Old 03-30-2010, 11:14 PM   #26
boonedogs72
boonedogs72's Avatar
Re: Bowtie468's Extreme '68 BuildPage
love it! i have 31x18.5 15 on the back of my pickup and they do look nice stuffed up in there
boonedogs72 is offline   Reply With Quote
Old 03-31-2010, 11:27 AM   #27
superflysteiny
superflysteiny's Avatar
nice build
superflysteiny is offline   Reply With Quote
Old 03-31-2010, 11:29 AM   #28
67cheby
67cheby
67cheby's Avatar
is the chevy emblem on the dash going to be lit also ??
67cheby is offline   Reply With Quote
Old 03-31-2010, 01:46 PM   #29
Bowtie468
Bowtie468's Avatar
I've thought of a thousand ways to finish that bowtie, but i have yet to make a final decision on it. I think i'd prefer for it to blend with the surroundings and not really scream "look at me". I dont have a pic to show, but one thing i did was roll a piece of sheetmetal to tightly fit the contour of the dash directly behind it, then painted the same as the dash. When in place it looks like the bowtie was milled into the dash.
If anyone would like to offer suggestions on it, fire away !!
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 04-06-2010, 05:57 PM   #30
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Bowtie468 View Post
Also, i didn't want the truck disabled in the event of an air system failure. Designed and fabbed up these stops, which presently bolt in. I'll eventually weld them to the upper bag plates and adding a teflon button to the lower arms to keep them from getting scratched.
Sweet build! How much would you charge to make a couple extra stops?
Hart_Rod is offline   Reply With Quote
Old 04-06-2010, 06:32 PM   #31
Dynomutt
Dynomutt's Avatar
Lot of nice things you've done there. I really like the latest wheel and tire combo.
What headers are you running?
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 04-06-2010, 07:28 PM   #32
Bowtie468
Bowtie468's Avatar
Thanks ! Marq
The headers are Hooker #2455 with 2" tubes. These are early Chevelle headers and they fit great. One tube comes real close to the lower control arm on the driver side, since adding the tubular arms. Factory lowers had plenty of clearance.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 04-06-2010, 08:26 PM   #33
Bowtie468
Bowtie468's Avatar
PM sent, Rob !
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 04-07-2010, 11:41 AM   #34
Dynomutt
Dynomutt's Avatar
Thanks for the header info Chris.
MARQ
Build Thread
Old 04-07-2010, 12:06 PM   #35
Hart_Rod
Hart_Rod's Avatar
Maybe I missed it, but what size of wheel and tire (brand) are you running in the front?
Old 04-07-2010, 10:45 PM   #36
Bowtie468
Bowtie468's Avatar
Rob, the front combo consists of 18x8 BS Bullets with 26x10x18 M/T Sportsman S/R's. Backspacing is 5.5 inches.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 04-12-2010, 04:01 PM   #37
Hart_Rod
Hart_Rod's Avatar
Thanks! I can't make up my mind between the 28 x 8's or the 26 x 8's for the front... But you have convinced me to go with the 31 in the back....
Old 04-12-2010, 04:14 PM   #38
lks dcvn
lks dcvn's Avatar
I really like that brake light [and the rest of the project] - hell of a nice job so far.
lks dcvn is offline   Reply With Quote
Old 04-13-2010, 01:42 PM   #39
Bowtie468
Bowtie468's Avatar
Rob, i pondered that same question over and over. If you check out Eric D's " Silver Bullet " build page in this section, you can get a real good look at 26" Sportsman S/R's on the front, from a lot of different angles .
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 04-23-2010, 01:22 PM   #40
HuggerCST
HuggerCST's Avatar
VERY nice Chris! I've been waiting to see it together for a long time. I knew that it would be nice, but I never imagined it being THAT awesome.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 04-23-2010, 03:47 PM   #41
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Awesome build!!!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-26-2010, 09:51 PM   #42
Bowtie468
Bowtie468's Avatar
Here's a little footage of the engine.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 04-26-2010, 10:12 PM   #43
sourkraut
sourkraut's Avatar
sounds great, do you have a gear drive?
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 04-26-2010, 10:53 PM   #44
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Nice! sounds sweet
Now I need to go back and read your engine specs again..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 04-27-2010, 12:41 AM   #45
Newtz67
Newtz67's Avatar
Great info on the headers. So they will fit into a stock frame with no modification? They look like they tuck up in they frame pretty well, how much do they show below the frame? Thanks!
Newtz67 is offline   Reply With Quote
Old 04-27-2010, 12:03 PM   #46
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
And here I am proud of my junkyard build! Very nice work, that 468 sounds very nice! 6,000 right now! I think my plow rig needs one of those...
propanemudtruck is offline   Reply With Quote
Old 04-27-2010, 12:24 PM   #47
splehigh
splehigh's Avatar
That is going to be one sweet truck! That 3rd brake light is awesome! Keep us updated.
splehigh is offline   Reply With Quote
Old 04-27-2010, 09:30 PM   #48
Bowtie468
Bowtie468's Avatar
Sure does, it's a Pete Jackson drive.
Yes, they do fit well without any mods. I'm using 68-71 big block towers. The tightest area is at the lower control arm on the driver side. Probably about 3/4" clearance since i added the Ridetech arms. Factory a-arms had plenty of clearance. Here's a few pics of both sides so you can get a visual on it.
Oh, they also stay tucked nicely inside the frame rails.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 04-27-2010, 10:08 PM   #49
Newtz67
Newtz67's Avatar
Thank you very much! I'm pretty sure I'm gonna go with those as well. That engine sounds great!
Old 04-29-2010, 11:39 PM   #50
highperf4x4
Simply amazing!
I am subscribed.
highperf4x4 is offline   Reply With Quote
