Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-12-2018, 11:16 AM   #51
shearjs
shearjs's Avatar
Re: Project: '72 Family Hauler
I had a little time to get out in the garage on Sunday. I pulled the rear drums to see how the rear brakes look. No leaks from the wheel cylinders, and the shoes still have some wear, so I think i'll let them ride until I swap over to rear discs. Also took a look at what was going on out back from the previous owner. (Check out that exhaust hanger!!) I have some notches on order from Dead End Garage that should be in within the next couple of weeks. I pulled the old door weather stripping from the 3 doors, and installed some new push on Precision seals. I think I need to go ahead and replace the window seals soon, because the doors are so tight now that I feel like the glass may break when they get slammed shut. I pulled the burb out and made my first lap around the block since replacing everything up front. No funny sounds, and nothing fell off, so I think we're good! I did a quick string alignment to straighten the wheels and steering wheel, then pulled this crappy aftermarket wheel. The 14" diameter felt too small for one of these vehicles. I mounted a 15" repo comfortgrip in it's place. I have to say, I definitely prefer the comfortgrip over the Grant equivalent that was installed on my old truck. The horn connection is giving me a little trouble. I can get the horn to sound by pushing on the contacts, but once the horn button is installed, I can't get any noise. Any recommendations?
shearjs is offline   Reply With Quote
Old 03-12-2018, 07:03 PM   #52
04ls1gto
That's a structural exhaust hanger haha.
04ls1gto is offline   Reply With Quote
Old 03-12-2018, 07:27 PM   #53
LockDoc
The Older Generation
LockDoc's Avatar
Where I come from it would be called "Bullet Proof"...
LockDoc
Leon
Old 03-13-2018, 08:50 AM   #54
04ls1gto
Where did you pick up the steering wheel? Why original is all cracked and beat up
Old 03-13-2018, 09:09 AM   #55
shearjs
shearjs's Avatar
It came from Ebay.
https://www.ebay.com/itm/Comfort-Gri...72.m2749.l2649
So far I'm extremely happy with the fit. I just haven't quite figured out the correct way to hook up the horn as there are no instructions.
Old 03-14-2018, 08:21 AM   #56
Hart_Rod
Hart_Rod's Avatar
Originally Posted by shearjs View Post
It came from Ebay.
I have a similar steering wheel. What is the issue with the horn?
http://www.camaros.net/forums/23-int...n-install.html
https://www.camarocentral.com/category_s/41119.htm
Hart_Rod is offline   Reply With Quote
Old 03-14-2018, 09:42 AM   #57
shearjs
shearjs's Avatar
Originally Posted by Hart_Rod View Post
Rob,
I have everything installed per the illustration. Is the spring from contact plunger the only thing that holds the steering contact away from the steering wheel? I can get the horn to honk when pushing down the contact, but when the horn button is snapped on, I get nothing.
Old 03-14-2018, 10:28 AM   #58
Hart_Rod
Hart_Rod's Avatar
Rob,
You should have a wire coming out of the plunger that connects to the switch ("E" in the diagram) that looks like this:
http://www.flamingriver.com/index.ph...0003/FR20120HN
Old 03-14-2018, 10:35 AM   #59
shearjs
shearjs's Avatar
Interesting. The aftermarket horn I took off had a wire in the plunger that was connected, but since this kit didn't include one of those, I removed it and instead installed the spring, then contact plunger. The contact plate with the 3 screws then holds down the plunger in the hole on top of the spring. I suppose I could put the plunger with the wire back in and hook the wire end to the little tab on the back of the 3 hole contact plate and see what happens. Should there be a spring behind the contact plate on top of the column nut that holds the horn button away from the wheel?
Old 03-14-2018, 10:39 AM   #60
Hart_Rod
Hart_Rod's Avatar
I believe my 3 hole contact plate is spring loaded.
