Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-27-2008, 01:08 PM   #126
VA72C10
VA72C10
VA72C10's Avatar
Re: LFD's 4dr Burb Build
Glad to see this is going to get completed...Still planning to sell it when done or will you keep it as the shop hauler?
Old 12-27-2008, 02:55 PM   #127
Rokcrln
Rokcrln's Avatar
WOW no one said anything about completion just more progress
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-27-2008, 03:48 PM   #128
XXL
Seņor Member
XXL's Avatar
Originally Posted by Rokcrln View Post
Well as my ADD kicks in again it looks like this project will go under the knife once again
Mike was too chicken to do the right thing... but I know you're not. Let's get some Lambo doors on that thing, and pronto!
XXL is offline   Reply With Quote
Old 12-27-2008, 04:58 PM   #129
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 12-27-2008, 05:03 PM   #130
Rokcrln
Rokcrln's Avatar
You know if you go and give all my tricks away then what is the point of even doing it!
Kevin
LFD Inc.
Old 12-27-2008, 05:11 PM   #131
brad2
I sure wanted to buy it and have you shorten it but it is not in the budget. Grrrr!
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
Old 12-27-2008, 05:16 PM   #132
Hart_Rod
Hart_Rod's Avatar
Well as my ADD kicks in again it looks like this project will go under the knife once again It was not selling like I thought it would and instead of dropping my price to a stupidly low amount I figured I might as well put in more time and shorten things up a bit. It is back in the shop and currently getting some layout marks before getting cut apart.
I will be following Mike's surgery directions but I am going with slightly different proportions and I will only be cutting my frame in the rear even know I am shortening the wheel base as well. The plans are for a 4 link of some design for the rear to be decided on at a later date. Since I am only going to shorten the WB by 9 3/4" their is no real reason for me shorten the center of the frame when I can do it all on the back end. This will also eliminate the need mods to the floor under the second row seat.
First step is going to be cutting the rear wood floor out so I can gain access to remove tubs, tire well and misc braces. Then body slice and dice time will begin. Pic's to follow but not allot because I think Mike did such a great job documenting his their is no reason to do it twice since I am following his as well for parts of this next process.
Kevin
LFD Inc.
Glad to hear this Kevin. You may have just saved me from the big "D", .
Hart_Rod is offline   Reply With Quote
Old 12-27-2008, 09:38 PM   #133
Rokcrln
Rokcrln's Avatar
Not to bad for one days work. I shortened the wheel base 9 3/4" and brought the wheel wells up the same. Next will be to mark and cut the rear of the body off then shorten the frame 19 3/4". This will give me a rear over hang 2" longer than a short bed. I think with the wheel base this will look the best.
Kevin
LFD Inc.
Old 12-27-2008, 10:00 PM   #134
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Also Glad to See you Back on this Project.............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 12-27-2008, 10:01 PM   #135
VA72C10
VA72C10
VA72C10's Avatar
WOW, you'll be finished in no time...oh wait, ..... I forgot,..... you're not finishing......
Old 12-27-2008, 10:05 PM   #136
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Whoa! Tahoe! The 3rd one too! Is it gonna stay 3/4 ton? or are you gonna put it different axles?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-27-2008, 10:42 PM   #137
thelonerife
thelonerife's Avatar
since its gonna be shorter and less burb is the price going to decrease?
thelonerife is offline   Reply With Quote
Old 12-27-2008, 11:36 PM   #138
desertrat
desertrat's Avatar
WOW, youre cutting up my Suburban
I will definetly keep an eye on this project. You make it look so easy!
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 12-28-2008, 12:26 AM   #139
corn
Done yet?
Amazing work as usual!
corn is offline   Reply With Quote
Old 12-28-2008, 12:36 AM   #140
lolife99
67-72 parts collector,…
lolife99's Avatar
Subscribing again!
Keith
Convert to disc brakes.
Old 12-28-2008, 02:57 AM   #141
tdave00
Restoring a 68 SWB
tdave00's Avatar
Looking good. My bet is that you end up keeping it . How you gonna let go of a 4 door 67-72 Tahoe unless the money is outrageous?
tdave00 is offline   Reply With Quote
Old 12-28-2008, 04:09 PM   #142
Rokcrln
Rokcrln's Avatar
Taking shape! How do you like the proportions?
Kevin
LFD Inc.
Old 12-28-2008, 04:15 PM   #143
Cyclone
Cyclone's Avatar
Proportions look great, subscribed.
Cyclone is offline   Reply With Quote
Old 12-28-2008, 04:37 PM   #144
tdave00
Restoring a 68 SWB
tdave00's Avatar
Looks good from here! So you just moved the crossmember forward and cut the frame off in the back? Are you still planning to notch the frame or not?
Old 12-28-2008, 04:55 PM   #145
VA72C10
VA72C10
VA72C10's Avatar
Proportions look perfect. That's the only way I'd have a Burb if it became a Tahoe...they look so much better IMHO. I know many love them full size and I'm sure the storage is awesome, but a bit too long to me.
Old 12-28-2008, 06:06 PM   #146
67ChevyRedneck
67ChevyRedneck's Avatar
Very cool
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-28-2008, 06:32 PM   #147
Looking great Kevin!!
Always interesting watching you do your thing.
Old 12-28-2008, 07:22 PM   #148
Rokcrln
Rokcrln's Avatar
Yes I did it this way because I will be running all new front and rear suspension and a large notch to get it way down.
Yes the storage was great but it still has plenty. If all works out I will have a third row of suitcase seats, second row bench out of a newer Tahoe and front buckets out of the same.
Thanks guys!
My wife (and I) want to check into re skinning the roof with a new flatter one off a different vehicle maybe with ribs or something. So I will get some dimensions and start roaming the parking lots
Kevin
LFD Inc.
Old 12-28-2008, 07:30 PM   #149
VA72C10
VA72C10
VA72C10's Avatar
Kevin
LFD Inc.
I think that sounds like a great idea. THe ribs will add strength and yet another subtle touch to set it apart.
Old 12-28-2008, 07:57 PM   #150
thirdstreettito
Resident of Here
I like it all, I just wouldn't have cut into the door.
~Bradley~
Miss having a truck
