Old 01-13-2015, 02:57 PM   #1
Coursey
Coursey's Avatar
"Brass Monkey".....Installing 4/6" ECE Drop Kit
Just received my ECE kit.
Found out the rear lower shock brackets are backordered. Should be here in a few days.
Went ahead and removed the upper shock brackets. Not to bad to do. Just cut an X in the rivet head and knock it off with an air hammer. Then punch out the rivet with the air hammer.
Coursey is offline   Reply With Quote
Old 01-13-2015, 02:59 PM   #2
Coursey
Coursey's Avatar
Re: "Brass Monkey".....Installing 4/6" ECE Drop Kit
I lubed all the bolts with Kroil once a night for about 3 nights that i haven't been able to work on it.
Hope this helps knock them free.
Old 01-13-2015, 03:06 PM   #3
TexasLS1
TexasLS1's Avatar
Love your truck, I'll follow along to see the results
TexasLS1 is offline   Reply With Quote
Old 01-13-2015, 04:34 PM   #4
Hart_Rod
Hart_Rod's Avatar
fun project.
Hart_Rod is offline   Reply With Quote
Old 01-13-2015, 04:59 PM   #5
67 cst swb
67 cst swb's Avatar
This is setting up to be a great before and after example.
You should show some current measurements and tire sizes.
That seems to be the most asked questions. Then people can do the math for drop totals.
Just a suggestion.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red
67 cst swb is offline   Reply With Quote
Old 01-13-2015, 05:20 PM   #6
Ekliptix
Ekliptix's Avatar
GREAT looking truck, love the color and upper/lower trim option. Nice workspace and setup with the plastic sheet too. Glad you already got the upper rear shock mounts off. That was the hardest part for me, installing the same kit. Holler if you have any questions. Looking forward to the after.
Btw, you can go an extra 1/2 lower in the front if you exchange the 1.5" front drop springs from the kit for 2" front drop springs that ECE carries. They did this for me, I paid for shipping. If you're worried about a rake, you can put small lowering blocks in the back.
Ekliptix is offline   Reply With Quote
Old 01-13-2015, 06:24 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Short boxes for me are not the everything truck they seem to be for lots of people and I actually prefer the steppers in a short box but I love your truck. The colour combo is great and it being a Cheyenne makes it better. It should look super when you get it lowered. Post up some interior pics as I'm sure we'd love to see them and of course more when you get it lowered.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-13-2015, 08:05 PM   #8
Coursey
Coursey's Avatar
Upper brackets on.
Right now the upper spring bolts are a major PITA! Still don't have one off after about 30 min. Thinking about saw sawing it off and just buying a new grade 8 bolt. Suggestions?
They have been soaked in kroil over several days.
Old 01-13-2015, 08:54 PM   #9
Mike C
Mike C's Avatar
What a great looking truck! I had a '70 GMC C2500 Sierra Grande that color combo, so I'm a fan. Looking forward to pics of it lowered. I just did my 69 short step and am absolutely amazed at the change!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-13-2015, 09:11 PM   #10
Ekliptix
Ekliptix's Avatar
Originally Posted by Coursey View Post
Upper brackets on.
I'm not familiar with kroil but I sprayed WD40 Penetrating spray on everything in advance and was able to loosen everything ok. WD-40 300007 Specialist Rust Release Penetrant... WD-40 300007 Specialist Rust Release Penetrant...
Old 01-13-2015, 09:33 PM   #11
Coursey
Coursey's Avatar
http://www.kanolabs.com
Old 01-14-2015, 08:33 AM   #12
Coursey
Coursey's Avatar
Old 01-14-2015, 08:35 AM   #13
Coursey
Coursey's Avatar
It needs a period correct steering wheel.
If anyone has a nice one please PM me.
Old 01-14-2015, 08:58 AM   #14
nlped
nlped's Avatar
Great looking truck for sure!
And, yes you can cut off the existing bolt and just replace it with a grade 8 nut, bolt, washers & lock washer as the existing bolt will be hammered even if you do get it off finally. I always replace them just for the peace of mind that I've got new hardware in place. Just my .02...
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-14-2015, 10:21 AM   #15
EdSevered
EdSevered's Avatar
Watching this thread...this project is on my bucket list.
Oh yeah, really, really nice truck and WOW what a CLEAN garage. Last time I saw plastic spread out on a garage floor like that, Joe Peschi was about to get whacked in Goodfellas. -Ed
EdSevered is offline   Reply With Quote
Old 01-14-2015, 10:33 AM   #16
ERASER5
ERASER5's Avatar
Kroil. Making WD40 look like cat pee for 50 years.
Oh, awesome truck. Love the color.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-14-2015, 10:54 AM   #17
Already Gone
I se the spid says olive trim and your seat and door panels are black. Did you buy the truck the way it is or change them yourself? I think the black looks much much better than olive would have looked.
Old 01-14-2015, 11:09 AM   #18
Coursey
Coursey's Avatar
I bought it like this. Glad it wasn't green though.
Old 01-14-2015, 11:11 AM   #19
Coursey
Coursey's Avatar
Does anyone know the correct size for the upper and lower bolts that hold the spring on?
I would like to have them handy for win I finally get the old ones off.
Old 01-14-2015, 12:35 PM   #20
nlped
nlped's Avatar
If nobody gets you the answer before this evening, I'll check my stash and get you the info.
Carter
Old 01-14-2015, 10:09 PM   #21
Coursey
Coursey's Avatar
Just a suggestion.
Current tire size is 255/70/15.
When measuring through center of wheel the front is 32 3/8" and the rear is 33 3/4".
Old 01-14-2015, 10:35 PM   #22
67 cst swb
67 cst swb's Avatar
So, If I did my math correctly.
The front should be 17.84" from centerline of front wheel to the measured location on the front wheel lip.
The rear should be 19.22" from centerline of rear wheel to the measured location on the rear wheel lip.
It will be interesting to see the actual measured drop once you're done.
My Trucks:
Old 01-15-2015, 08:18 PM   #23
Coursey
Coursey's Avatar
Figured out a trick to get to the top bolt easier. Just take the bottom one out then put an extension up through it.
Old 01-15-2015, 08:20 PM   #24
Coursey
Coursey's Avatar
The old spring was 13 1/8". The new one is 8 1/2".
Old 01-15-2015, 08:21 PM   #25
Coursey
Coursey's Avatar
Which way is up on the new springs?