Old 03-14-2018, 11:10 AM   #61
shearjs
shearjs's Avatar
This is what my kit came with, minus the horn contact canceling cam. I'm using the original truck cam. Other than what's pictured, I have the hub, the steering wheel, and the horn button.
https://www.camarocentral.com/1967_1...t_p/ste-85.htm
Old 03-18-2018, 01:35 PM   #62
shearjs
shearjs's Avatar
So, it turns out that the horn/steering wheel was installed correctly. I just didn’t have the horn button on exactly right. At least it was something simple even if it did make me feel like an idiot. I took the Burb in for an alignment yesterday. I’ve put 10-15 miles on it since then and it drives down the road awesome. The steering is nice and tight. The rear suspension bottoms out on decent bumps so I’ll be installing the notch soon. I also picked up a 1” block to put in at that time. The inside edge of the rear tires are rubbing the tubs a little on bumps. I’ll probably try massaging the tubs a little with a block of wood and hammer and maybe add a 1/4” spacer when I redo the rear end. I’m sure the panhard bar could use a little adjusting as well. It feels good to actually have it on the road!
Old 03-18-2018, 04:47 PM   #63
LockDoc
LockDoc's Avatar
Good deal. Glad you have it on the road.
LockDoc
Leon
Old 03-18-2018, 05:45 PM   #64
goldenburb
goldenburb's Avatar
Way cool how nice wheels and lower stance can make. Good job.
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 03-18-2018, 07:10 PM   #65
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Congrats on getting it on the road!
68SWB4x4 is offline   Reply With Quote
Old 03-19-2018, 08:08 AM   #66
Bennett68C10
Bennett68C10's Avatar
Burb is looking good Jason, glad to see you out driving it.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-19-2018, 12:13 PM   #67
Perpendicular
The stance is perfect!
Perpendicular is offline   Reply With Quote
Old 03-19-2018, 10:03 PM   #68
Advanced Design
Advanced Design's Avatar
Congrat’s looks very good!
Advanced Design is offline   Reply With Quote
Old 03-20-2018, 04:34 PM   #69
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It sure looks sweet now! Great work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-29-2018, 05:49 PM   #70
Duraburb
Duraburb's Avatar
Sweet Burb!!
1972 C20 Suburban, Bagged and c10 swapped Suspension (sold)
1969 Jimmy, 2wd swapped. bagged, body dropped
Duraburb is offline   Reply With Quote
Old 03-29-2018, 09:03 PM   #71
gringoloco
A guy with a truck
gringoloco's Avatar
Love it! Doing flat caps on the TTs?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-30-2018, 08:42 AM   #72
shearjs
shearjs's Avatar
Thanks guys! It's coming along. I've decided to go ahead and address the rear suspension while the weather is still crappy. I have a c-notch, panhard bar, and some rear shock relocators that I picked up from Jason over at Dead End Garage. New trailing arm bushings, some new shocks, and a 1" lowering block are in the plans. I've replaced the lenses on the turn signals, tail lights, and reverse lights and replaced a couple broken door handles. I also replaced the front factory lap belts with some 3 point retractable belts from Morris Classic. I hope to tackle the suspension stuff within the next week or so and will have some new updated pictures.
I've contemplated doing flat caps like you had on your Streeter wheels, but I'll probably leave the original caps on for now. I do like the look though and it may be in the books for a future upgrade.
Old 03-30-2018, 11:47 AM   #73
Bennett68C10
Nice buddy, can’t wait to see the next round of updates!
Keith
66 Suburban
IG: bennett68c10
Old 03-30-2018, 02:59 PM   #74
duke_lbz
duke_lbz's Avatar
Looking good. Ive got similar plans for my recently purchased burb
07 GMC Sierra 2500 compound turbo' duramax
99 GMC Yukon solid axle swapped
67 Chevy c10 small window swb stepside supercharged ls6
70 Chevy c10 suburban
72 K5 Blazer 4wd
duke_lbz is offline   Reply With Quote
Old 04-09-2018, 10:19 PM   #75
shearjs
shearjs's Avatar
I was really hoping to have a new round of updates to share from this past weekend. Instead, all I have to show for it is a fractured 4th metacarpal in my right hand. While drilling holes in the trailing arms to mount the new Deadend Garage lower shock relocators, my drill bit grabbed and torqued the drill around in my hand. That force was enough to break the bone. Vacation day was wasted after drilling two measly holes...minor setback.
