Old 06-08-2017, 08:22 AM   #1
PortHeadlight
PortHeadlight's Avatar
Another headliner installation - FINALLY
Finally got it together. I picked up in Bow, New Hampshire from Kal-Lite. They don't make headliners, they make Fiberglas Reinforced Plastic. Went there because they offer several choices of color and pattern, and I wanted to see what they looked like in real life. FRP is the same material used in other headliner install threads. You can get it at big box stores - only in limited colors and patterns. Went with the Hexpin pattern in gray because it was exactly what I wanted when I saw it, but they offer many choices. I used the .060 FRP because .090 thickness of the Kal-Lite product was simply too rigid and less flexible.
http://www.kal-lite.com/frp-products/frp-colors.html
Used my own pattern from old headliner and cut to fit using 32 teeth / inch blade in saber saw. Other threads describe the process of "cutting to fit" and making adjustments, and that's what I followed. Also two pairs of hands often needed. Measure twice, cut once. Actually, measured like 10 times and cut slightly big, then trimmed to fit. HA!
Was lucky to have plastic bows BUT they were very brittle and already cracked. Tried superglue. No joy. A couple missing edges but aint perfect, but it's up and not coming down soon. Did warm up with heat gun and that helped...BUT when somebody starts making these will definitely get a set.
And added a rear dome light by splicing into the front dome light wire and installing a front bracket I got from a member and the dome light kit from one of our vendors.
PortHeadlight is offline   Reply With Quote
Old 06-08-2017, 08:24 AM   #2
PortHeadlight
Re: Another headliner installation - FINALLY
Also added "fit trim edge" from Grainger. Item number 48RM13 comes in 25 foot rolls which is enough to do sides and front above visors.
Old 06-08-2017, 08:55 AM   #3
chris mc bride
chris mc bride's Avatar
Looks good. Sounds as if fairly economical also. Hard pair to beat right there.
Only the stupid know too much to learn something new.
chris mc bride is offline   Reply With Quote
Old 06-08-2017, 09:50 AM   #4
nastety92
Headliner looks good, nice job. Got any more pics of your truck? I'm hoping to have my Suburban on the road soon and we spend a lot of time up in York, ME.
Nick
nastety92 is offline   Reply With Quote
Old 06-08-2017, 02:16 PM   #5
nate_g_2003
nate_g_2003's Avatar
Looks really nice. Thanks for the write up, information, and pictures.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
Old 06-08-2017, 07:00 PM   #6
LuckyScott
LuckyScott's Avatar
Looks great
LuckyScott is offline   Reply With Quote
Old 06-11-2017, 01:19 PM   #7
Average Joe
Average Joe's Avatar
Beautiful
Great job!!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 06-11-2017, 09:15 PM   #8
HO455
Post Whore
HO455's Avatar
Looks real nice (as does the rest of your Burban). I was looking at their stuff on line and trying to find a local distributor just to check it out. Lucky for you they were local. Thanks for the tips on the thickness of the product and cutting it. If you don't mind what was the cost?
RIP Bob Parks.
Old 06-13-2017, 02:18 PM   #9
Hart_Rod
Hart_Rod's Avatar
Well done!
Hart_Rod is offline   Reply With Quote
Old 06-13-2017, 05:34 PM   #10
PortHeadlight
I don't mind. Picked up at the plant, a 4 x 8 sheet was $48.00. As you may know... the width of the headliner is such that it takes a sheet for the front piece, a sheet for the back piece, and a sheet to make the two middle pieces.
they do sell the material in rolls, but I think that would be in a quantity purchase. the guy that helped me was Brian Barker at Kal-Lite. Don't know if I should post any more info to avoid any problems with vendors and such, but I'm sure you can find him easy enough. He wanted the pictures of the finished work and may post them on the company website.... who knows?? Good Luck!
Old 06-13-2017, 09:08 PM   #11
HO455
Post Whore
HO455's Avatar
Thank you for all the information.
RIP Bob Parks.
Old 06-22-2017, 04:34 PM   #12
hdman6465
hdman6465's Avatar
Looks very nice. Thanks for taking the time to write it up, photograph, and describe the process so that some of us slower ones can follow you. Thanks, again.
72 C10 suburban, lowered,nice original
55.1 Panel, bagged,old school
56 Panel,ls power,frame up build
72 C30 enclosed car hauler, 454,FI,4L80E
hdman6465 is offline   Reply With Quote
Old 08-02-2017, 12:10 AM   #13
HO455
Post Whore
HO455's Avatar
You are really lucky to have the factory close to you. I have called every supplier in the area using my contractor discounts, they only able stock FRP in white or black in the bubble or smooth surfaces. Any other choices like the one you used would cost $4-500 for delivery to Portland. That puts it out of the budject for me. I may go the big box FRP route and try to paint it prior to installation.
RIP Bob Parks.
Old 08-10-2017, 04:19 PM   #14
AnotherWs6
AnotherWs6's Avatar
How were your factory bows? Mine are kinda rough, would love to find some replacements...
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 08-10-2017, 10:38 PM   #15
LockDoc
The Older Generation
LockDoc's Avatar
Don't know if you saw this thread or not.
http://67-72chevytrucks.com/vboard/s...t=plastic+bows
And I don't know if anyone figured out exactly what year van they were out of....
LockDoc
Leon
Old 08-11-2017, 09:27 AM   #16
AnotherWs6
AnotherWs6's Avatar
Wow, interesting. Thanks. I wonder how they would look in 100% factory (read=not modern) interior.
Old 08-11-2017, 05:12 PM   #17
PortHeadlight
Of the factory bows.... two worked out OK and the other was pretty beat up. Heating with heat gun was a good tip, but even then VERY brittle and none of them are 100% complete. But work. Would consider shifting if we could ID the van and find them.
