Old 05-24-2021, 02:23 PM   #1
Hart_Rod
Hart_Rod's Avatar
Suburban lowering question
Will the lowering kits for 84-87 fit on the 89? If so, what kit do you use? If not, what kit do you use? TIA
Hart_Rod is offline   Reply With Quote
Old 05-24-2021, 03:46 PM   #2
Ziegelsteinfaust
Re: Suburban lowering question
Kits for 73-88 or what ever the change over is will work.
Being a Burb you should 1.25 inch rotors.
I would do spindles before coils depending on how low you desire to go.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-24-2021, 07:55 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
89-81 suburbans are the same as the 73-87 burbs.
Also mentioned you should have the 1.25” rotors.
I had a 91 burb lowered with 4” drop leaf springs.
You will need to shim the carrier bearing mount to help with driveshaft length.
I had drop spindles and springs up front.
I see a lot of people using flip kits on the rear.
TinWorks Fabrication make a bolt in c-notch with the “suburban only” body mount built in.
This gets you axle clearance, but also gets the center section of the rearend close to the bed floor.
Good luck with your build.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 05-25-2021, 08:24 AM   #4
Hart_Rod
Hart_Rod's Avatar
Thanks!
88-91 suburbans are the same as the 73-87 burbs.
I had a 91 burb lowered with 5” drop leaf springs.
Thanks Keith. Not sure I'm lowering it yet. I kinda like the look as is with the ralleys. Here's a picture with the factory 7" wheels that were on it when I got it, ... The ralleys look so much better!
Old 05-25-2021, 12:05 PM   #5
GRADYS Performance
GRADYS Performance's Avatar
Lower it just a couple of inches with spindles and shackles, it wide ride the same and look nice with your wheel and tire combination.
GRADYS Performance is offline   Reply With Quote
Old 05-25-2021, 12:15 PM   #6
lolife99
lolife99's Avatar
I told you wrong.
These were 4” drop leaf springs.
Keith
Old 05-25-2021, 01:07 PM   #7
Hart_Rod
Hart_Rod's Avatar
I told you wrong.
Whose kit did you use?
Old 05-25-2021, 05:24 PM   #8
lolife99
lolife99's Avatar
Originally Posted by Hart_Rod View Post
:metal
No kit.
They were Chisholm Leaf Springs, (out of business now)
I would use Western Chassis if you want drop leaf springs.
I thought a flip kit would be too low and no one made a bolt-in c-notch back then.
Belltech 3” drop spindles and 2” drop springs.
Belltech nitro drop shocks with rear shock extenders.
15x7 and 15x8 rally wheels.
215/70-15 and 275/60-15 tires.
Keith
Old 05-25-2021, 05:25 PM   #9
SCOTI
SCOTI's Avatar
Standard C10 lowering stuff up front.
Tinworks c-notch & flip kit out back. Swap a lift shackle in place if the flip is too much.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-25-2021, 05:55 PM   #10
lolife99
lolife99's Avatar
Better plan,... ^^^
Keith
Old 05-26-2021, 08:39 AM   #11
72c20customcamper
72c20customcamper's Avatar
I purchased 4 inch drop leafs and 3 inch coils for my Burban from Western chassis. Sold the truck before I had a chance to install.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 05-26-2021, 01:27 PM   #12
Hart_Rod
Hart_Rod's Avatar
No kit.
Thanks Scoti, looks like a good way to go.
Better plan,... ^^^
Agreed!
I'm guessing the parts went with the Burb?
Old 05-26-2021, 03:44 PM   #13
BlueJeep
BlueJeep's Avatar
Here's 4/6 drop, details are all in the build thread:
And the notch will get you axle clearance, but before the axle hits the frame or the diff hits the floor the tires will rub on the tops of the wheelhouses. That was NOT something I factored in...
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-26-2021, 04:08 PM   #14
Ol' Drippy
I used drop spindles and springs up front. In the back, I flipped the axle but then it was too low. In order to avoid notching the frame I lifted it back up a little with some short shackles from Rancho. That gave me enough clearance.
Ol' Drippy is offline   Reply With Quote
Old 05-26-2021, 05:01 PM   #15
SCOTI
SCOTI's Avatar
I thought I mentioned that clearance caveat & why I suggested raising the floor directly above the differential?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-26-2021, 05:11 PM   #16
BlueJeep
BlueJeep's Avatar
You did mention that, but the floor is NOT the problem. The wheel tubs are the problem, tires rub on them before the diff ever gets close to the floor....
Effectively, the tires rubbing on the wheel tubs are the "bump stops". I assume the wheel tubs are lower than the equivalent pickup ones, which is why the axle flipped truck guys don't mention this.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 05-26-2021, 06:31 PM   #17
SCOTI
SCOTI's Avatar
Interesting. I never thought about the tub location relative to the floor. My assumption was they bolted to the flooring just like the trucks which would yield similar height limitations. I was solely focusing on the differential to floor clearance.
Thanks for the insight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-26-2021, 06:43 PM   #18
BlueJeep
BlueJeep's Avatar
If you step back and think about it, it makes sense. The floor over the diff in a suburban is lower than the floor above the diff in a truck. If the same height wheel tub (unvalidated) is bolted to that floor, the top of that tub will also be lower than a truck.
Hopefully all of this is somewhat helpful to Hart Rod!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 05-26-2021, 08:31 PM   #19
72c20customcamper
No I still have them . New owner was keeping it all original . I guess I can see his point truck had never been touched.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-26-2021, 09:49 PM   #20
lolife99
lolife99's Avatar
Just so everyone can compare “apples to apples”,... what HEIGHT rear tire are your running?
Keith
Old 05-27-2021, 12:53 AM   #21
SCOTI
SCOTI's Avatar
I recall he was using 295/45-20's @ ~30.4" tall in the rear.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-27-2021, 07:46 AM   #22
GRADYS Performance
This is the piece of the puzzle that needs to be taken into consideration in the comparison.
Old 05-27-2021, 11:00 AM   #23
BlueJeep
BlueJeep's Avatar
Yep, they are what seems to be a "normal" size rear tire for squarebodies. 235/75R15 was stock and that is @28.9", so 1.5" taller, and .75" closer to the wheel tub.
Correct.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 05-30-2021, 12:54 PM   #24
Hart_Rod
Hart_Rod's Avatar
Are you interested in selling those parts? LMK.
Old 05-30-2021, 01:32 PM   #25
72c20customcamper
I have been looking for a square to use them on . I did speak with St.Louis about the leaf spring and the guy told me they fit my 72 C20 I'm not so sure though
I think shipping would be way more than they are worth.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
