ATTN LS Swap guys! Over the counter swap radiator!
With so many people converting to LS engines these days, I thought this would be useful for many of you! I found this out during the LS swap on my '78 Chevy.
Murray makes an over-the-counter replacement radiator that is LS swap ready! The part number is 433161 (I believe I purchased this at Oreilly's), and it includes a 1/8" NPT port between the transmission cooler ports, which is an identical position that the steam line runs to from the factory. All you need is a 1/8" NPT to 1/4" barb adapter, and you can run a 1/4" rubber line directly from your steam line on the engine to the radiator! ![]() ![]() ![]() I purchased these from Autozone. 072010 is the 1/8" NPT to 1/4" barb adapter. 071910 are block off caps for the transmission cooler. ![]() ![]() I hope this helps someone! |
Re: ATTN LS Swap guys! Over the counter swap radiator!
Nice, thanks! What was the application for this, square body?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
Yes, squarebody. Another thing I should mention, this radiator works with stock Silverado hoses, such as 2002 Silverado 1500 5.3L upper and lower hoses.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
![]() Join Date: May 2010
Thanks for the info
It only has original paint once |
Thats handy. I'm running the stock 34" core radiator from a 2006 Yukon but it means I've got the surge tank rather than a standard radiator cap. Excellent find.
Has anyone used this radiator? Any problems cooling with A/C?
Thanks |
chevy truck fan
nick, thanks for the info...
![]() Join Date: Apr 2005
+1
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
