07-05-2013, 09:05 PM | #151 |
Re: Project "Shifted"
If you install lower motor mounts won't that raise the rear of the tails haft and make that angle worse? Or are you going to lower the entire assembly, motor and trans together to keep the same angle?
Frank Posted via Mobile Device
Born and proudly residing in a Red State ! |
07-05-2013, 09:23 PM | #152 |
How come when I come over there is no beer on that cowl.......? Lol. Ill bring them next time.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
07-05-2013, 09:39 PM | #153 |
That's what I was wondering , the angle being 5 degrees is right . So did Nate think you might have just got the wrong motor mounts? Because mine set up at 5 degrees the trans x member is lower than yours. Mine looks like floppydoodle's
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
07-05-2013, 09:48 PM | #154 |
Bennett--G4L mine is a little less than halfway. Actually you can see where I had to shim the tail shaft up so my headers wouldn't hit my control arms. I am machining a 5/8 aluminum spacer to slide in there.
Posted via Mobile Device |
07-05-2013, 10:18 PM | #155 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-05-2013, 10:48 PM | #156 | |
07-05-2013, 11:22 PM | #157 |
Rob mine is at 5* like RRC and the carrier bearing is 2-1/2" shimmed up. From the tail shaft to the carrier bearing it runs parallel to the the frame.
07-05-2013, 11:47 PM | #158 | |
07-06-2013, 12:15 AM | #159 |
I'll get pics and measurements tomorrow.
07-06-2013, 12:19 AM | #160 | |
07-06-2013, 09:51 AM | #161 |
PROJECT 7DEUCE
Im tuned in on the driveline action... I agree there needs to be a good write up soon..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-06-2013, 07:25 PM | #162 |
Rob my motor mount measures 8" from center of the lower hole to the top edge of mounting plate......
07-06-2013, 07:31 PM | #163 |
Posted via Mobile Device Here is a pic from the front ....the motor is not set at 5 degrees in this pic.....
07-06-2013, 08:23 PM | #164 | |
07-06-2013, 08:50 PM | #165 |
The surface of the tail shaft
07-07-2013, 09:28 AM | #166 |
Thanks Russ. Can you get one more measurement from the centerline of the lower engine mounting hole to the centerline of holes that the lower A frame bolt to? TIA
07-07-2013, 09:32 AM | #167 |
67-72 parts collector,…
I assume everyone is getting their "5 degrees down" measurement with the frame rails level and not setting on the wheels?
07-07-2013, 09:41 AM | #168 |
That measurement is 4.5" .....I measured from the top of the lower control arm tube to the center or of the lower motor mount hole....
07-07-2013, 09:56 AM | #169 |
A day late and $1 short...
Good point Keith!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
07-07-2013, 10:01 AM | #170 |
That's the only way to compare "apples-to-apples", here.
07-07-2013, 10:16 AM | #171 | |
Yep Thanks Keith, that's what I'm using as the reference. I should have mentioned it before. Posted via Mobile Device
07-07-2013, 11:45 AM | #172 |
Yes my frame is level as well.....I wonder why there would be 1/2" difference ?
07-07-2013, 12:06 PM | #173 |
Posted via Mobile Device Sorry Rob.....when you said yours was 5 I double checked and it is 5
The frame is still level the other question should be is the 5 degrees measured with the frame level or ride height ? Posted via Mobile Device
07-07-2013, 01:25 PM | #174 |
Mine is with frame level.
07-07-2013, 02:23 PM | #175 |
I have also heard that it should be measured at ride height ...not sure which is correct though. I could not lower my engine or the rack would hit.
Posted via Mobile Device Posted via Mobile Device
