around the bulb will get hot and melt? I know the heat sink of the bulbs get pretty hot. Here's a picture of mine installed. Thanks again for all of the info!
Here's the lights I purchased:
http://www.ebay.com/itm/322177905990...AIT&rmvSB=true
Old 05-10-2017, 09:26 AM   #14
Custom 68
Custom 68's Avatar
Nice write up. I thought about this on mine as the actual LED complete headlights are super expensive. Mine work great now so I will probably leave them for now as they are.
But these look nice.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-10-2017, 03:41 PM   #15
lower50's
lower50's's Avatar
Not really...I like the ring on my truck and the clear on the Jeep, both seem to work very well. Comes down to personal preference really.
Ya I knew what you meant. Making sure for everyone else. The lights you got look nice. As for the heat these don't get to hot, but any LED will be cooler than the original incandescent H4.
Ya man, the complete LED light's are crazy. Nice to know there are options.
1951 MG TD
Old 06-21-2017, 10:23 PM   #16
Dan in Pasadena
Dan in Pasadena's Avatar
L50's, THANKS SO MUCH for the link to the thread! I wasn't sure I liked what I saw of the lenses until I saw the finished installation on the '72. That looks like exactly what I want.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-22-2017, 08:14 PM   #17
lower50's
lower50's's Avatar
That's why we are all here Dan
1951 MG TD
Old 06-22-2017, 08:48 PM   #18
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice write up Lower. One other nice feature of these LED type bulbs is most of them have a cooling fan in the back of them to keep them cool and to prevent pre mature failure.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
7" bulb, convert, how to, led, swap
